01-03-2018, 11:44 PM | #68 | |
Rep 875
01-04-2018, 06:07 AM | #69 | |
General
17365
Rep 18,762
The Choosey begger71936.50 |
01-04-2018, 06:09 AM | #70 |
General
17365
Rep 18,762
01-04-2018, 06:13 AM | #71 | |
General
17365
Rep 18,762
sygazelle11451.00 |
01-04-2018, 06:52 AM | #72 |
Libertarian
71937
Rep 4,035
All these people who think anything other than inline6 is not smooth, is pretty laughable...
01-04-2018, 06:55 AM | #74 | |
Rep 1,148
No need to be so sensitive - just wanted to point out that one sentence that jumped out at me in an otherwise fine post. Congrats on your driving history.
2018 M2: BSM, Exec, 6MT (ED on 10/5/17, re-delivery on 11/30/17) My BSM M2 European Delivery Story
2013 335i M-Sport sedan: BSM, 403M wheels, walnut trim, 6MT (gone) |
01-04-2018, 08:33 AM | #76 |
Libertarian
71937
Rep 4,035
01-04-2018, 09:27 AM | #77 | |
Rep 9,160
Doesn't mean a naturally unbalanced engine isn't good. The S65 is tits, just looking for a good car. I currently would love an RS3 hatch with a manual, that I5 is great. And as you stated, plenty of I4's are great motors, they're just not naturally balanced. |
01-04-2018, 10:02 AM | #78 |
#buildnotbought
10906
Rep 4,901
I'm pretty sure they didnt chose the I4 because of that. You're making that up while you're typing it.
01-04-2018, 02:09 PM | #79 |
Libertarian
71937
Rep 4,035
01-04-2018, 02:10 PM | #80 | |
Rep 3,408
Can't top that! Anyway, the number of cylinders today mean less than it did in the past. I went from American V-8s to BMW inline 6 (E28) to BMW V-8 (E39) 540s to my 4-banger F30. Used to be that you needed more cylinders to get the job done. Now, the 4 cylinder engines are so powerful and have such low end torque that many people, me included, don't need or want more. My 328 is just as quick and fast as my E39. Less cylinders means less weight over the nose. I don't track so I'm not sure but it seams like less weight in front will help in the handling department. I get wanting more cylinders. I'm just saying that less is not bad either. |
01-04-2018, 02:51 PM | #81 |
#buildnotbought
10906
Rep 4,901
I'm not angry, you're just making things up as you go, presenting them as facts.
The e30 m3 was developed as a homologation model. That means it has certain specs to follow in order to compete in that class. BTW the 4 cyl s14 in the e30 sits almost as far foreward as the later i6 in the e36: Look at its position compared to the strut towers or the wheel wells. Its all a matter of how you design a chassis.
01-04-2018, 02:58 PM | #82 |
Libertarian
71937
Rep 4,035
Well go ahead with your little sideshow it doesn't change the fact that a shorter engine is actually better than an inline 6, it moves the cg back, improves handling.
01-04-2018, 03:12 PM | #84 | |
Rep 9,160
Here's an actual S50b32 just to get things back on track. [IMG]https://i.ytimg.com/vi/pgJWq1hTvBc/maxresdefault.jpg[/IMG] |
01-04-2018, 03:21 PM | #85 | |
Libertarian
71937
Rep 4,035
01-04-2018, 03:24 PM | #86 | ||
Rep 9,160
01-04-2018, 03:31 PM | #88 | |
#buildnotbought
10906
Rep 4,901
The e36 m3 was never developed as a homologation model.
By that time only Mercedes, Opel and Alfa homologated to the class 1 dtm. Max specs for those seasons (1993-1995) were 2,5L 6cyl. The e36m3 has a bigger engine so no go. And in 1996 DTM stopped. Quote:
But you're completely right, if a designer cannot place an i6 into his design (for instance he doesnt want to offer up the required cabinspace ), a more compact layout can be getter. Of course you have to come over the fact that the i6 has a better balance, is easier on flow and thermal management (it has a distinct cold and hot side) etc etc. compared to a V6 setup So all people with an engineering background will answer the question with the same as what was already given in the first reply of this topic: "it depends". Its mostly the people that dont have an engineering background that luster for an answer that is conclusive in ALL situations, as that would make it easy to understand. Alas it is not that easy.
