03-29-2024, 10:29 PM | #1 |
Rep 84
RWD vs AWD Oil Capacity
Is there a difference in the oil capacity between the RWD and AWD model? Some sites says 6.9 quarts (6.5L) while others like below says 7.6 quarts (7.2L) for AWD model.
6.9 quarts https://www.amsoil.com/lookup/auto-a...b30o1-8-turbo/ 7.6 quarts https://www.amsoil.com/lookup/auto-a...b30o1-8-turbo/ |
04-01-2024, 08:15 AM | #3 |
Rep 84
04-01-2024, 10:34 AM | #4 |
Rep 194
NP. Your manual should also have this information in it. I usually fill a bit under 6.5 L to avoid inadvertent overfills; anywhere between min and max in iDrive is fine. BMW even says not to top up until you're at the min mark.
04-02-2024, 03:56 AM | #5 |
Rep 142
Drives: BMW 330e 2021
Does the M340i with the "M technik package" with the aditional oil cooler take more oil? On Ravenol's oil finder it says "6.5-7.2 liters" as capacity for the car.
04-07-2024, 12:55 PM | #6 |
Rep 194
Check your manual. I'd just buy 7 L as normal, fill to ~6.5 L, and take a measurement. Even if you needed to fill to 7.2 L, being short .2 L isn't an issue.
04-08-2024, 10:32 PM | #7 | |
Rep 84
I checked the owners manual and it doesn't list the amount to use and mentioned to refer to the maintenance booklet which I don't have a copy of. |
