12-04-2022, 12:29 PM | #133 | |
Rep 5,097
1. after the car is completely off(ignition off) 2. charged with jump terminals under the hood 3. hood stays open and up If these conditions are met(per user manual), then foreman should ask field engineers to check your car to diagnose why 48V system wakes up. |
12-04-2022, 02:14 PM | #134 | |
Rep 6,045
12-04-2022, 03:27 PM | #135 |
Rep 5,097
It appears those with MHT charging issues are not DD, but I would assume they also have garages to store their cars for extended period of time, and leaving the hood open and up(to disconnect 48V?) while charging 12V should not be an issue.
12-04-2022, 04:06 PM | #136 | |
Rep 6,045
12-04-2022, 06:15 PM | #137 |
Rep 2,350
So, if you do not have a garage or not drive it daily, do not buy a BMW. Correct?
12-04-2022, 06:31 PM | #138 | |
Rep 5,097
So one thing to consider is to figure out how to hit those parameters, e.g. u may be able to make the ECU think the hood is open and up. |
12-05-2022, 05:52 AM | #139 | ||
Rep 15,858
Clearly there is the instruction to have the hood open, (User Manual and BMW service documents), as that initially switches off the 48V electrical system. (Activated again either by a system request, or external 12V charging). There is reference in a different document to high voltage batteries (plug-in hybrid) that charger activation for the 12V battery must be within 3 minutes from opening the bonnet/hood. Quote:
Thinking about it, If BMW are following the same design logic for the MHT as charging the PHEV's 12V battery from a 12V charger, it could be the immediate (less than 3 minutes) charger activation, which initiates the correct system request. We need someone to test the 'timing', see if this is a critical part of starting a successful charge. |
12-05-2022, 06:06 AM | #140 | ||
Rep 15,858
Simply put, with energy management as it is these days, driving profile does have a part in keeping our battery/batteries in a good state of charge. If our profile is outside the ideal, we do need to maintain our batteries. BMW's advice during Covid, gave a good clue to how we really need regular battery maintenance, if we don't use a vehicle regularly. BMW UK posted the following... Quote:
12-05-2022, 06:58 AM | #141 | |
Rep 2,350
My Honda sitted for eight months with nobody being home to even touch it and started when I pulled the key out if my pocket. Tried to fill the battery thinking it was low and to my surprise the charging to full took little over one hour. Talking about a good car that really shuts off when you press LOCK. And that one was also fully loaded with alarm on. So I disagree,something is too much and off with these cars, and the more I look into it, the more disgusted I get. I own a 2012 BMW as well, the guy can sit few months without any trouble with the alarm on, and even that guy still works sometimes as you can hear buzzing once in a while. Yet, while not perfect, he is ok and never got me to “dangerously low battery level”. Very dissapointed by the power consumption in these cars. I rather have none of the nanies that take so much power. I probably need to sell it and find myself something else, or an almost new preMHT era vehicle. What bothers me the most is the fact that BMW comes with no official response or proper instructions. And to make it more confusing, some people can charge it with a 5 A and some don’t?! In my opinion, nice car but shitty car. Not sure that I want that anymore. Even if I can deal with it, just the principle of it bothers me tremendously As I feel lied and ignored by the manufacturer. If I knew about this ahead, I would have never buy it. In the end, it doesnt’t matter about the instructions an Covid crap, what it matters is the fact that BMW is incapable of making a car that shuts down everything when you press the lock button like others, keeping only the alarm in a stand-by mode. |
12-05-2022, 07:24 AM | #142 | ||
Rep 15,858
To be honest, it is what it is, has been so for at least 10-years.
Using it 3 times a week, about 25 miles each trip, just about holds the same charge, during the winter months. Anything less and the battery SoC will slowly drop off, as energy demand is higher than the driving charge available. It's not the battery, (same with it's new one) it is the nature of the beast. The closed circuit current draw can be quite high, without a discharge warning. For vehicles like mine, the following applies. Quote:
I can see why BMW gives specific instructions to BMW dealers, why they need to regularly charge the batteries of vehicles stored on their sites. |
12-05-2022, 11:30 AM | #143 |
Rep 299
So the NOCO 25 got here and I gave it a shot. So first off, it works. After plugging it in, it began charging with no clicking noises! Only noticed one sound closer to full charge which I believe was a switch to charge the 48v. After the sound I noticed the battery level in idrive started going up.
One thing I did notice this time, if you plug the car in before all the interior lights go off, it starts clicking. If you wait ~5 minutes for everything to shut off and then begin charging, no clicking. This is different than what I experience with the mxs5, that one I couldn't get the clicking to stop no matter what |
12-05-2022, 11:38 AM | #144 | |
Rep 5,097
HighlandPete6658.50 JSaid286.00 |
12-05-2022, 11:40 AM | #145 |
Rep 5,097
12-05-2022, 11:53 AM | #146 | |
Rep 15,858
Interesting, possibly fits with the "system request" comment and waking up the 48V battery. Could all be about charging start-up sequence. If it is, BMW could explain it a lot better. |
JSaid286.00 |
12-05-2022, 11:57 AM | #147 | ||
Rep 299
12-06-2022, 05:25 PM | #148 | |
Rep 2,350
A Few questions please: 1. So, when you plug it in without properly turned off, you still have the clicking? And is repetitive like with our regular chargers , or only once? 2. You managed to -somehow- be in the area when that click happened and presume that it switched to the lithium battery charge? Or you slept beside it just to obseve? Very important… 3. Should I understand that once the 12 battery is charged, the system will switch to charging the 48V Li battery? And you can also visualize that on the screen? 4. If tht Noco was -obviously- set for AGM battery and 12 V, - how it charges a 48V battery? - and how does it given the AGM SETTING? (i presume that the 12V system will automatically do that as they reciprocally charge one another?) 5. Did you try to put the 5 amp after everyting was charged just to confirm the theory that under a certain, minimal, voltage loss, the 5 Ah still works , and only under o bigger loss it doesn’t? 6. Can you put the charger on but lock the car in the meantime? Leaving the hood open of course. For ex, on the other BMWs I can. Thats enough for today… Thanks Last edited by Teutonic; 12-06-2022 at 05:39 PM.. |
12-07-2022, 05:35 PM | #149 |
Rep 80
My 2023 440i was in storage for 2 months in FL hooked to a CTEK MXS 5 amp charger. The charger has been at stage 7 for two months, green light indicating a fully charged battery. I left the hood unlatched as recommended by BMW.Today I started the car and there were two errors, battery maintenance and emergency call unavailable. Upon starting the car, the battery error disappeared but the emergency call unavailable is still there. Probably unrelated to the battery. So as far as I am concerned, all the clicks and whirring sounds that I ignored have not appeared to cause any issues. I will be driving the car in FL over the next 5 months and see if anything untoward crops up.
12-07-2022, 06:09 PM | #150 | |
General
13576
Rep 20,217
12-07-2022, 06:30 PM | #151 | |
Rep 80
12-07-2022, 06:47 PM | #152 |
General
13576
Rep 20,217
CarPlay uses your phone's connection and not the vehicle's. Wuite a few folks who had had the Emergency Call Malfunction message have had to get the TCU replaced so was wondering if you had any other symptoms, ie. the vehicle doesn't connect using its cell.
12-07-2022, 07:19 PM | #153 |
Rep 80
My phone is connecting fine. All my settings are unchanged. I’ve only driven the car a few times since I took delivery in early October. Don’t know about anything else.
12-07-2022, 07:26 PM | #154 |
General
13576
Rep 20,217
You are misunderstanding what I'm asking, your phone has nothing to do with it. The vehicle has a cell connection that is used for the emergency calling, real-time traffic, searching within navigation, calling concierge, etc. If the are not available then a bad TCU could be one of the reasons. Could also be that BMW servers are having an issue or the cell connection is down. Try restarting iDrive (push and hold in the volume button for 30 seconds. It is easiest to do while driving since you will get the feedback of the CID going black to signify the reboot has started) and see if the message goes away. If it continues then you will want to take it in to get looked at. Good luck and let us know how it turns out.
