Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics My Trips in MyBMW App
      10-27-2022, 05:57 AM   #1
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
I noticed yesterday a new item in the Data Privacy in my 2020 M340's iDrive--MyTrips.
I checked & did a Google search on this feature; found out it provides an additional item on car screen of the app that provides mileage, time, MPG, etc for each trip.
In addition to checking the Data Privacy menu, I updated Data & Services in iDrive and logged out & back into app -- but no joy
Any thoughts?
Al
Retired: 2014 328i
BMW CCA
      10-27-2022, 08:49 AM   #2
gavinwong
gavinwong's Avatar
155
Drives: BMW G20 330e M Sport
2020 G20 330e  [9.00]
Hi,
Any thoughts?
Few of us discussing it here :
My Trips https://g20.bimmerpost.com/forums/sh....php?t=1960018
RSnic657.50
      10-30-2022, 05:20 PM   #3
tylers1027
Drives: 2022 330I
"My trips" was working on my app but for some reason I went to login the app and it made be do the whole sign-up/ registration process again. The app works now, but my trips no longer works. It's activated in the data privacy section in the car and I restarted I drive. Any ideas how to make it work?
      10-31-2022, 03:14 AM   #4
TikiTourer
Old Member
TikiTourer's Avatar
New Zealand
65
Drives: M340i, Mineral White
2020 BMW M340i  [0.00]
2013 125i  [0.00]
I'm pretty sure that there is a bug in the Store Version of the App...it isn't currently working in Android 2.9.2 (17848) although it was previously. My App version is Android 2.9.2 and my M340i is on 07/2022.57. BMW are aware of the problem
      11-01-2022, 05:45 AM   #5
RSnic
RSnic's Avatar
OuterBanks ,
Thanks for the update!
Still no joy! About the only thing I haven't tried is to delete & re-install my profile in my car — a little reluctant to do so because it also deletes my wife's profile (secondary driver) & re-installing is a crap shoot
Seems like app version (same as stated above) TikiTourer is cause??
Al
Retired: 2014 328i
BMW CCA
      11-01-2022, 01:24 PM   #6
chris_1001
chris_1001's Avatar
532
Drives: 2022 BMW M340i
So my BMW app is not updating the status of my car. It's last trip data was from Sunday. I removed and reinstalled the app, made sure my privacy was set properly on my car and nothing...
Any ideas?
2022 M340i XDrive, Oxide Grey Metallic/Tacora Red/Shadowline.
2004 330Ci (Sold), 2007 335i (Sold)..
      11-02-2022, 06:15 AM   #7
Wink3
Drives: 2011 E90
Any ideas?
I had the same problem. Reboot iDrive by holding in the volume button at least 30 seconds.
      11-02-2022, 11:16 AM   #8
G22b58
Drives: G22
It seems that a trip ends when turning off the car, so the two logged trips are correct according to that logic.
      11-02-2022, 11:25 AM   #9
chris_1001
chris_1001's Avatar
532
I did that about 6 times, no luck. also did the data privacy check boxes a few times. still cannot connect. Even deleted and reinstalled the App.
      11-04-2022, 04:39 PM   #10
stochastic_dev
Drives: 330e
Having the same issue, no updates from the car since 11/1, were you able to fix this? I've tried deleting app and data, rebooting iDrive, re-pairing the phone. Wondering if the update broke something, might have to call BMW
      11-05-2022, 01:15 PM   #11
chris_1001
chris_1001's Avatar
532
Nope, called the dealer twice, both times the genius was busy awaiting a call back
Mine died last Sunday. I was in an area with no cell reception. Got in the car, drove home and it still thinks I'm parked there.
I'm getting pretty frustrated
      11-05-2022, 02:15 PM   #12
tylers1027
Drives: 2022 330I
FYI there is a my bmw app update 11/2. I Uninstalled the app, reinstall the updated app and now it works!
      11-06-2022, 06:22 PM   #13
chris_1001
chris_1001's Avatar
532
Nope. I'm now on that version and no luck.
I'm getting pretty pissed.
I'll call the dealer again tomorrow
      11-11-2022, 05:57 PM   #14
TikiTourer
Old Member
TikiTourer's Avatar
New Zealand
65
2013 125i  [0.00]
Did they fix it? If not, in cases like yours, it's often best to remove the car from your BMW account. Wait to you the receive email from BMW confirming removal. Then Reset I-drive via long press. Uninstall the App from phone. Clear all cookies from your phones default browser.. reinstall App and add your car back in.
Then update Apps and Services in car I-drive..press Apps, tilt left to highlight Installed App, press Option, Seiect Update Apps and Services
This is basically a fresh start....
      11-12-2022, 12:47 PM   #15
drdino
drdino's Avatar
135
Drives: BMW 330i
2019 BMW 330i  [0.00]
FWIW, I've put this sheet together for My Trips working/not working. If anyone would like to contribute, please feel free to do so.
https://docs.google.com/spreadsheets...t?usp=drivesdk
      11-14-2022, 10:05 AM   #16
chris_1001
chris_1001's Avatar
532
Nope, they did not. Useless actually.
I basically did what you said and got it to work again. I disconnected the car using the website. Then added the car. No need for a. I Drive reset or deleting the app. Disconnecting the car reset everything
      11-15-2022, 04:32 PM   #17
TikiTourer
Old Member
TikiTourer's Avatar
New Zealand
65
2013 125i  [0.00]
That's great.. yes removing the car seems to cure most things.
I found similar when I first got my car...after about a month, I knew more about it than the so called BMW genius.😥😥
      11-29-2022, 06:42 AM   #18
RSnic
RSnic's Avatar
Hi,
Pardon my tardiness, but was visiting family.
Thanks to an update from Google Play Store, myBMW app now has working My Trips
Al
Retired: 2014 328i
BMW CCA
