Technical Topics Wheels and Tires Wheel Specifications 791M, 792M, 793M
      08-21-2019, 02:19 PM   #1
WXdrivefun
WXdrivefun's Avatar
Drives: G20 330Xdrive
Hi Everyone,
Can anyone verify the wheel specifications for the 19" wheels mentioned below for 791M; 792M; 793M wheels with M-Performance Brakes or with the ZTK package?
From what I know our BMW G20s have a bolt pattern of 5X112, but what about other specifications like:
Center Bore?
Offset?
Wheel Width? Stagger i believe is 8 in front and 8.5 in Rear?
      08-22-2019, 09:30 AM   #2
stvding
stvding's Avatar
Drives: G20 M340ix
I was told by my dealer that 791M black wheel on M340i needs ZTK in Canada !!! I don't understand.
      08-22-2019, 10:24 AM   #3
WXdrivefun
WXdrivefun's Avatar
I believe this is true in Canada, the package is called 'M Enhanced Track Package' code: ZGW
With Fall season approaching, definitely need to look at Tires and Rim combinations, especially for those including myself with the Summer Tires.
      08-22-2019, 12:06 PM   #4
remmib
General
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
They're all the same size. Front 19x8 ET27 and rear 19x8.5 ET40.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      08-22-2019, 08:25 PM   #5
raptorapture
raptorapture's Avatar
Drives: 2020 m340i
2020 M340i  [0.00]
Center bore is 66.6mm
      08-26-2019, 12:37 PM   #6
Delta5
Drives: 2020 M340i, 2018 X3 30i
TireRack recently added the G20 to their wheel database. They now list regular and winter wheel/tire combos, 18 and 19. If buying elsewhere, you could use their suggested wheel sizes as a starting point for specs.
I emailed their customer support regarding ZTK and was told that their listed 19's would work, but 18's will not. I'm planning on ordering a winter set from them soon.
