01-15-2020, 12:30 PM | #309 |
Rep 174
New PB today
Screen, AC, BT etc all turned on 55.6 km
Sunset orange 330e M-Sport
YT:http://www.youtube.com/c/Mazzman IG: https://www.instagram.com/m4zzman/ |
01-15-2020, 01:00 PM | #310 |
Rep 395
Also the higher your car spec and the more options you have the more power they drain, according to the dealer that is but it does make sense, all the radars reading the road constantly for the self drive must be using something.
01-15-2020, 01:42 PM | #311 |
Rep 15,858
That's what we need to see.
The other interesting figure is 17.4kWh/100km... that's right on the 330e WLTP rating... * Vehicle Consumption 280 Wh/mile (for UK users). So it is possible. * Vehicle = calculated battery energy consumption used by the vehicle for propulsion and on-board systems. |
01-15-2020, 01:49 PM | #312 | |
Rep 15,858
Other than the necessary onboard systems to run and propel the car, everything else is consuming energy that could be 'miles'. Including what appears insignificant, like interior lights, or charging the phone. Using high energy consumers like heated seats, rear heated screen, really eat into the mileage. |
01-15-2020, 01:50 PM | #313 |
Rep 829
Picked up my new 330e. Brilliant 200 mile drive home. I have some questions:
1. What amp setting in the car should I use with the granny cable and 3 pin socket? 2. What is the charging socket in the armrest storage box for? It’s too small for a USB. 3. Can you send a destination to the car from your phone? When I do a message shows on the app saying log into your account in the vehicle to start navigation - how do you do that? 4. Can you personalise the news feeds like you can in the G30? 5. Today’s trip isn’t showing under the activity tab in the app, should it? Thanks in advance! Last edited by Chuckyarla; 01-15-2020 at 01:58 PM.. |
01-15-2020, 01:53 PM | #314 |
Rep 15,858
Still interested in the kWh/100km (or Wh/mile) figures. That is key to the actual consumption. If it calculates and adds up with charge rates, will tell you how accurate the readouts and predictions are.
01-15-2020, 02:04 PM | #315 | |
Rep 27
01-15-2020, 02:13 PM | #316 | |
Rep 283
True very true. But then I have a base spec M Sport with no additional options. |
01-15-2020, 02:18 PM | #317 | |
Rep 283
1. Depends on your wiring at home? I have mine set at 10a and it’s fine, but it’ll be set to 6a out of the box. If you live in a house with decent wiring and loads try “amping” it up a bit each day to see where you go. I’m sticking with 10. 2. It’s a USB C socket. Faster charging than USB A (regular one). 3. Yes you can - through connected drive app. Better still, use voice assistant - it’s very good for the most part - including the “Hey BmW, take me home!” 4. Not sure about personalising news feeds. 5. App doesn’t show journey data I’m afraid. There is a tab for it on the full web version of Connected Drive “virtual cockpit” - but it appears to be broken and doesn’t work for many users. Get some pics up! Enjoy! |
01-15-2020, 02:20 PM | #318 |
Rep 15,858
And that is the issue and a lot of the disappointment in EV mileage. The official tests, like the WLTP rating and published figures, are not reflecting how most are going to drive.
01-15-2020, 02:20 PM | #319 |
Rep 283
HighlandPete6658.50 |
01-15-2020, 03:20 PM | #320 | |
Rep 829
01-15-2020, 03:24 PM | #321 | |
Rep 283
01-15-2020, 03:50 PM | #322 |
Rep 829
01-15-2020, 04:00 PM | #323 | |
Rep 2,234
I'm thinking of ordering a 330e, so I'm interested in stuff like this. You say you "popped it into cruise control", but what did you do to the drivetrain? Force it to use the ICE? How? I've had a play in the showroom and I'm aware you have various options to control the battery etc. |
01-15-2020, 04:04 PM | #324 | ||
Rep 165
01-15-2020, 04:05 PM | #325 |
Rep 2,234
01-15-2020, 04:11 PM | #326 | |
Rep 165
Also in hybrid mode the battery will be used unless you either exceed 68mph or accelerate hard the t he ICE kicks in |
01-15-2020, 04:52 PM | #327 | |
Rep 2,234
Maybe when Cranester1983 replies it will be clear. |
01-16-2020, 01:46 AM | #328 |
Rep 829
How do you set the temperature that the climatisation will climatise to? Also when I got in my heated seat and steering wheel were on - very nice! How can I set it so that the passenger seat also pre-heats in order to keep my wife happy?
01-16-2020, 07:59 AM | #329 | |
Rep 283
You can pop it into manual shift to engage the petrol engine or let it do itself above 68mph |
mofomat791.50 |
01-16-2020, 08:00 AM | #330 | |
Rep 283
Be warned though as good as it is, it eats a fair chunk into the battery life before you start! |
