02-15-2022, 08:15 PM | #1 |
Rep 1,521
I'm in the market for a set of aftermarket wheels but I'm having a difficult time deciding on which wheel to purchase.
I am between the HRE FF10 (color - tarmac) and the Vossen HF5 (color - gloss black); my M340i is alpine white with the shadow line package. Let me know your thoughts! |
02-15-2022, 11:54 PM | #2 |
Rep 410
Both are a great looking wheel.
I've already decided on HF-5 but a different color. There is another member with a white G20 and gloss black HF-5 wheels, looks damn good. The gloss black would match your shadow line trim great. I'm partial to Vossen as I have a set of VFS1 wheels on my G37 coupe. Then again can't go wrong with HRE.
Chubbiejones891.00 |
02-16-2022, 05:12 AM | #3 | |
Rep 1,521
Tough choices! |
02-16-2022, 09:16 AM | #4 |
Rep 410
Another thing to consider as well is wheel weight. I wanted to go from my stock 19" wheels to 20" but didn't want an increase in weight. I've confirmed with Vossen that the size and offset I am going with are lighter than my stock 19s. I'd be interested to see what those FF10s weigh. I figured the HREs would be more expensive, you are partly paying for the name I feel like. The design definitely screams Euro and would match well.
I lost about 5 lbs on my G37 when going from stock sport 19s to 20" Vossens. I looked up tire weight as well and added everything up, about 205 lbs vs 200 lbs.
02-16-2022, 10:11 AM | #5 |
Rep 123
Drives: 2022 BMW M340i xDrive
This one is tough. These are two of my favorite that I'm thinking about as well when I get my M340.
I have gone back and forth to this album and it's a great aggressive look on the HF-5s. I also love the FF10s "busy" style that makes you stop and look. You really can't go wrong with either IMHO.
2022 M340i xDrive - Black on Tacora Red Vernasca
Retired - 2014 335i xDrive |
02-16-2022, 12:34 PM | #6 | |
Rep 1,521
02-16-2022, 12:35 PM | #7 | |
Rep 1,521
HRE FF10 wheel weights: 20x9 = 26-28lbs (per wheel) 20x10.5 = 28-30lbs (per wheel) Vossen HF-5 wheel weights: 20x9.5 = 33-35lbs (per wheel) 20x10.5 = 36-38lbs (per wheel) For me, if weight is a factor, I will be definitely traveling with HRE wheels! I would have never thought Vossen wheels would have been almost 10lbs per wheel more than the HRE…crazy! |
ctbimmerfan27.00 |
02-16-2022, 10:48 PM | #8 |
Rep 410
Those weights are different than what Diego at Vossen provided me, hmmm....
He quoted me 24-25 lbs for HF-5 20x9. Did you get your weights from a website or did someone at Vossen provide you those? I'm curious about the discrepancyx, pretty big difference. The numbers I have recorded for my VFS1 wheels (same hybrid forged series) are 20x9 - 25 lbs, 20x10.5 - 26 lbs.
Chubbiejones891.00 ctbimmerfan27.00 |
02-17-2022, 05:58 AM | #10 | |
Rep 1,521
02-17-2022, 06:01 AM | #11 | |
Rep 1,521
Dang you chenry!! This throws another decision into the mix - Tarmac vs Silver on the FF10! I basically have the identical car and I must admit the silver really does give great contrast and it looks superb. The car is looking fantastic brother! |
02-17-2022, 11:50 AM | #12 |
Rep 44
FF10 design will be lost with a black wheel. If you must go with black, then go with Vossen. If you’re interested in a lighter color that will let the FF10 design show through, then FF10 might be the better choice.
Chubbiejones891.00 siegester344.50 |
02-17-2022, 11:55 AM | #13 |
Rep 1,521
Couldn't agree with you more! Those are my thoughts exactly. The difficult thing is I'm a sucker for black accents, including wheels, on a white vehicle. But as you have stated a European style wheel, especially black in color, becomes difficult to distinguish the design of the wheel.
02-17-2022, 11:57 AM | #14 |
Rep 158
My vote would be the HREs. I want the FF04s for my car.
02-17-2022, 02:00 PM | #16 | |
Rep 2,964
I'm not sure if you've had the opportunity to see the HRE "liquid metal" finish in person (it's their standard silver finish) but it really has a lot more gray and depth to it vs your typical & more traditional "hyper silver" finish. It's a very nice color in my opinion. Here's a pic for reference - the wheels are a little dirty though (I took the pic for the side skirt extension and vinyl behind it not for the wheel) Hope this helps a bit |
Chubbiejones891.00 pdxdbo331.00 |
02-17-2022, 02:07 PM | #17 | ||
Rep 1,521
02-17-2022, 02:16 PM | #18 | |||
Rep 2,964
I'm running a 19x9 square setup. ET is 25 however I do have a 5mm spacer on the front purely for aesthetic purposes so that makes front ET 20. Tires are 255/35 |
02-17-2022, 02:26 PM | #19 | ||||
Rep 1,521
https://g20.bimmerpost.com/forums/sh....php?t=1853598 |
02-17-2022, 02:49 PM | #20 | |
Rep 2,964
02-17-2022, 03:00 PM | #21 | ||
Rep 1,521
Stage 2 you say - do tell 😀😀 |
jpowers36218.00 |
02-20-2022, 02:52 PM | #22 |
Rep 31
CB too small on Vossen HF-5?
I've been lurking on this forum for about a year and this is my first post. There's certainly lots of great info to be found here!
As it turns out I too am considering the Vossen HF-5s for my '21 M340xi - currently on the stock square 791M 19' wheels. I can definitely appreciate the HRE FF10 as well but am looking for a simpler pattern. I've read the entire post with everyone's aftermarket wheel setups and have also tried to do my homework on square vs. staggered setups as well as spacer choices for flush fitment. As I understand it the CB for the HF-5 is 66.5mm but the hub bore on the G20 is 66.6mm. So are there spacers/adapters available that will allow fitment of the HF-5s? I'm assuming that's the only way to get them to fit outside of additional machining? Thanks for any additional info you can provide! |
