Technical Topics Wheels and Tires What can I run on M340 x-drive 20"?
      02-28-2020, 06:29 PM   #1
Mr.G20 M340
Mr.G20 M340's Avatar
Drives: 2020 Portimao Blue M340-x
Hello,
I have had the car for a month and I'm very new to the AWD world and don't want to ruin the car and got an opportunity to team up with an awesome company for wheels, I can't wait to show you guys. But anywho, I'm going with 20" wheels and wanted to know what dimensions I can run on the wheels and tires? Is 8.5/9.5 okay? I wish I could run 9.5 all around. Also what tire sizes can I go with?
Instagram: Bmw_Captivate
2020 Portimao Blue M340 X Drive and adaptive suspension.
Mods: custom exhaust, VRSF Catted DP, Injen intake and Chargepipe.
      02-28-2020, 09:14 PM   #2
Preciseyyc
Preciseyyc's Avatar
Drives: F15 35i G20 m340
You can run anything you want. As long as diameter front to back is the same.
I'll be running 20 x8.5 with 255/30/20 and 20x10.5 with 295/25/20
      03-01-2020, 09:55 AM   #3
Asterix
Asterix's Avatar
21
Drives: BMW 330i G20 Msport
That's beefy , what ET do you have for the rims ? No rubbing
      03-01-2020, 09:57 AM   #4
Preciseyyc
Preciseyyc's Avatar
I honestly can't remember the specs. They're on order currently. But we spent about 2 weeks going over specs and doing measurements so it'll be perfect fitment with around 1mm of wheel metal poking out but with the tire size they'll be within the wheel wells
      03-01-2020, 10:37 AM   #5
Asterix
Asterix's Avatar
21
Would appreciate if you can share when you have the wheels .
In the front 255 ? no limitation of turning angle ?
      03-01-2020, 10:40 AM   #6
Preciseyyc
Preciseyyc's Avatar
No with test fitting that we did with spacers and such there's none.
From memory we did 12ish mm more aggressive than the stock 437m front and back. Doing work vsxx so our specs also allowed for the extra bit of lip work uses on their wheels versus cheap wheels.
