11-07-2023, 12:50 PM | #45 |
Rep 60
Drives: 330e xDrive 2021
I noticed my FF and PWM (WGDC) curves has a negative curve which affects the shape of the boost curve. I don’t really like that it is a negative curve beginning of the pull so I decided to experiment and set FF back to 50 and lowered Duty bias below 40 starting at 4k rpm. I wanted to have a positive FF/PWM curve rather than negative one at the beginning of the pull and have the same smoothness on the boosts at the higher rpms. The result is was exactly what I expected. My FF/PWM curves are positive at the beginng of the pull and the boosts are pretty much the same as when I set FF to 20. Now I don’t know the details as to why lol. I believe FF and DB affects the shape of boost curve. PID affects how far FF can be from PWM and ideally you want them close or similar. I didn’t fix the throttle closure but my FF/PWM curve is positive and both are close to each other.
the fist graph below is when FF was set to 20 and DB are below that at the higher rpms. You can see FF and WGDC are negative curved and has more distance between each other. the second graph is when FF was set to 50 and DB are below that at higher rpms. You can see FF and WGDC are positive and they are very close to each other. As far as throttle closure for my car, it’s still a mystery to me. |
11-07-2023, 01:42 PM | #46 | |
Rep 70
11-07-2023, 04:32 PM | #47 | |
Rep 60
The last three graphs, FF was set to 20 DB was set to 0 from 5K, 5.5k. i guess I can set FF to 50 and DB to 0 from about 5k rpm and see if ECU_PSI will be much lower than the DME_BT. i don’t think it will honestly. |
11-07-2023, 04:50 PM | #48 |
Rep 60
@[cola.p]
Here’s a graph of a 1/4mile run i did a while back where you can see my throttle through out the gears are low even though my ECU_PSI is lower than DME_BT. This actually one of my faster 1/4 mile runs. Maybe this “throttle fix” doesn’t apply to 330e’s. I really don’t know. But I’m glad I fixed my boost oscillations lol. |
11-09-2023, 05:20 PM | #49 | |
Rep 70
From my understanding, Duty Bias = 0 is equal to 50 (default). I have read somewhere. Then you might try DB = 20 or 15 from 5,000rpm this should pull ecu_psi under dme_bt. Not sure it will help or this will not fix 330e throttle closure issue as you said. |
11-09-2023, 10:13 PM | #50 |
Rep 60
i think if you set all DB through out the rpm range to 0 is the same as the default which is 50 all through out the rpm range. I could be wrong though. I also tried 30, 20, 10 and 0 and throttle still the same. I remember experimenting with ASBR and I got the throttle to open up. I set them to 80 and 100. I was trying to figure out my boost spike after shifts and for some reason my throttle started to open up. Here are the graphs showing that. In the second image, the logs are runs from 1st to 3rd gear. You can see in the third gear, throttle was open. I actually posted this in jb4tech.com a few months ago.
11-12-2023, 06:54 PM | #51 | |
Rep 70
Throttle on 2nd image looks great! Because off ASBR adjustment? How does it work? and what is your best ASBR setting? I tried to figure it out for a while but very tiny information on the Internet. By the way, could you please give me some tips for dragy 100-200kph? Which gear and what speed to push 100% pedal? Last edited by cola.p; 11-12-2023 at 07:12 PM.. |
11-12-2023, 08:42 PM | #52 | |
Rep 60
Currently for my car, I get the best 100-200km/h time by using the paddle shifters and shifting at 6k rpm to 4th gear and to 5th gear and shifting at 5.5k rpm going to 6th gear. With my boost targets and dp, the turbo spools faster but also loses steam sooner so I have to shift sooner than when it does on auto. I think if I can get rid of the speed limiter, my time will be faster. |
11-12-2023, 09:58 PM | #53 | |
Rep 70
Seems like ASBR would not be a way to go stick at default value. For 100-200, as you guided, I need to practice a lot |
01-25-2024, 08:49 AM | #54 |
Rep 142
Drives: BMW 330e 2021
Hi 330eJL did you fix your throttle closure issues? I installed a month a ago a JB4 on my 330e, and while the car runs great on map 1 or 2 (with 93 gas), I see throttle closures similar to yours on the logs at around 5300RPMs. However I also see the same throttle closures at map 0...
01-26-2024, 12:06 PM | #55 |
Rep 2
Drives: G80 M3 Competition
Hey, I was thinking about making a 500HP 330i build, I think the engine does have the potential for that, so far with a simple downpipe, exhaust, stage 1, and cold air intake I would be pushing close to 340hp, I was thinking about putting a stage 2 turbo on it and then doing a stage 2 remap, which could put me closer to 450hp, but I don't know what else I would have to do or replace to go 500Hp
01-26-2024, 04:49 PM | #56 | |
Rep 60
https://youtu.be/cXtGi5yjnOs?si=8GMoTKndixM7Pydv https://youtu.be/1yigaG2PFB0?si=eAJdSEptaxKio0Ys |
01-26-2024, 05:13 PM | #57 | |
Rep 60
gorthol64.00 |
05-02-2024, 12:58 PM | #58 |
Rep 60
I think I kinda figured out the throttle issue. It is directly related to IAT. The higher IAT is, the less throttle closures the car gets. I’ve experimented with this with IAT Spoofing. On a cold day, I did logs without spoofing vs with spoofing. Without spoofing, the IAT was at 82F. Everything looks good except the usual throttle closures and the gap between preboost and boost2. With setting the IAT to 122F, throttle closures were much less and there is very little gap between preboost and boost2. However, the AFR isnt as stable and there were some lean spots. The first image will show this. I’ve done this multiple times with similar results. I’ve done many different settings and spoofing IAT seems to be the one that consistently decreases throttle closures for my car. You can feel the difference when setting the IAT high on a cold day. It pulls harder, however the car runs lean, which I don’t like.
Now that the weather is warmer, i notice the car gets much less throttle closures. I did two logs today. The weather is 82F. The IAT on the first log is 109F. Then I parked the car for about 30min. I knew the IAT will be much higher since the engine bay will get hotter while parked. I did another log and there was pretty much no throttle closures. The IAT was 126F. There is no IAT spoofing so the car made whatever adjustments it needed to do to be safe. The the car had lower timing on the second run with a much higher IAT. Preboost and boost2 closely matches and AFR is good and stable. The 2nd image will show the first log i did today. The 3rd image will show the 2nd log I did after parking the car for 30min. I think with this car, just like I mentioned before, the throttle closures are fine and happens to keep the car safe or maintian the right AFR. You can decrease it with IAT spoofing but i dont recommend it. It makes the car run leaner. I don’t think there is much power difference, if any at all. Most likely it’s minimal. |
