02-13-2022, 03:43 AM | #23 |
Rep 3,059
Sure, send me vin to pm
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
02-21-2022, 09:27 PM | #24 |
Rep 10
Hi, I have an OG M2 F87 LCI 2018.
Car had apple carplay when I took over but the subscription lapsed and I was told I have to pay BMW connected services to have it activated for life. Is there a way to get it done on the side at a better rate without violating the warranty? Thanks!
2018 OG M2 LCI Mineral Grey
03-18-2022, 09:34 AM | #26 | |
Rep 3,059
03-23-2022, 03:15 AM | #28 |
Rep 3,059
Yes no problem
PM sent
04-03-2022, 07:31 AM | #29 | |
Rep 4
04-13-2022, 01:17 AM | #31 |
Food Critic
1086
Rep 1,015
So I know I started this thread, just wanted to give a heads up...
For cars with telematics deactivated, it seems that maps through carplay just...Don't work well on iDrive7. It literally makes navigation apps unuseable. It doesn't matter what nav app you use, same situation, and it's the same situation for everyone I know with iDrive7 that doesn't have telematics updated. It seems that it can't pin to your actual location and it doesn't constantly update and freezes, so the app will constantly recalculate the route, and the map will literally bounce your location around 100 meters or more from where you are. I have a video of the screen just bouncing back and forth it makes navigation literally impossible. I'm posting this because had I known that I wouldn't be able to use maps I wouldn't have gotten Carplay especially given the price. Everything else of course works fine with pairing to the phone and using music, etc. just not maps.
04-22-2022, 01:43 AM | #32 | |
Rep 451
Drives: 2017 X5 & 2020 X5
Try checking it with the Life360 app where someone in the family/group can monitor your phone location independently from CarPlay
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
04-22-2022, 08:29 AM | #33 | |
Food Critic
1086
Rep 1,015
To your second point I'm not sure what you're suggesting...use an app to see...what exactly? To add a further data point, I live in a place where US spec cars are sold in a foreign country. I've talked to a number of other folks who have the same exact issue with carplay on ID7.
04-22-2022, 03:48 PM | #34 | ||
Rep 451
Just trying to isolate if it is the phone (which you have established is not the problem), Phone Network or the Carplay setup in a US spec BMW. In the meantime i will look into the FDL settings of the HU on my car which unfortunately in this case is an EU spec unit OK had a look at the FDL coding in the HU and there are too many country specific parameters that may be causing the problem. My only suggestion is if you can find someone with ESys or download a copy of ESys software (free) without the add on software and buy an Enet cable for about $25 You can temporarily modify the FA (Vehicle Order) from the US Version 800? to 802 (Korean) and VO code only the HU and see if that makes any difference? I came across a forum member from Korea called "Freelancer withour work" on one of the coding threads. Not sure where he resides in Korea but he seems very switched on with ESys coding and advanced retrofitting in his G20. He has a web page on You Tube showing all his modifications and coding procedures. https://www.youtube.com/c/freedong Maybe send him a PM and he might be able to help after all you have nothing to loose at this stage
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 04-22-2022 at 05:48 PM.. |
08-04-2022, 10:42 AM | #35 |
Rep 2
X2 imported from Japan to EU needs CarPlay
Hi kubax86,
would you be able to help activate CarPlay for WBAYK720705N02104? Imported from Japan to Cyprus. Thank you, Regards, Sergey |
08-04-2022, 01:15 PM | #36 | |
Rep 3,059
PM sent
08-04-2022, 02:26 PM | #37 |
Rep 2
08-26-2022, 03:58 PM | #39 |
Rep 3,059
PM sent
08-26-2022, 11:47 PM | #40 |
Rep 2
09-08-2022, 07:17 AM | #41 |
Rep 43
Big shoutout to kubax86 for carplay activation on my 2019 x3 . i have enterynav2 and didnt know it was possible to get carplay. kubax86 was very patient with all my questions as i was very nervous. simple process took 3 min. here are before and after pics.Attachment 2977471
Btw my car didn't come with any navigation . thanks again |
01-30-2023, 10:16 AM | #43 | |
Rep 1
