08-15-2021, 02:00 PM | #23 |
Barge driver
8656
Rep 12,425
First thing you should do in weather conditions like that is take full control of the car and reduce speed and increase the distance to the car in front, I'm actually quite shocked someone would just continue on cruise control regardless.
730d/Z4C
TiMSport12803.00 |
08-15-2021, 04:27 PM | #24 | |
Rep 6,031
Consider why the label even exists (referred to as a "placard" in the rule). The label adds cost and complexity to every vehicle and assembly plant. It's another step for the operator on the line. An OEM would be delighted not to have to have this additional part number, especially as recommended tire pressures are addressed in owner manuals. If a wrong label was applied from the different ones with different air pressures, it would create a non-compliance leading to a recall. I know this as I was part of the industry response to the advent of the air bag labels on visors way back when. The label only exists because the FMVSS reg requires it. As such, the content of the label is that which NHTSA requires the OEM to post for certification for safety in a maximum load condition, not some set of numbers the OEM thinks performs best.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner Last edited by Sportstick; 08-16-2021 at 08:35 AM.. |
08-16-2021, 11:21 AM | #25 |
Rep 132
I also found that my 330i xDrive with 19" all-seasons tires is dealing worse on standing water during heavier rain (I live in Seattle) than my other car with 18" all-seasons; I got scared once when it started to move under me as I was driving together with traffic under the speed limit (same as I was used with my other car) and the car in front of me didn't seem to experience anything.
Maybe the RF tires that my car came are not good on wet; they however have a tread-wear pretty high which means they would last more and I'll have to deal with them for longer (or spend $$$ and replace ). My 330i xDrive came with: 225/40/R19 Bridgestone Turanza LS100A A/S with "Treadwear 560, Traction A and Temperature A". The other car (also AWD) has: 215/45/R18 with Toyo Proxes A/S with "Treadwear 300, Traction B and Temperature A". I use 35PSI/42PSI on my 330i xDrive as per recommended on sticker and 36PSI/36PSI on my Mazda3 AWD as per sticker. Last edited by iulianm; 08-16-2021 at 11:39 AM.. |
08-16-2021, 11:34 AM | #26 | |
Rep 6,031
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
08-16-2021, 12:17 PM | #27 |
Rep 27
I have hydroplaned with brand new (under 500 miles) Michelin Sport A/S 3 tires
I don't think it's a G20 issue. I think speed + huge puddle is the issue lol |
08-16-2021, 05:33 PM | #28 |
Rep 2,983
Yes, let's be clear here. There are no tires completely immune to hydroplaning when the conditions are severe. The only thing you can do is slow down.
Sportstick4654.00 HighlandPete6658.50 ultrared93103.00 TristarL10109.50 Benjamin_Nicholas443.50 NorCalAthlete3191.00 |
08-17-2021, 06:38 AM | #29 | |
Rep 15,858
Tires only have two ways to prevent hydroplaning, storing the water in the tread/grooves and water dispersal. The shape of the footprint can make a little difference. Michelin indicate the rounded footprint is more efficient in water dispersal. Higher pressures can assist by helping with the wave front. I know from experience, that when we are in the mid range of tread wear, I find my winter tires are more efficient in coping with standing water than the summer set. Primarily due to the ability to store and disperse more water. |
TiMSport12803.00 |
08-17-2021, 01:45 PM | #30 |
Rep 88
When I'm driving in "heavy rain", mine automatically turns itself off and warns me to take over manually.
Once the roadway is obscured by heavy rain, the radar and camera sensors recognize this issue. When the anti skid senses "wheel slip" it also has input into the issue.
JLH
-EndOfAnEra-686.50 |
08-18-2021, 02:42 PM | #31 | |
Rep 1,067
Your tire pressures are wayyyy too high. At those speeds the tires will be very slick as the contact patch is minimal at best. If youre running RWD, 35-36 front 37-38 have worked well for me in for best grip & sharp turn in. i bet you can get the tires to squeal pretty easily at those pressures.
2019 G20 330i RWD
2014 F30 328i RWD 2009 E90 328i RWD 2006 E90 330i RWD 2002 E46 330i RWD Last edited by alpinewhite3; 08-18-2021 at 02:48 PM.. |
08-18-2021, 02:45 PM | #32 | |
Rep 1,067
Check how your tires are wearing. I was running 40 psi in the rear and realized it was over inflated by the constant squealing and confirmed via wear pattern.
2019 G20 330i RWD
2014 F30 328i RWD 2009 E90 328i RWD 2006 E90 330i RWD 2002 E46 330i RWD |
08-19-2021, 04:30 PM | #33 |
Rep 360
Drives: 2020 M340i RWD
Thanks everyone, appointment is set for Monday for an alignment check.
For those thinking of me as a devil-may-care madman, I assure you my wife would have a good laugh at that! Active cruise control will shut itself off if the rain is too heavy, it didn't do so those times. It did surprise me because I thought any traction loss would deactivate it! Taking a role as a scientist, after the first time when I recognized the active CC was contributing to the issue, I stopped using it until the next time it rained. I only turned it on again to test my hypothesis. I turned it off quickly. I've not had crazy rain since those times but due to this experience I've begun using more downshifting and engine braking with just enough brakes to slow/stop in the hopes of improving brake and tire wear on my fronts. Eagerly looking forward to BMW giving me a yay or nay on any issues! Thanks again! One interesting wrinkle which I will get a pic of later. iDrive itself is telling me that my PSI should be in the 40s which is why I set it there. I also thought that sounded high as my old car was around 34 PSI front, 36 PSI rear but figured BMW knew something I didn't.
"Christy" - 2020 BMW M340i 8AT BSM / Black&BlueStitching
Gone! "Edna" - 2011 BMW 335i 6MT TiAg / BlackOyster - M-Sport, Premium, Comfort Access, Navigation, Heated Seats, Rollerblinds R.I.P. "Heidi" - 2005 BMW 330xi 6MT BSM / Black - Sport, Premium, Cold Weather, Harmon Kardon, Navigation |
08-19-2021, 05:31 PM | #34 | |
Rep 15,858
Many who argue the case for something like a 35psi cold setting pressure, will be running near to 40psi once warm and driving distance. 40+psi "working" pressure on a RWD BMW, is not at all uncommon on the rear axle. |
hockeymen14120.00 |
08-20-2021, 08:36 AM | #35 | |
Rep 1,067
Sorry i should have clarified - my recommended pressures were hot running pressures-cold would be 33F35R. The rear axle will increase more than the front when running hot. So i usually en up at 34-38 /35-38. I never let it go over 40 now after seeing how my rear tires wore out down the middle after 10k mile. And then dont forget - every season you have to adjust b/c of temperatures changes. 10 degree mean 1 psi change.
2019 G20 330i RWD
08-20-2021, 09:28 AM | #36 | |
Rep 15,858
From Continental: |
08-23-2021, 03:48 PM | #37 |
Rep 311
If you take the time to read the instructions it is not recommended to use it in heavy rain, here in Europe on some roads it is even forbidden with loss of insurance in case of accident
08-23-2021, 05:19 PM | #38 |
Rep 21
Idk how you drove around with 44psi in the first place... That's just outrageously...dumb (to put it nicely). Thankfully you caught this before it became a bigger problem.
08-23-2021, 08:29 PM | #39 |
Rep 220
Drives: '20 M340iX
Never never ever ever drive using CC in the rain. Ever. It does not know how to modulate and predict standing water and the direction that water may be traveling (or not) at a given moment.
Second... cars hydroplane. If it happens, drive slower until it stops. |
08-24-2021, 09:40 AM | #40 | |
Barge driver
8656
Rep 12,425
Given that BMW still haven't managed to get rain sensing wipers to work properly yet, I'd rather back myself.
730d/Z4C
08-17-2023, 12:07 AM | #41 |
Rep 12
Had a similar problem in X3, I've crashed it few months ago on highway due to ACC and hydroplaning. Had 225/60 R18 both in front and rear. Once you get the tire tread under half of so its starts to get pretty bad same aplies for tire width, thinner is better. But BMW cruise control really sucks in this case whether on snow or wet, way worse than on cars i had before....
08-17-2023, 05:17 AM | #42 |
Rep 4,143
the problem is the rear tires are too wide too low profile and that's the cause of the hydroplane
i have the same car and it hydroplanes at anything over 50mph |
08-17-2023, 08:10 AM | #43 |
Rep 1,664
I have driven my m340i in biblical rain to the point you can barely see the car infront of you, on 225 square run flats which are the worst tires you can get. At 55mph the car does not hydroplane and feels completely stable. Always drive to the conditions.
ultrared93103.00 |
