2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Wireless phone charger
      11-14-2023, 09:18 AM   #1
Davyogg
Drives: BMW 3 SERIES M Sport
Does anyone know if the wireless phone charger can be switched off? It’s the best place to keep your phone but constantly charging will make it really hot!
      11-14-2023, 09:29 AM   #2
lnlyssg
58
Drives: BMW 320i
You may be able to disable it with coding, there's a setting that you have to enable when retrofitting wireless charging so in theory you could turn it off that way:
Body Domain Controller (BDC_BODY3) -> WcaWirelessChargingAblage-> WCA_ENABLE
      11-14-2023, 09:48 AM   #3
paulockenden
575
Drives: 330e xDrive Touring
Just put the phone upside down if you don’t want it to charge.
ramparts1120.00
      11-14-2023, 09:51 AM   #4
Davyogg
I’ve been placing it at an angle to lift it up a little, just thought it might have an ability to be switched on and off..
      11-14-2023, 03:47 PM   #5
Chrisspencer
Drives: G21 330i
You can disable it in the settings menu
      11-14-2023, 04:04 PM   #6
The_Tok'Ra
Scotland
124
Drives: 325ti Compact Sport, G21 M340i
Care to expand on that? Where is that in the ID7 settings menu, or is that only in ID8?
      11-14-2023, 04:13 PM   #7
K20C4
Drives: G22 M440i
As someone else mentioned, you can place the phone face down to prevent it from charging. If you orient it correctly you can still use the digital key with it face down.
      11-15-2023, 12:42 AM   #8
Charlie (Wessex)
Drives: G21 M340i
I have to lift my phone up to get it to charge, but I guess that's a Google Pixel 7 Pro piss poor design. I started off thinking that wireless charging would be good, but it's not as good as wired and sometimes can't keep up with using Waze.
As Chrisspencer points out, it can be disabled in settings. It's somwhere under the Car settings (iD7)
      11-15-2023, 02:38 AM   #9
MisterG
England
21
Drives: M340i Touring, TVR Chimaera
Its piss poor on iphones too....
I normally resign to plugging into the armrest socket and leaving it in there.
B6WAF77.50
      11-15-2023, 03:17 PM   #10
The_Tok'Ra
Scotland
124
Personally, I've always avoided phones that have the ability to charge wirelessly. It tends to overheat your phone which is not good for the batteries longevity, and while wired charging is typically over 90% efficient these days, wireless charging at best is typically around the 70% mark.
      11-15-2023, 04:45 PM   #11
Scrupix
Scrupix's Avatar
Drives: BMW G20 330e M Sport
I’m also interested, but I did not find any option in ID7 to disable from settings, maybe I miss something 🤔
      11-16-2023, 12:56 AM   #12
Chrisspencer
Drives: G21 330i
It’s under settings, general settings then scroll down and it’s under data and devices
bmnut813.50
      11-16-2023, 02:18 PM   #13
bmnut
bmnut's Avatar
814
Drives: M440i xDrive
Had this model of car for over two years now and I did not know that!
'Every day's a school day' !!!
Thank you for sharing that!
      11-16-2023, 02:27 PM   #14
330Stevie
Drives: G20 M340i xdrive
Does this also turn off the external aerial boost?
      11-16-2023, 05:18 PM   #15
Scrupix
Scrupix's Avatar
So checed earlier and with my ID7 I don’t have such thing, I only have the options from the attached picture🙄
      11-18-2023, 07:26 AM   #16
The_Tok'Ra
Scotland
124
Yes, I see the same thing. No ability to disable the wireless charging pad.
      11-19-2023, 03:03 AM   #17
ramparts
Drives: M40i
You can only turn off the notification, not the pad itself.
As others have mentioned, place the phone face down if you want to use the spade without it charging
