03-31-2024, 08:27 PM | #23 |
Rep 4,166
03-31-2024, 08:37 PM | #24 | |
Rep 458
EVERY single tire no matter what will wear differently in the end because of the unique situations a single tire will undergo in its life. These ratings are to show how fast a tire will wear when under the EXACT same circumstances. It is a guide to give an INDICATION of wear, and they can be very useful. Over decades of driving I have found them to be a great indicator. |
04-01-2024, 12:30 AM | #25 | |
Rep 5,091
"UTQG Treadwear grades are based on actual road use where the test tire is run in a convoy on a 400-mile test loop in Texas (West Texas, actually) for a total of 7,200 miles. The test vehicle can have its alignment set, air pressure checked, and tires rotated every 800 miles. At the end of the 7,200 mile test, the wear on the tires is measured and compared to a reference tire that was being run under the same conditions. If the test tire is expected to last as long as the reference tire, it receives a UTQG Treadwear grade of 100. If it is expected to last twice as long, it would receive a grade of 200. 300 means it is expected to last three times as long, and so on." Tirerack does quote 2 reasons why the treadwear ratings may not be incredibly reliable: 1. the test run is only for 7200 miles 2. manufacturers are allowed to under-report the Treadwear grade https://www.tirerack.com/upgrade-gar...utqg-standards |
