11-13-2022, 08:19 PM | #1 |
Rep 265
Map region question
The maps in my G20 cover NC, SC, VA, WV, DC.
I will be traveling to Atlanta GA soon, is there a way I can add coverage for that area as well? Assuming it requires loading a different region, does that not become awkward driving between GA and SC for example? When I look at the MyBMW web portal under settings, it indicates I have automatic updates for Region 3 (south) which includes GA. So I'm confused about whether the nav system will work in the Atlanta area or not. Last edited by TheRetroGuy; 11-13-2022 at 08:26 PM.. |
11-15-2022, 07:16 AM | #2 | |
Rep 265
I mentioned in another post many months back that once on a trip to the DC area, the nav system seemed to work fine in Maryland even though it wasn't in the list of states displayed on the display. However on another trip to same area when (I believe) I was in DC city boundaries proper, the navigation system reported not knowing where I was.. somewhere around the Smithsonian zoo area. This, despite DC being in the list of the supposedly supported. Right now the plan is to invest a reasonable amount of time trying to get this question answered before the trip, but also have multiple backup mechanisms. Probably Waze on Carplay since I always have that running anyway. I also have a decent Garmin unit with a beanbag mount that I keep handy as an extra backup which has lifetime north america updates. I might also experiment with Apple maps and Google map apps to see if I have a preference, but I would prefer to use BMW nav as much as possible, as I like seeing details on the HUD. Trip isn't until January so I have some time to work it out. If for some reason I forget to report back on my experience, someone please ping me here, thanks. |
11-15-2022, 09:11 AM | #3 |
Rep 204
I wouldn't think you would be able to tell that you are 'in region' or not. I drove out to Colorado a year ago and used the BMW routing almost exclusively. It knew about construction zones, found every place I needed in Vail/Beaver Creek. It probably showed me points of interest, like restaurants, that were no longer open. Since I wasn't going to them I didn't notice. One of the better features of the BMW app is the ability to navigate based on Contacts (maybe IOS only?). Setup a restaurant or any destination as a Contact before your trip and then search for it within the app, send the directions to your car. BMW under-documented this feature and it is one I use all the time.
11-15-2022, 10:30 AM | #4 |
Rep 380
I'm in Europe but I think you can test the available map data while at home. Set a destination where you want to go. To check map detail, make a search around the destination.
Alternatively you can use the Demo mode and enter both start point and destination in the area of interest. In Europe the "Home region"= a few countries, defines what area is updated over air, but the car was delivered with map data for many more countries. (We can subscribe to USB updates of the whole area, but IIUC it's not available in NA.) |
11-15-2022, 08:00 PM | #5 | |
Rep 265
11-15-2022, 08:05 PM | #6 | |
Rep 265
11-15-2022, 08:19 PM | #7 | |
Rep 265
11-20-2022, 05:52 AM | #8 |
Rep 1,479
Drives: 2020 M340Xi (G20)
TheRetroGuy,
Since I'm in VA, I set home region on BMW ConnectedDrive site same as you did. Car has received OTA updates for this home region, but car still has map information for rest of Continental US. Several months ago, we took a trip to NJ & upstate NY, returning through PA. Car's map data was fine. I must say, however, when we got near New York city & DC, switched to Google Maps for most current traffic information So, I think when we traveled into another region, map updated for that region Hope that helps
Al
TheRetroGuy148.00 |
11-20-2022, 12:52 PM | #9 | |
Rep 265
I still don't quite have a grasp on what the limitations are for the main regions of the USA (such as region 3 - south, which is pretty much everything from VA to Texas) versus the OTA update region, versus what exactly would be lost or less current if I did travel out of region 3 etc., so if anyone knows a definitive link where I could read that info I would be most grateful. |
02-11-2023, 08:43 AM | #10 | |
Rep 265
It all went fine enough on the trip. In the part of ATL (north) I was in, there was a lot of construction happening with exits closed off so there was some level of frustration, but I'm not sure this had anything to do with the map data or if it would have been solved using Waze or Google maps instead. |
02-12-2023, 05:38 PM | #11 |
Rep 208
Drives: 2018 640i GT/2017 X5 40e
The NAV system will work everywhere in the US. The only thing you’ll be missing is any updates to regions you’re not subscribed to for the reasons another poster mentioned. (Essentially, it keeps the updates quick) If you log on to connecteddrive.bmwusa.com and log into your account, you have the option to change regions.
12-03-2023, 01:29 PM | #12 |
Rep 10
Region vrs US update
While planning a road trip out of “ my region” I’ve now clearly seen the “rest of US” map data is 4+ years old (2019-1) while my local region is latest 2023-x. It’s also clear bmw doesn't want to update all the US data for every update. One doesn’t need data where one doesn’t Go.
I have read that once the car is driven “out of region” *and* the update is subscribed the new update will auto load OTA. So I’ve read but not confirmed by anyone I can find. The Nav won’t stop navigating it will just continue with its out of date database. (Ignorance is bliss) The dealer will no longer update out of region maps nor will they update car OS which has been “waiting for install” but like so many others just WONT do its install. Dealer explained the sw update has become so burdensome they can’t handle it and that bmw no longer reimbursing them for time on incremental updates. Alternative is to do our own USB xfr & install. Anyone see these “automatic ota into a new region”? I will update after the trip. |
12-28-2023, 06:38 PM | #13 |
Rep 10
Regarding the map update, bmw customer service replied (thank you very much) that my map rev was up to date. Although the X5’s Nav display clearly shows Ca, Hi, NV and not “Western Region”, CustServ says that indeed the whole western region is updated. So, either customer service is off OR the coding map gurus SHOW a Ca, Hi, Nv update when they REALLY mean “whole western region”. Smells off to me.
The car did not update automatically once we were outside of Ca, Nv and never updated in the weeks in Colo & Utah. But of course if it was updated before it would not need an update. BMW regions indicate the entire wester US as “the region” while my display shows Ca, Hi, NV. I’d like to see any of you in WA, ID, Co, WY etc western area display info. Is it Subregions (unlike what customer service replied)? We are indeed getting our 4 updates OTA as indicated by the display 2023-04. And- btw - customer service says if you wanna travel outside your region the car will NOT update until it get into that region. You’d have to do that manually with a usb if you want the next region updated. Mine is clearly 2019 for the non-resident region. |
