03-02-2024, 10:02 AM | #1 |
Rep 8
Xdrive tires size difference
Hello everyone 👋
May car is m340 2021 xdrive I want to run 225/45 r18 on front tires And 265/35 r18 on the rear Is that ok for the xdrive system or it could destroy the transfer case ? |
03-02-2024, 11:04 AM | #2 |
Rep 113
That difference is like a 2.7%, general rule
Of thumb is to be within 1%. Bump the front tires to 235/45 and rears to 265/40, and that would be almost perfect. https://tiresize.com/calculator/ |
Seba77W401.00 |
03-02-2024, 11:45 AM | #3 | |
Rep 547
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
03-02-2024, 12:40 PM | #4 | |
Rep 4,143
i have 2 cars with staggered and as i am wanting to keep them for a long time, i've bought square wheels for them and am in the process of changing to square for both of them ANY difference = slippage = heat = excess wear mind you with staggered, the difference could be exaggerated when rear tires wear more than front (depends if rear was smaller to start with, or front is smaller to start with), rear tire pressures higher/lower than front. the saving grace is the car is most of the time RWD on perfect roads in perfect driving conditions, unless you're driving it hard |
dhock_holiday210.50 |
03-02-2024, 02:05 PM | #5 | |
Rep 547
03-02-2024, 03:06 PM | #6 | |
Rep 4,143
however the transfer case breaking is not the end of the car, not like if the engine implodes, but any difference in diameter is still not ideal, 1% is just the high risk point, it's not like 0.9% the transfer case won't break, 1.1% the transfer case explodes, it's a continuum having said that, every time you turn the car the transfer case generates slippage/heat because all 4 wheels are now moving in 4 different speeds. which is why drifting an AWD car is the best way to get you a new transfer case. |
03-02-2024, 03:34 PM | #7 |
Rep 8
I can’t do 235/40 18
On the front tire because my car speed limit locked on 200km/h GPS So when I make the diameter shorter the speed limit on GPS will be less than that It will effect the 1/4 mile that’s a thing And If I make the rear 265/35/18 It will make the rear spin faster than the front and that should be ok because she already spin on launch control I think if the different between the front and rear with the (-%) it should be ok I don’t know 🤷 |
03-02-2024, 03:39 PM | #8 | |
Rep 4,143
i tried different tire sizes and checked the GPS speed - the first time i drive the speedo is way off. after a while it's magically back to 3km/h difference. so i think the car knows what the actual speed is. |
03-02-2024, 04:07 PM | #9 | |
Rep 113
03-02-2024, 04:15 PM | #10 | |
Rep 4,143
just be prepared to toast the TC if you drive it hard and keep it beyond the warranty period. if you drive it normally, 99% of the time it's RWD. TC is not expensive, so should be fine either way. |
