2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Without trying not to sound simple
      09-20-2021, 06:17 AM   #1
johnboysafc
johnboysafc's Avatar
99
Drives: BMW G20 330e MSport Xdrive
How the hell do you get a G20 up on 4 x axle stands?
JohnBoySAFC
BMW Msport 330e xdrive 2020
      09-21-2021, 02:11 AM   #2
johnboysafc
99
149 x views to date and no one can answer? Im not sure its possible or wouldnt ask. But would like to be able to take all 4 x wheels off at the same time, is this possible on your drive or does it need a lift?
JohnBoySAFC
      09-21-2021, 02:16 AM   #3
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
You'd need a very low-profile trolley jack to get under the front but there's no reason you shouldn't be able to raise the back on the diff housing and place stands on the jacking points and then raise the front on the front subframe crossmember.
Ian
      09-21-2021, 03:01 AM   #4
johnboysafc
99
Cheers
But i thought there was no way of single/central lift point at the front on the G20, thats why ive been stumped
JohnBoySAFC
      09-21-2021, 03:03 AM   #5
xenon
xenon's Avatar
England
1397
I must admit I haven't done it but there is a sub-frame so no reason you can't use that. It might be a right PITA though if it's covered by a shield or undertray.
Ian
      09-21-2021, 03:30 AM   #6
johnboysafc
99
JohnBoySAFC
      09-21-2021, 03:32 AM   #7
HeebieJeebies
Drives: G21 320d xdrive, G22M440i xdri
Why don’t you use ramps or planks (stacked single, double etc), then you’ll get a clearer view of where to put final jack adjustment to get stands in
      09-21-2021, 04:29 AM   #8
GusL
34
Drives: G20 M340d Xdrive
Do you have 2 jacks and a spare pair of hands? Up at the front on both sides, stands in. Repeat at the rear?
      09-21-2021, 04:59 AM   #9
xenon
xenon's Avatar
England
1397
How? If you use the jacking point to jack the side up, where do you place the axle stand? The axle stand has to go on the jacking point. A central lift of the front / rear is the only way.
Ian
      09-21-2021, 06:45 AM   #10
johnboysafc
99
that's my thinking, unless you centrally lift the rear say and then use 2 x Jack's at front and leave them under.? But that's risky
JohnBoySAFC
