04-08-2024, 11:34 AM | #1 |
Rep 29
New tire fitment
I am currently in the process of replacing my stock runflats on a staggered setup with stock wheels.
I have seen both people stating that you cannot run larger then 225/255 stock setup on stock rims because the larger size is not within 1% of the stock diameter. I have also seen people say that you can run say 235/265 setup because the diameter of those are within 1% of each other front to back. Which is the actual rule to go by for a 2023 xdrive on stock wheels? |
04-08-2024, 10:37 PM | #2 |
Rep 63
https://tiresize.com/calculator/
Plug in your 2 sizes to compare, you shouldn’t have a diameter/circumference over 1%. Closer to 0 the better Possible combinations that work for 19” 225/40 + 255/35 (.4%)(8.5” rear rim) 235/40 + 265/35 (.4%) (9” rear rim) 245/40 + 275/35 (.4%) (9.5” rear rim) |
