03-01-2011, 04:01 PM | #24 |
One cam is enough
130
Rep 6,801
That's a HP COMPAQ BERKELEY-GL8E G33 MOTHERBOARD according to the p/n.
Onboard video is there, where the cover is. Whether or not there's an option to disable onboard in the BIOS, I don't know.... Does the mobo POST? When you turn it on, do the fans power up and behave normally? |
03-01-2011, 04:03 PM | #25 | |
Resident Black Guy
251
Rep 2,302
03-01-2011, 04:06 PM | #26 |
One cam is enough
130
Rep 6,801
Do you get no video on startup or does it hang at a certain point?
Also, if you're using the onboard video port, maybe try removing the graphics card (with the computer powered off), and then try that. Your BIOS is a really basic set of settings for your computer to know what to do with its accessories and peripherals and how to communicate to them. It's not OS dependent and can contain some pretty dangerous stuff. There may or may not be an option in there to disable the ability of the onboard video to output a video signal or to disable the output of video through there if a peripheral graphics card is installed instead. Anyway, as basic and easy to get to as the BIOS is, you can't get to it without video. |
03-01-2011, 04:11 PM | #28 |
Resident Black Guy
251
Rep 2,302
Also when I star it up it's not clear enough for me to be able to see what the screen is. It kind of looks like an Atari game or when the old Nintendo games wouldn't right and it would be a weird looking screen
03-01-2011, 04:14 PM | #29 |
One cam is enough
130
Rep 6,801
Out of the onboard port (the one you uncovered) or out of the video card?
03-01-2011, 04:20 PM | #31 |
Rep 4,709
I don't think you'd have to enter the BIOS since this just happened out of nowhere, but getting in there is different depending on the motherboard. Sometimes it will say "Press Delete to enter setup" when booting up. Other times you have to hit ALT+F8/F5 (I forget) or other combos.
If there's onboard video, there's got to be an option to disable it in the BIOS. |
03-01-2011, 04:27 PM | #32 |
Rep 4,709
I would check to see if you can boot into Safe Mode too. Once you press the key(s) I mentioned above to get to the boot menu, there should be an option to boot into safe mode. If you can do that, your hardware is OK.
03-01-2011, 04:37 PM | #33 | |
One cam is enough
130
Rep 6,801
If you want in the BIOS, it can vary, but my HP here uses F10 and F11 is for "Recovery" but those vary by BIOS provider more than final manufacturer. I don't know if my BIOS would be the same as OP's. Sometimes Delete gets you into the BIOS. But, like was said, if your video isn't even coming out right on your POST screen (where you see all the low-res nerdy info on the screen right when you start up), then you're not going to be able to properly navigate the BIOS or safe mode. |
03-01-2011, 07:10 PM | #36 |
d[-_-]b
484
Rep 968
I'm too drunk to give a good response right now but it seems it could be motherboard related if you cant get video on your aftermarket video card and onboard. Ill reply in the morning though.
03-01-2011, 08:10 PM | #37 | |
One cam is enough
130
Rep 6,801
It could be your mobo, but it could also very well just be your video card while your onboard is disabled. |
03-02-2011, 07:47 PM | #39 |
Rep 158
The onboard video on those boards are VGA and the card you have is DVI that is why the cable does not work, either that or you are using the HDMI output, I can't really tell which monitor you have.
The uncovered port should look like this : If so check the back of your monitor and see if the monitor has a similar looking part there. If it does head down to your local computer recycler/used computer store and ask for a VGA cable. Looks like this : Don't worry about the actual cable color, they come in different colors. If you do not have a VGA input on your monitor then you will need a VGA to DVI cable which looks like this: Once you have the cables problem taken care of, remove the video card which is shown in your photo's, attach the cables and try and power on and post the results. If it works and you are happy with picture quality then continue to use the onboard video. I'm going to take a guess that the video card you have now has a fan and the fan has stopped work causing overheating and failure. |
03-02-2011, 11:25 PM | #43 |
Rep 158
If you look at post #17 photo 1 you see a metal plate 90' to the back of the machine. Between the words FM Ant & S-Video, just to the left of them you see the end of a screw. Remove this screw.
Then open the case, this piece should be on a hinge and lift up and away from the case allowing you to remove the video card. Make sure all this is done with the computer unplugged. |
