02-02-2024, 06:20 AM | #1 |
Rep 102
Washer Jets
Sorry to ask. But I've not had a car befors with washers jets directly at the end of the blade arms. I might have to adjust the direction as the coverage of fluid could be improved. Can this be done with a pin?
But I noticed that on the passenger side there is a hole for a single jet facing back across to the drivers side. But looking closely I can't see a jet. Before I make an idiot of myself at the dealers can I ask if one should be present? Hopefully the attached 2 photos should show the location. Thanks |
02-02-2024, 06:49 AM | #2 |
Rep 129
Will have a look on mine over the weekend if no-one else answers in the meantime.
On a related note, I noticed on mine the other day that the pump for the front washers only runs / pushes the fluid out when the wiper blades are going up, not when they are going down, while the rear one jets constantly for as long as you hold the switch in the "wash" position. Can't remember if the front has always worked like that but it does it consistently now so I'm assuming it's normal? |
02-02-2024, 07:30 AM | #5 | |
Rep 102
02-02-2024, 03:05 PM | #7 |
Rep 492
OK So I must admit I had not spotted that in the Manual... Antifreeze additive? I have the proper BMW screen wash, I've not had to top up yet. I need additive as well?
02-02-2024, 03:22 PM | #8 |
Rep 163
Depends what sort of screen wash you use and if you need an additive, most of them contain antifreeze these days including the BMW one - https://shop.bmw.co.uk/5631/genuine-...antifreeze-5l/
02-03-2024, 03:49 AM | #9 | |
Rep 492
02-03-2024, 05:44 AM | #11 |
Rep 492
02-04-2024, 07:07 AM | #12 | |
Rep 2,182
I use a 2:1 water to screenwash for winter months and a 4:1 mix for summer, although recently with really mild winters here in the North East I've been leaving the mix at the 4:1 ratio. I know others on here have said that the BMW stuff is expensive for the sake of it but in reality I don't tend to use that much so it doesn't bother me. What would bother me is having to have the whole system flushed out due to deposit blockages and again as others on here have confirmed something BMW would not cover under any warranty so why would you want to take the risk? I can remember some time ago BMW used to advocate adding "Intensive screen wash" or some such named thing to add if found to be necessary I even seem to remember a separate reservoir for it on xenon headlight equipped cars going back to the days when there were little 'mini wiper blades' on the lenses, can anyone still remember them? |
The_Tok'Ra124.00 |
02-04-2024, 03:44 PM | #13 | |
Rep 492
Fun fact, My 325Ti Compact is a 52 plate from 2002, and it's mostly only used in the better weather now, but for the first 10 years it was used daily. I have never had to top up the screen wash reservoir in the 21 years I have owned the car LOL the reservoir must be pretty big. I do rememer those little mini wiper blades for the lenses, LOL. My Octavia had little water jets under the headlights, intergrated into the front bumper that would pop out and blast a jet of screen wash on the headlights every second time you used the windscreen washer. It worked very well, and I never had an issue with them failing in the 8 years I had the car. But the main jets would freeze up quite often in the winter, but then when it's down to -5°c for days on end, it's hardly surprising. I think I read somewhere that BMW use heated water jet nozzles on most of their current line up? |
02-05-2024, 04:31 AM | #14 |
Rep 342
Had 6 beemers and never had a screen wash issue. I use 50% mix in winter and 20% in summer and works great. Regular use of washers on the crappy roads up here propably helps keep system clear!
There are lots of good screenwash products out there BUT the key thing for us is to make sure that you never use a screenwash that contains silicone. See post #44 in link thread linked below. This is specifically stated by BMW as a possible cause of damage to the screen washing system. I wrote to Holts and they replied stating that none of their Holts or Prestone products contain silicone. Good news as I has been using them for years. There is a good thread on this that covers lots of options: https://g20.bimmerpost.com/forums/sh....php?t=1916642
02-05-2024, 04:32 AM | #15 |
Rep 342
There are lots of good screenwash products out there BUT the key thing for us is to make sure that you never use a screenwash that contains silicone. See post 44 in link thread linked below. This is specifically stated by BMW as a possible cause of damage to the screen washing system. I wrote to Holts and they replied stating that none of their Holts or Prestone products contain silicone. Good news as I has been using them for years. There is a good thread on this that covers lots of options: https://g20.bimmerpost.com/forums/sh....php?t=1916642
The_Tok'Ra124.00 bmnut815.00 |
02-05-2024, 04:36 AM | #16 | |
Rep 2,182
BMW washer jets have been heated for years now, they were even available back in the 80's and the era of the E30 but often as an optional factory fitted extra on the lower models in the range...at the time the only ones I could afford! |
02-05-2024, 06:41 AM | #17 | |
Rep 492
I may have heated washer jet nozzles on my 325Ti, I have no idea, it was treated to a good number of items on the option list, so... maybe! |
02-05-2024, 09:51 AM | #18 | |
Rep 2,182
Would be very surprised if the washer jets on your 325Ti weren't heated as that was the same model year era as the E36's and the 325Ti was the top model in the range, my late mother-in-law had the 318Ti and I know that definitely had them, she may have had them as a factory fitted option mind you, I can't remember now? |
The_Tok'Ra124.00 |
02-06-2024, 05:56 AM | #19 |
Rep 204
My E39 had two ways of washing the screen, as normal by pulling the lever towards you, but also by means of a little button at the end of the stalk which you'd push inwards - that was the "intensive" wash option that bmnut mentions above. It did also have its own separate tank, which I believe should have taken its own purpose "brew" intensive screen wash.
Btw, on the heated washer jets, I find they don't really help that much as the fluid tends to freeze within the small tubes that lead to it, which are unheated. Had this a number of times in our E91 when skiing... |
bmnut815.00 |
02-06-2024, 06:54 AM | #20 | |
Rep 2,182
The_Tok'Ra124.00 Riccardog37.50 |
02-06-2024, 12:05 PM | #21 |
Rep 129
Checked on mine: there does appear to be water coming out of the hole you showed in the pictures, Arthur.
The_Tok'Ra124.00 |
02-06-2024, 01:27 PM | #22 | |
Rep 492
I'm being a bit pedantic perhaps, but my 325Ti Compact Sport is the later model, built on the E46 platform. Like this one. https://www.pistonheads.com/news/ph-...-spotted/39311 Mine has differnt wheels, an all Chrome grille, and the clear rear lenses on the rear lights. It probably does have heated water jets then. |
