BIMMERPOST Universal Forums Off-Topic Discussions Board Samsung Refrigerators
      01-04-2019, 05:49 PM   #1
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
Can I get some feedback on anyone owning a Samsung refrigerator? I read horror stories about performance, reliability, and customer service.
I need a refrigerator for a space that is only 67" x 33" (exactly). Selection is limited on the high end without getting more available height.
Samsung makes a French door that is only ~$1500, and looks ok for a sorta-budget French door.
https://www.samsung.com/us/home-appl...tasg-aa/#specs
TXSTYLE13847.00
      01-04-2019, 06:00 PM   #2
a4nut
Drives: 13 135is
We bought a 4 door samsung back in June when we moved in. It's been great so far. No issues
      01-04-2019, 06:07 PM   #3
BzsBimmer
BzsBimmer's Avatar
3274
Drives: '23 G80 FO M3, M3 & MY Tezzy's
Our Samsung fridge popped a leak through the ventilation system inside and caused it to drip under the deli tray. We only noticed it because the tray would not budge one day.
It just so happened that the warranty ran out a month prior so we were on our own.
Tossed it and got an LG
      01-04-2019, 06:27 PM   #4
Tuxedo
Bowties r cool ▶:◀
Tuxedo's Avatar
Drives: 09' 128i MT e88, 24'G05 X5 50e
I have one that has an Ice maker issue that Samsung admits is a defect but refused to take care of it. Paid for a service call and tech hillbillies it no charge, as he warned us fixing it correctly is $500 and no doubt will have the same issue later. Great product other then, french 4door
      01-04-2019, 06:46 PM   #5
zx10guy
Drives: 2013 135i
I also have french double door/bottom freezer/through door ice maker water dispenser. It's branded as a GE but is really a Samsung refrigerator. Had it for probably about 8 years now. Overall, ok. But had some problems with it. Shortly after getting it, the frig would make some loud knocking popping noise. Had a tech come out to look it over and could never find the problem (of course) and the frig would never make the noise when the tech was here (of course). It eventually went away on its own. Had some sensor go bad which was replaced under the extended warranty I got. I also seem to recall a board needing to be replaced too but not entirely certain.
Current problem I have is some frosting issue with the coil in the back of the refrigerator section. It's causing water to build up at the bottom of the refrigerator. If I don't drain out the water over time it'll spill over and leak out onto the floor of the kitchen. I talked to a tech a while ago about this and said it is a common problem with those refrigerators. Told me how to do a fix for it, but I've been too lazy to take apart the refrigerator to try the fix.
      01-04-2019, 06:55 PM   #6
a4nut
Drives: 13 135is
Here's what we have
https://www.bestbuy.com/site/samsung...?skuId=4906701
Just because it's different than the others
      01-04-2019, 06:58 PM   #7
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
My house came with a Samsung fridge. I probably wouldn't have chosen it myself, but it's been working just fine for the past four years.
      01-04-2019, 06:59 PM   #8
P1
P1's Avatar
11572
That's the one I have. Works just fine. Good standard fridge, I suppose.
      01-04-2019, 09:41 PM   #9
stbm5
Drives: 2018 M5 DG
i had a samsung. bought it 3 years ago. totl. after 4 major repairs my home warranty gave me 3500 to buy a new fridge. awful product. had ice maker replaced multiple times. then lines in the rear of the fridge kept freezing over, it'd have to be thawed out every few weeks. replaced it with a GE that I've had for 6 mos now without a problem.
pic above my post looks like the one i had.
      01-04-2019, 10:41 PM   #10
stevenvillatoro
stevenvillatoro's Avatar
Drives: ‘18 M240i, Estoril Blue
2018 BMW M240i  [0.00]
I also have the Samsung pictured. Would get an LG next time; never again a Samsung.
My complaints are its (1) poor space utilization, and (2) birdbrain design-engineering shortcomings.
—Steve
'19 MX-5 Miata GT-S soft top
Past BMWs: two '57 Isetta 300s, '70 1600, '72 Bavaria, '78 320i, '18 M240i
      01-04-2019, 10:43 PM   #11
Maestro
Drives: 2007 335i Sedan, 2021 X3
My in-laws have a Samsung, twice now the refig ended up demo mode which turns off the compressors but all the lights work, so you think the refig is running but it is not and there is no way to knows until everything melts in the freezer.
Turns out the controls for refig are on the front where the water and ice dispenser are when cleaning the front you can easily press the right key combination to put the unit in demo mode. I can not believe how stupid this is. Every refig I have owned always had the controls inside and in an out of way place.
BTW I just replaced our refig and went with kitchenaid, I have replaced all of our appliances with kitchenaid, and bought them at Sears scratch and dent, at 50% to 60% off. Great deal and units had minors scratches where you could not see. No reason to pay full price.
      01-04-2019, 10:48 PM   #12
2014 335i  [9.74]
The refrigerator being replaced was purchased at a Sears scratch & dent deal. Thing lasted 20 years without an issue. Even now the compressor just rattles, but it still works for now. (Knock on wood)
      01-04-2019, 11:00 PM   #13
svt1998gt
Drives: 2008 e90 335i, 2012 X5 M spor
I bought mine off of craigslist, its been through 3 moves owned it for 3.5 years and works great, before that i had a samsung fridge that lasted a long time in a garage in the Texas heat. We eat out alot and its rarely full but it does the job for us.
Knock on wood it doesnt go out after sending this message.
      01-04-2019, 11:16 PM   #14
BayMoWe335
Drives: 2010 E92 335i 6MT
Worst appliance I’ve owned. I have like a $2800 French door Samsung fridge with bottom freezer with ice and water on outside. GARBAGE.
Freezer thawed twice, randomly. Ruined all my food both times.
“Support” came out both times only to report that it had magically begun freezing again, with no faults.
Ice maker replaced 3 times. Each time froze over and stopped making ice. Solution was to turn off ice maker and buy ice from the store. Tastes better anyway.
A fan stopped working, replaced under warranty.
This was all in the first 3 years. The last 2 years, it’s been fine without making ice.
It’s also loud as fuck and I’m rolling it out to the curb the next issue I have and cutting my losses.
Samsung also has about the worst customer service I’ve dealt with in my life. Incompetent. Slow. Don’t give a shit.
      01-04-2019, 11:20 PM   #15
BayMoWe335
Maybe that’s what happened to mine. No way in hell I put it in demo mode because I never touch the keypad and no one else does either.
      01-04-2019, 11:21 PM   #16
BayMoWe335
See, others have the ice maker issue too. Mine is like that one, just without that third drawer.
Bullshit isn’t it?
      01-04-2019, 11:25 PM   #17
RickFLM4
RickFLM4's Avatar
Drives: M4
We have had ours for a couple of years without any issues so far. I agree it can be a bit loud when running. We had numerous problems with the GE it replaced over the years.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      01-04-2019, 11:59 PM   #18
stevenvillatoro
Yes, the noise... OMG, the NOISE!! When the compressor kicks in, there's a loud vibration. And occasionally, there's a multiple knock or thunk that used to make me think the house was coming apart. I'd probably have sold the POS by now, but how, in good conscience, could I sell the turd to someone else?? At least the ice-maker hasn't ever broken, but simply because I never use ice. Do not buy a Samsung! And this includes their laundry machines which I actually did send back for a refund.
—Steve
      01-05-2019, 12:36 AM   #19
Drv4fun
Drives: '13 M3 (original owner)
Everything mentioned above plus the doors DO NOT close on their own! Just go and compare in the store if you relase the door pushing it slightly it will close on ever other brand.
      01-05-2019, 01:15 AM   #20
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3038
Drives: 340 6MT, 50e, others
You're asking about the reliability of a Samsung refrigerator on the BMW forums..... lol.
They are the same. Both unreliable. I've got one. You can have it. Only broke. Once tho. Better than the washer dryer.
      01-05-2019, 01:24 AM   #21
Nivarox
Quadrex
Nivarox's Avatar
1093
Drives: W212 Mercedes=Benz E Class
I have got a Samsung but mine is one of the entry levels not having some fancy gadgetry as yours . It performs better than Bosch .I like Bosch as a brand but Samsung is doing better job because Bosch ,in hot days, constantly keeps beeping to alert unless you press Deep Freeze button whereas Samsung is just working as it should .
Comparing BMW i8 to Tesla Is Like Comparing Apples to Pineapples
      01-05-2019, 01:41 AM   #22
henrylee
henrylee's Avatar
Drives: 2018 F80 M3 6MT
I have a Samsung Food Showcase refrigerator and has been working well.
2018 F80 M3 6MT///Black Sapphire w/ Sakhir Orange Leather
2006 S2000 AP2 Laguna Blue Pearl 6MT
