Technical Topics Wheels and Tires Will any 18x8 5x112 wheel fit?
      08-05-2019, 09:19 PM   #1
Liquid_Ice
Drives: 2020 BMW M340i xDrive
I'm looking to buy a set of wheels for winter tires - would I be able to buy almost any 18x8 5x112 wheel?
This is for my 2020 M340i (has not arrived yet) - My car doesn't have the ZTK, so an 18" wheel should fit.
I read somewhere though that the lugnuts might be different on the G20 and therefore - for example a VW or Mercedes wheel in 18x8 5x112 would not work. Is this true?
Thanks!
      08-06-2019, 11:20 AM   #2
Booster
Pave The Rainforest
269
Drives: Wagon
2007 335i Coupe  [0.00]
"any" is a stretch...
Have to make sure that the offset (for brake clearance) and hub size are correct... You should be able to use your existing lug bolts...
Sold: 2015 Pyrite Brown M3
Sold: 2020 Sunset Orange M340i Xdrive
Sold: 2021 Bluestone 540i Xdrive Msport
      08-06-2019, 02:24 PM   #3
Liquid_Ice
Got it - I was thinking more of buying some cheap OEM rims from Mercedes or VW off of eBay. I think the hub size are the same for Mercedes as BMW now.
BMW OEM rims in 5x112.0 right now are expensive - and for winter wheels, I don't really care too much - I would think OEM Mercedes rims would be decent?
Here are the specs of a set I'm looking at:
Bolt Pattern: 5x112
CB: 66.56
Offset: +35
I think those would work on the G20?
      08-07-2019, 05:48 AM   #4
Booster
Pave The Rainforest
269
Drives: Wagon
Our offsets are in the low to mid 20's...
with your 35 offset, they may not clear brakes and will be tucked in further for sure if they did clear...
would have to run spacers...
