03-03-2020, 03:55 PM | #1 |
Rep 147
330e home charging
Some advice please.
What is best for charging 330e mSport at home. Is it worth putting in a proper home charging point - I should be eligible for £500 grant - or do I just use 3 pin plug. We have cheap night time electricity. Car will come with both 3pin and type 2 charging cable as standard. Any advice much appreciated. |
03-03-2020, 04:46 PM | #2 |
Rep 414
I decided to get Pod-Point installed, and take advantage of that grant (whilst its there). They did a decent job installing it and it looks tidy.
Driving - 330e M Sport 2020
Previous - 2017 F32 420d M Sport, 2014 F30 330d M Sport, 2011 E90 320d Efficient Dynamics |
03-04-2020, 12:44 AM | #3 |
Rep 62
Are you sure the type 2 cable is standard? Unless they've changed the spec it's not.
Where I am there's enough free charging to justify a type 2 cable. (About 700m if free electric in the last couple of months, break even is about 2k) |
03-04-2020, 01:27 AM | #4 |
Rep 275
Another with a Pod Point here. Decent install just allow two or three weeks for install date.
I’d also go for a 7kw charger as the recommended 3.6kw system won’t preheat or cool without using stored charge. |
03-04-2020, 01:58 AM | #5 |
Rep 147
Yes - as from March orders/builds both come as standard.
03-04-2020, 01:59 AM | #6 |
Rep 2,234
I believe it was recently announced that from April, the 330e will come with both types of cable included.
03-04-2020, 03:03 AM | #7 |
Rep 414
I didn't know what about the 7kw charger. I got the 7kw as its gives a bit more future proofing (for when the missus gets some kind of EV).
03-04-2020, 03:07 AM | #8 |
Rep 252
Definately get the 7kw, as stated above, its best to get future proofed whilst the grant is available, mind the keep an eye on the budget next week, the grant could get canned.
03-04-2020, 03:30 AM | #9 | |
Rep 43
Also, the 3-pin that comes with the car will not give more than 2,3 kW (10 amp) no matter how you set up the charging options in the car. Some aftermarket 3-pin chargers can give 16A, but the one that comes with the car is limited to 10A. As for 7.2 kW etc. chargers; 330e cannot use anything above 3,7 kW (1-phase 16A), not for charging or for preconditioning; if one looks at the charging port in the car there is only one phase connected and there is no indication anywhere that one could take more than 16A from that phase; this means 3.7 kW max for any use. So only thing going for > 3.7 kW chargers with 330e is futureproofness which IMO makes sense; these are not gonna be our last ever pluggable cars. I actually have a 22 kW capable charger, it is just currently connected only to single phase and limited to 16A so that I did not need to make any change in fuses/cabling in my house, the charger just replaced one outdoor plug. When I need more power in the future I'll just have electrician make necessary changes in the cabling; no need for a new charger box. |
03-04-2020, 04:12 AM | #10 |
Rep 147
03-04-2020, 07:16 AM | #11 |
Rep 13
03-04-2020, 08:41 AM | #12 |
Rep 275
I have. The 3.6kw charger charges just as fast as the 7kw but as soon as you introduce any pre conditioning the power required is too much for the charger alone so the battery loses 3 or 4 miles off the range. In another thread those with a 7 kw feed were unaffected. This isn’t commonly known or advised when selecting a charger.
Anyone looking to purchase a Pod Point or similar should spec a 7kw charger imho. |
03-04-2020, 09:14 AM | #13 | |
Rep 13
Too late though! I might see if I can change my order. Did you upgrade your charger to 7kwh? |
03-04-2020, 09:36 AM | #14 | |
Rep 43
This is what the manual says: "The AC rapid charging cable enables fast charging at sockets of designated AC charging stations through a special plug. Alternating current is used to charge at labelled AC charging stations. The charging process can be completed faster than with domestic socket outlets. A charging current of up to maximum 16 A is possible." More than 16A draw from single phase would actually need higher rated cable so drawing more than 16A without telling in the the spec would be kind of not ok; there is (a very theoretical one) fire hazard in draving more than spec says since. I've heard and personally seen that battery can be depleted a bit when preconditioning and charging with 8A or 10A via 3 pin cable and it can happen in theory with the 3.7 kW charger too as there supposedly is 5 kW heater in the car. But this is very first time I have heard anyone claim that the car draw more than 3.7 kW in any situation; if it could it would be displayed somewhere in the specs. |
03-04-2020, 12:38 PM | #15 |
Rep 275
03-04-2020, 01:35 PM | #16 |
Rep 13
03-04-2020, 01:36 PM | #17 | |
Rep 13
03-04-2020, 03:34 PM | #18 | |
Rep 275
Warmer weather soon so it won’t be required. I don’t think pre cooling is something I’ll need. Just open the windows for a couple of minutes |
03-04-2020, 04:07 PM | #19 |
Rep 674
Make sure you take advantage of this offer. My bmw dealer didn't know about it..
https://discover.bmw.co.uk/offers/2020-q1-phev 7kw charger plus installed all for free! |
03-05-2020, 01:37 AM | #21 | |
Rep 80
03-05-2020, 02:06 AM | #22 |
Rep 252
Thats just the OLEV grant isnt it? Some folk have to pay more if the install deviates from the standard.
https://pod-point.com/guides/driver/olev-grant |
