09-22-2022, 10:31 PM | #23 |
Rep 843
Drives: ...
Garage List 2015 Lamborghini Hu ... [10.00]
2018 BMW M3 [10.00] 1997 BMW E36 [0.00] 2022 BMW X5M [0.00] 2022 BMW 330i [0.00] 2023 Cadillac Escalade [0.00] 2023 Honda Civic Ty ... [10.00] |
Anyone install their system yet?
CURRENT: 97 E36 | 15 Huracan 610-4 | 18 F80 Competition | 22 F95 Competition | 24 G80 Competition | 23 Escalade | 24 Civic Type R
09-23-2022, 06:59 AM | #25 |
Rep 3,134
09-25-2022, 12:24 PM | #26 |
Rep 13
09-26-2022, 07:02 AM | #27 |
Rep 3,134
Would take some fabrication but a competent muffler shop I wouldnt think would have too much of an issue. What exactly it would entail I could not say but at worst it would be cutting off the inlet pipes altogether and routing smaller pipe instead that 2-2.5'. With how much growth happens in the pipe when heated I just don't see the bigger pipe working with the existing bracing despite any modfications without some rubbing either when the system is hot or cold.
09-26-2022, 02:04 PM | #28 | |
Rep 1,009
09-26-2022, 02:59 PM | #29 |
Rep 3,134
1WickedE90199.00 |
11-12-2022, 07:54 AM | #30 |
Rep 115
Such a good design utilizing the stock valve system. But how can you sell a straight tip exhaust when the stock diffuser is tapered the tips look so out of place. Amerritx, FI exhaust all have this figured out don't see why you guys can't
12-07-2023, 07:25 AM | #34 |
Rep 3,134
Couldn't say for sure one way or another as it's never been fit on the hybrid but it appears unlikely. From comparing the factory ETK's, the factory exhausts themselves have different part numbers and appear to have different cut points, hanger locations and pipe sizes (330e pipe is substantially smaller) so even if it would physically fit, at minimum, there would be some adaptation needed on the pipe side.
12-07-2023, 10:10 AM | #35 |
Rep 25
Will this fit my 2024 LCI 330i? Also, are the valves controlled by a remote control or is it controlled by the car’s original actuator by changing drive mode (like the stock muffler)?
12-07-2023, 10:20 AM | #36 |
Rep 3,134
Yes it would fit the LCI. Valve behavior is the same as OEM as the factory actuator and control (factory ECU/programming) is retained. For full control of the valve you would need to purchase the remote valve controller that Dinan and a few other entities offer.
