06-07-2022, 09:05 AM | #1 |
Rep 831
Got the VIN can I check if anything is removed?
Just got VIN for my car. Is it possible for me to check what was removed from my current build or is it still to early?
Current: 2022 BMW M440gc / 2022 BMW x5 45e
06-07-2022, 09:50 AM | #2 |
General
13576
Rep 20,213
Ask your CA to run you a new Vehicle Inquiry or you can use the F12 process to look at the options and look for deletes.
The instructions are around but can post if needed.
06-07-2022, 11:03 AM | #3 | |
Rep 49
Curious if options might have been deleted |
06-07-2022, 11:14 AM | #4 | |
General
13576
Rep 20,213
Safari: https://g05.bimmerpost.com/forums/sh...&postcount=164 Mostly complete option code list: https://g05.bimmerpost.com/forums/sh...&postcount=720
kruzader21.00 |
06-07-2022, 11:18 AM | #5 | |
Rep 52
dataContent.ProdVehicleDetails[0].options 'options' has all codes like - options: "0ZAX 0ZDY 0ZHO 0ZPK 0ZPP...." You can use your VIN in a decoder to get all the decoded information as well. |
06-07-2022, 11:22 AM | #6 |
General
13576
Rep 20,213
The VIN is only available for decoders after the vehicle has been built.
06-07-2022, 01:02 PM | #7 | |
Rep 32
06-07-2022, 01:03 PM | #8 | |
General
13576
Rep 20,213
06-07-2022, 01:17 PM | #9 | |
Rep 115
enter your vin there and it should pop up with all the things your car is built with. Mdecoder never really worked for me as it always says i've reached the daily limit. |
06-09-2022, 04:48 PM | #11 |
Rep 2,719
I just received my VIN today.I decided to look up my M340i on the VIN decoder and I was surprised to see that it already has all the specs for the vehicle.Does that mean that production has definitely been completed.
06-09-2022, 04:50 PM | #12 |
Rep 32
Not necessarily. You can have a full options list of the car before it's even been completed.
06-09-2022, 04:56 PM | #13 |
Rep 2,719
OK,thanks.So the specs in the VIN decoder could still change once the car has fully completed production.I am interested in seeing what deletions there will be.I used bimmerwork.
06-09-2022, 05:02 PM | #14 | |
General
13576
Rep 20,213
Perhaps something has changed but the details for the VIN were never available on Mdecoder until the build was complete. It could also be Bimmerwork is different.
06-09-2022, 05:09 PM | #15 |
Rep 2,719
I just tried Mdecoder and it says vehicle not found try again later.Maybe bimmerwork is able to give the info before production is completed.I can’t imagine that the vehicle has finished production already because yesterday there wasn’t a VIN and today there is.
06-09-2022, 05:11 PM | #16 |
General
13576
Rep 20,213
If you didn't get a VIN until today then it has not been completed. Bimmer.work must pull from a different db.
06-09-2022, 05:15 PM | #17 |
Rep 2,719
06-09-2022, 06:57 PM | #18 |
Rep 32
Yeah I was using mdecoder and during my production run they added the passenger lumbar delete code.
01-04-2023, 06:42 AM | #20 |
General
13576
Rep 20,213
It means that parts have been ordered/allocated, not that assembly has begun. The time between getting a VIN and final assembly varies by model. It generally a week or two from what I have seen.
01-12-2023, 08:45 AM | #21 |
Rep 43
Hi,
I checked today mdecoder.com and finally it displays my configuration. In production date it mentions : 2023/01/10 does that mean that the car has already been build? |
01-12-2023, 09:43 AM | #22 |
General
13576
Rep 20,213
Yes, that means it has been completed.
