05-25-2022, 06:53 AM | #23 |
Rep 337
Another shame tbh, LLs are really effective around where I live.
05-31-2022, 08:18 PM | #24 | |
Rep 511
06-01-2022, 12:16 AM | #25 |
Rep 1,230
I don’t think the company has abandoned laser headlights - they are still available on new versions of the higher end models. They’ve just ditched them for cheaper headlights on the 3 series.
06-01-2022, 01:13 AM | #26 | |
Rep 5,681
I also don't see any reference to matrix technology in the blurb for the LCI 3-series and to be honest the explanation they've simply dropped the laser lights sounds more plausible to me.... Last edited by JNW1; 06-01-2022 at 02:10 AM.. |
QuarterMileJoe9.00 |
06-02-2022, 08:45 PM | #27 | |
Rep 511
The matrix tech is way way more reactive to traffic than the older tech that the lasers use.. obviously there’s no laser module in the lights which is what’s keeping the cost down.. £1000 vs £1500 I think these, the black pack etc being standard go towards the ~4k price increase for the LCI car. |
06-03-2022, 02:02 AM | #28 |
Rep 474
Seems odd why anyone would spec the vis. pack separately at £1k when it’s part of the msport pro pack at £2.8k.
Basically means you get everything else in the pro pack for £1.8k, which is dare I say it a slight bargain considering it includes adaptive dampers, upgraded wheels and msport braking system to name a few. |
06-03-2022, 09:42 AM | #29 | |
Rep 5,681
06-03-2022, 11:26 AM | #30 | |
Rep 1,230
06-04-2022, 06:28 AM | #31 | |
Rep 511
So obviously the 4 series, M3/M4 all use the same front end and have come into production after the LCI 5 series I’d suggest they’re using the same tech as that, and also why the option is priced at £1500 still. Obviously for the LCI 3 series they’ve decided to do away with the laser module on the matrix lights, I’m assuming to cheapen the option to £1000 (which adds up to me) They’ve thrown it in with the LCI 340’s probably to help justify the price increase. The best thing about the laser lights for me is the selective beam bit, and the matrix tech does this so much better.. so for me it’s a step forward. I once had a late night drive back from Whitby across the moors and the lasers were nothing short of amazing, but that’s probably 1% of my driving, for the rest of the night driving I do they just don’t react quick enough (after coming from a car with matrix tech) |
06-05-2022, 06:00 AM | #32 |
Rep 436
The laser lights are still an option on 5 Series (though now a stand alone as opposed to with adaptive)
Personally, I think it's the adaptive leds that have now been adopted to the 3 series, and the lasers are still up there where they were. Lasers are not part of the adaptive system per se, (so called 'dancing LED's) and only illuminate above 37 MPH, and switch off immediately when oncoming lights appear, or the rear lights of cars. I also think they switch off in illuminated areas. |
06-05-2022, 08:48 AM | #33 | |
Rep 5,681
06-05-2022, 11:09 AM | #34 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Laser lights will disappear on the rest of the range as the LCI’s and new models appear. They weren’t available in all markets worldwide anyway.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
06-07-2022, 06:06 PM | #35 | |
Rep 511
Not 100% what has which, but yes😄 |
06-08-2022, 06:01 PM | #36 | ||
Rep 383
06-09-2022, 01:27 AM | #37 |
Rep 1,230
When the beam forming is in operation the lasers are off. They are only on above 37mph and when there’s no other traffic or streetlights. Outside of that it’s just beam forming LEDs.
06-10-2022, 07:18 AM | #38 |
Rep 337
Are you 100% that LLs were active (and not just main beam) below 30 mph? iirc manual states 37mph minimum for activation, but I get main beam on at 25mph.
06-22-2022, 08:13 AM | #39 |
Rep 736
The new M3 Competition Touring (G81) will be available with Laser Lights.
So, it seems they're not being replaced by LED lights, they just won't be available on the G20 LCI. |
06-22-2022, 12:58 PM | #40 |
Rep 5,681
Unless - as was suggested by philmots - there are different derivatives of laser lights? If that's the case those fitted to the new M3 are presumably not the same (i.e. better) than those that used to be offered on the pre-LCI G20/21?
06-22-2022, 03:26 PM | #41 | |
Rep 736
I used Joe's video as a reference: (skip to 7.20) |
06-22-2022, 04:08 PM | #42 |
Rep 1,230
Some people seem to suggest that the existing laser lights don’t already use matrix LEDs alongside the lasers in the pre-LCI setup. They do, as shown by the complex beam forming capabilities. They are a step up from the standard LEDs (hence the reason why adding adaptive as an OTA upgrade doesn’t add beam forming, only auto-dipping).
06-24-2022, 09:39 AM | #44 | |
Rep 156
Laser high beams When the high beams are switched-on, starting with a speed of approx. 37 mph/60 km/h, the laser high beams in the headlight are automatically switched on in addition to the LED high beams. |
Matrixsenior10.50 |
