2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Want to remove the spare tire permanently - where can I get the proper cover?
      08-27-2019, 01:00 PM   #23
Sussex_G20
Sussex_G20's Avatar
145
Drives: G20 330i M Sport
Originally Posted by Giggler View Post
I believe the front battery is for the vehicle electrics systems, remote ventilation, stop/start etc. The main battery is in the trunk as usual.
Probably the keep alive as it is not a huge capacity item. My 435i battery would go nearly flat when I left it for two weeks during business trips ended up using a battery maintainer. With even more to run in the background makes sense to add a specific small unit.
      06-01-2020, 12:39 AM   #24
MU
Drives: 2020 330i
I know this thread is old, but were you able to order the trunk floor panel for cars that don't come with a spare? If so, did it fit properly? I'm in the same boat you were. My car came with both a spare and runflats (unfortunately), and I'd like to get some of the trunk space back.
      06-01-2020, 07:25 AM   #25
murderedg20
murderedg20's Avatar
Drives: 2019 330i M Sport
I'm working on this right now. I ordered the rubber mat instead of the carpet because it was $100 as opposed to like $300. I just need to put a piece of plywood under it
MU0.00
      06-01-2020, 08:50 AM   #26
mcg88
Drives: g20
I ended up buying this: https://www.bmwpartspros.com/oem-par...er-51477438290 Works as expected
MU0.00
      08-10-2020, 12:21 AM   #27
marcin693ca
Drives: BMW 330i xDrive (g20)
How to remove space saver?
Hi!
I accidentally got my g20 with a space saver, and now my trunk is 2 times smaller, any idea, what can I do to increase a space in the trunk?
I was trying to remove it, but the cover on the top doesn't fit when the tire is removed. Any ideas? Thanks!
      08-10-2020, 02:46 AM   #28
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Originally Posted by marcin693ca View Post
Hi!
If you remove the space saver you need to buy a new (non space saver) cover. Don’t know if you need anything else.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      08-10-2020, 05:53 AM   #29
FrostNixon
Drives: vw golf
Does anyone know of a handle on the cover? I have to use a screwdriver or knife to lift mine.
