12-07-2022, 07:46 PM | #155 | |
Rep 80
12-08-2022, 07:57 PM | #156 | |
Rep 80
TCU malfunctioning seems like a common problem with all BMWs. Another thing I learnt today about these cars. I will post an update after the service department has taken a look. With my 2022 Volvos and their new Android auto, connectivity used to be a problem but software updates solved those issues and I haven't had any more trouble except intermittently. I read that some folks had to have their TCU replaced multiple times in their BMWs. I hope that is not the case? |
12-08-2022, 08:27 PM | #157 | |
General
13582
Rep 20,217
Best to take what the folks at Genius say with a grain of salt. Interesting the person said that though, they usually suggest rebooting iDrive as a way to get folks off the phone since they rarely have a clue as to what the solution to the problem is. Good luck
12-09-2022, 08:39 PM | #158 | |
Rep 80
BMW’s bulletin doesn’t say that a 5 amp charger won’t charge the 12 v battery. Only that the hood must be unlatched and that the 48 v battery may not be charged. I don’t worry about the latter because Li ion batteries discharge very slowly at 2-3% a month. Last edited by anandn; 12-09-2022 at 08:45 PM.. |
12-09-2022, 09:24 PM | #159 | |
Rep 80
12-09-2022, 11:28 PM | #160 | |
Rep 1,799
Yes I use a 25A that works well but we’ve seen reports of 5A also working for others. I also think most people with 5A trickle chargers put it in AGM mode which should only charge the 12v battery anyway. |
12-10-2022, 05:44 AM | #161 | |
Rep 80
Important: Trickle chargers (< 20-amp output) or solar chargers will not be able to charge the 48 V battery, but could prevent further discharge to the 48 V battery when the 12 V battery is properly maintained to optimal SOC. The 48 V battery does NOT charge when using a 12 V battery charger with the hood closed. When charging the vehicle using a 12 V battery charger, the 48 V battery is ONLY able to charge with the hood open. I interpret these statements to mean that 5 amp and 10 amp chargers will not charge the 48v battery when hood is open (condition for charging the 12v battery using a 5 amp charger). Not that it, the 48 v Li ion battery, needs to be charged that way. But maintaining the 12v battery with a charger will prevent discharge of the 48 v battery when idle. I used the CTEk in AGM mode with the hood unlatched and the 12 v battery charged up fine but for all the commotion under the hood. This car is too smart for me. Last edited by anandn; 12-10-2022 at 06:46 AM.. |
12-10-2022, 11:32 AM | #162 | |
Rep 1,799
12-10-2022, 03:50 PM | #163 | |
Rep 80
Many are spooked by all the noise from the engine bay. The charger gets disconnected and the conclusion is that it doesn't work. I didn't do anything special to get my charger to charge the 12 v battery. I hooked it up, left the hood unlatched, locked the car and ignored the noise from the engine bay. |
12-10-2022, 04:50 PM | #164 | |
Rep 1,799
To add to the twist: there are others who don’t hear a persistent clicking sound after plugging in a 5A. So experiences tend to vary wildly here and it’s easy to understand why some people are frustrated. Anyway my point is that the bulletin you cited isn’t that relevant because it doesn’t really address the customer’s complaint. |
12-10-2022, 05:19 PM | #165 | |
Rep 80
12-10-2022, 05:57 PM | #166 |
General
13582
Rep 20,217
I think you missed the salient point, some people (at one time it was the overwhelming majority) can't charge their batteries using a maintainer, doesn't matter what brand or type, even when following the published procedure and ignoring the clicks/noises. This has been going on with various models since they introduced the mild-hybrid system.
12-10-2022, 07:11 PM | #167 | |
Rep 80
12-10-2022, 07:15 PM | #168 |
General
13582
Rep 20,217
LOL never mind.
12-10-2022, 09:17 PM | #169 |
Rep 80
12-10-2022, 09:22 PM | #170 |
General
13582
Rep 20,217
You obviously are very misinformed, confused or just joking around. There is no way you can actually believe that 48v MH systems are the same across all brands. Your experience with Volvos and all the others sports cars is not relevant at all.
TheMaxXHD641.00 |
12-12-2022, 07:18 AM | #171 |
Rep 14
Out of curiosity, what's wrong with these? Do they not work?
https://www.shopbmwusa.com/product/1...ATTERY-CHARGER https://www.shopbmwusa.com/product/1...LLIGATOR-CLIPS |
12-12-2022, 08:26 AM | #172 |
General
13582
Rep 20,217
The issue is not the charger but rather the individual vehicle. A charger will work fine on one vehicle but another person using the same charger and procedure will not be successful.
12-13-2022, 06:05 AM | #173 | ||
Rep 2,350
I bought a Noco 25 to see if it works as claimed and how. To add more to the confusion I an tell you that NOCO 25 DOES NOT WORK on my 2021 M340i MHT. Noco 25 Connected to the 2021 M340i I have the same behaviour: charger is pushing charge, first LED blinks at 25%. Compared with the Noco 5 or Noco10, Noco 25 has a fan incorporated. The fan starts spinning at max, then the grinding noise in the central angine area and the following click (relay maybe) in the 48V battery area. The charging status does not evolve and continuously gets reseted like in the past. POINTS: - 12 V Battery is almost fully charged. - The hood was open. Car locked, car unlocked, it doesn’t matter. - Connected right away, or after 5 minutes after turn off, it doesn’t matter. - the red hazard light and the left lights switch area are always lit - in my case it does not switch to Li battery charge and shows nothing in the “energy flow” display like user JSaid mentioned. - the “energy flow” does show however charging when engine is running and keep it over 1500-2000rpm. To add more confusion to the problem, I connected Noco 5 and I get the same behaviour with gringing and clicking but no charging. So no change here. But the Noco 10 got connected, and strange enough, it seems that the charging does occur this time (LEDs are evolving) but with grinding and clicking noises. This time the battery was charged via trunk before, so almost full, so I wonder if the charging percentage has something to do with under the hood charging. Noco 25 Connected to the 2021 X4 MHT I have the following: Car charges but does not move to charge the Li battery. I might also have another problem with this car, as compared with the M340, the X4 even when engine runs, the “energy flow” shows nothing on my screen. My Lithium looks depleted, who knows what other susrprises I might get… In the end, I am confused to max and start to believe that these cars are a pain to live with. still hope we can find the proper answer. |
bavarianride1513.50 tcbmhell10.50 |
12-13-2022, 12:25 PM | #174 | |
Rep 5,097
At first glance, it appears the specific setups of individual cars(e.g. option/package/integration-level combo) create untested configurations that BMWAG should debug and track down. |
12-14-2022, 04:10 PM | #175 | |
Rep 2,350
I am overly confused at this point… Last edited by Teutonic; 12-14-2022 at 04:25 PM.. |
12-15-2022, 12:11 AM | #176 | |
Rep 299
So with the noco 25, I plugged it in to the car after leaving it unlocked, hood open and waiting ~5-10 minutes for all the interior lights to shut off. I did check the battery level in idrive before starting and it was at 2 bars. After plugging it in the first thing I noticed was the familiar clicking noise from the ctek in the beginning, but it only happened once. It did not continuously occur as with the ctek. I then left the garage for a little. Upon coming back ~45 minutes later. The charger was on the last stage (blinking green) and I decided to hang around with it for a little. Shortly after I heard a new sound (like switches/relays flicking) again only once. After waiting about ~5-10 minutes I left the garage and came back another 20 or so minutes later. At that point I disconnected the charger to check on the car(still on last stage of charging) got in and checked idrive waking up the car. The idrive battery level was on four bars now as opposed to two before I started.I then let the car go back to sleep and finish charging until full. Started up the car and all seems fine. I scanned for codes as well and didn't find any except a few low battery warnings and some small driver assistance errors (from when I swapped my mirror caps disconnecting the glass, unrelated). To double check I cleared all the codes about a week later and retried charging. No codes showed up (however I noticed a code for a WLAN failure , I think it was on bmws side. The apps in idrive weren't loading for a few days and then it just started working again. Probably servers down or something). Maybe I can try recreating the battery management error and see if that throws anything. Since then I also took it in to the dealer for an oil change and figured I'd have them check the battery as well. I mentioned the sounds and prior errors and they ended up doing a full inspection of the 48v battery as well as the rest of the car and found nothing wrong with it. At this point I'm just summing it up to the 48v system makes weird sounds lol they must be a normal part of the charging system. if anything goes wrong later I can point out my previous dealer visit and hopefully it's an easy warranty claim but I think it's all good. I'll continue to scan for codes occasionally to see if anything comes up I don't leave the car sitting for too long at a time it's mostly if the roads are bad(New York) so I don't think I'll run into this again with leaving the car unlocked in the garage. Im pretty sure it was the security system draining the battery quick. You can also monitor all of the 48v battery performance metrics while you drive with BimmerLink so maybe I'll give that a shot too |
Teutonic2709.00 |
