09-15-2023, 06:57 AM | #1 |
Rep 23
T Cut on Cirium?
Hi, I have a couple of stubborn marks on the grill surround which is in cirium grey. Anyone tried T Cut on this or any other suggestions? Thanks
09-15-2023, 02:37 PM | #2 |
Rep 1,156
What kind of marks? The most likely culprit is mineral deposits from water drying, in which case a water spot remover will be your best bet. A polish is safe to use on cerium trim though for reference.
09-17-2023, 06:48 AM | #5 |
Rep 23
Thanks for the comments. I should have said- car has been in garage and think mechanic has either put greasy hands on it or rubbed something on it - hard to tell what it is. I will try some mild cleaners. I have autoglym super resin so may try that.
09-17-2023, 07:34 AM | #6 |
Rep 2,195
Is your paintwork GTechniq coatings like your wheels?
09-17-2023, 04:00 PM | #8 |
Rep 2,195
If you're considering ceramic for the paintwork soon then, just a suggestion, but maybe wait until then and have your chosen detailer sort those marks out for you prior to applying the coating?
When the guy I used did mine when the car was less than a month old he meticulously did a paintwork check and preparation before applying the GTechniq serum ultra coating. Even he had to do some light machine polishing of the factory finish to get it to a stage which he was happy with before applying the coating. |
