09-09-2020, 01:03 PM | #23 | |
Rep 11
Im noticing and as someone stated, M series tends to be a little noisy. Does it seem to come from the rear or the front as another member suggested? And yes I had mentioned a few posts up it is more for feed back to see if we should go ahead with a product. Its in existence for other cars now that suffer from road noise and exhaust. Just checking if its an issue with the BMW's Thank you |
09-10-2020, 03:22 PM | #24 |
Rep 7,484
We're having a discussion on UK Off topic of how the 20d engines are prone to "sound deadening roulette." Some are quiet. Some sound raucous. Noise in cabin varies hugely. Might be worth looking into that if you can.
09-10-2020, 05:04 PM | #25 |
Rep 1,481
M cars are definitely louder all around. The liners on my M3 / M4 in my house hold are all plastic, therefore gravel and what not create a lot of sound that can be transmitted back into cabin. The wheel liners on my X1, the 550i, the old E46 (all non-Ms) were fabric material lined which significantly decreased the same noise that the M3/M4 generates over the same patch of road.
Couple of other things that increase sound on M cars are obviously lack of sound deadening material, stiffer suspension, bigger wheels / stiffer low profile tires and the subframe being directly bolted without any bushings. |
09-15-2020, 10:09 AM | #26 | ||
Rep 11
We too noticed more recently, certain cars had "carpeted" like wheel wells to help mute rocks, pebbles..etc. But it really does not help with overall tire noise from harder compound tires and or runflats during long trips on certain surfaced roads. My question is would a sound barrier in the trunk help prevent much of that noise from getting into were you live (cockpit). Sometimes its hard to tell where noise leaks in from. My feeling is the rear of the car. No drone from aftermarket exhaust? Great feed back James |
09-16-2020, 10:08 PM | #27 |
1Addict
3233
Rep 7,894
Heavily modified E82 here. Lots of road noise from tires and moderate drone from big custom exhaust.
Interested pending product weight and where you would plan to apply it.
09-17-2020, 10:41 PM | #28 |
2006 TIME Person Of The Year
9720
Rep 6,445
I've literally sold and/or installed (at retail) at least 100 pallets of Dynamat. I also was the Dynamic Control (Dynamat) Rep for the NY-Metro area for like 7 years. I think I qualify as an expert on the topic.
Subarus are the sweet spot. 😉
04-16-2023, 05:12 PM | #29 |
Rep 224
I’ve an F31 M sport, the door closure was tinny and the factory fitted speakers were a joke. I added a vibe mini amp, match speakers with built in tweeters, front and rear doors, kept the under seat factory subwoofers,and added stinger sound deadening to the inside of all 4 doors. The amp and the match speakers sound amazing, even at full volume, no distortion and no vibration. The factory fitted subwoofers are 20 times the bass and don’t distort, in fact I have to set the equalizer bass very low, and still it can take the bass at high bass settings, this was the perfect set up for me, and inside the cabin the ride is super quiet without the audio on, the doors close with a thud rather then thinking the windows will shatter if someone closes them too hard. Despite the bonnet having the noise dampener underneath, being a diesel you can still hear the engine so I’m going to take off the noise dampener and line the bonnet skin with stinger sheets as a 1st skin, then the put the noise dampener back on as a second skin
Martin
04-19-2023, 04:17 PM | #30 | |
How's My Driving?
1082
Rep 987
You can probably find data on how much, or how little, sound deadening XYZ vehicle models have from the factory |
04-19-2023, 06:15 PM | #31 |
Rep 4,135
sound deadening in the cabin doesn't do squat to tire roar
i applied butyrl layer and sound foam all over the cabin and nothing changed with tire roar there is youtube video where a guy did 3 layers and to his disappointment the dB meter is unchanged lol i think you have to also insulate the wheel well the quietest cars are EVs - courtesy of the 6 inches of battery between you and the road |
