02-20-2023, 12:33 AM | #309 |
Rep 164
Anyone here have a direct comparison to how much the main downpipes add for power? I currently have secondary downpipes and full Remus so trying to see if it’s worth taking out the front set
02-23-2023, 05:24 PM | #310 |
Rep 2
High Elevation
You guys with your low to negative DAs make me so jealous. Check these out.
I should head to the Gulf coast while it's still winter. Downpipes and Stage 2 e30 OTS tune. Forged wheels. |
02-23-2023, 10:06 PM | #312 |
Rep 2
Yea, I was surprised to get that low. I've only had the car for about 3 months now. I'm impressed at just how fast they are. In my little rural town, there isn't anything faster.
05-05-2023, 06:05 AM | #313 |
Rep 10
M5 F90 SWR St2 E40
hi guys, here are my results, in custom tune By (JDL__87 SWR Team) instagram. Only downpipes, XHP, E40 fuel. The car is made for rolling launch runs, 1000 meters. 200-250 kmh seems to be a good result. For the 100-200 we made a good torque limit to preserve the connecting rods.
SatinblkF90134.00 |
07-25-2023, 12:16 AM | #314 |
Rep 764
Drives: 2020 BMW M5 Comp
20’ comp , carbon roof , steel brakes, 789m wheels with new Michelin ps 4s, 350lb driver
Only mod is bootmod3 ots stage 1 93. Half tank of Shell 93 with 1 gallon of e85
11-23-2023, 01:04 PM | #316 |
Rep 282
One invalid run that I cannot figure out, same road same direction on all the runs above lol
Mods are pump 93 octane, Dinan inlet with bmc drop in filter, Racechip on 7, catless secondary with resonator delete. (muffler shop did such a bad job I believe I added the restriction back to the exhaust with the resonator delete. Apparently they used a 2.5 to 2.75" pipe) Last edited by Kponti; 11-23-2023 at 01:11 PM.. |
11-23-2023, 01:11 PM | #317 |
Rep 282
M8 coupe with factory Pirellis that are atrocious for drag racing. Ordered new tires today, tire mod alone will probably make car faster than any additional power can. Tires only have 4k miles on it and look brand new but suck on launch.
Tom C44.50 |
01-13-2024, 06:50 PM | #319 | |
Rep 239
Is that launch control or manual? Still trying to find the best settings Suspension - I've always been in sport+ but heard maybe Comfort is better? Traction - I've been doing 4wd Sport based on recommendation but didn't notice any real difference vs 4wd in my dragy times. Any other tips? |
04-14-2024, 08:12 PM | #321 |
Rep 6
Reviving this thread here, this is a pre lci 2018 base model.
1.54 60ft on a rubbish surface. I'm currently the 8th fastest on the dragy leaderboard once you remove duplicates Forged engine. E35 map with meth. Stock turbos and stock gearbox. The car has surpassed its 100 launch limiter for the ZF8HP75 variant. However it has a custom velocitytuning.uk gearbox map which removes this limiter along with a plethora of other changes. The car is an absolute weapon. |
