10-26-2022, 03:02 AM | #1 |
80
Rep 437
ARMASPEED G20 M340i B58 Carbon Fiber Cold Air Intake
The BMW G20 M340i B58 ARMASPEED intake is made with prepreg carbon fiber and has been developed to provide the most efficient and direct airflow path to the turbo while maintaining low inlet temperatures. It not only brings you a visual shock but also brings out the best efficiency in your car. This particular G20 M340i B58 intake generates horsepower and delivers a plethora of turbo noises, previously hidden with the OEM intake. You’ll hear the turbo spool, vent, and flutter under load, especially in a higher gear with a light push and release on the gas pedal. 📌You can also add strut bars and paddle shifters for your BMW G20/ G21. Includes: - Carbon fiber cover - Carbon fiber pipe - ARMASPEED high-airflow air filter - Accessories Description: - Carbon fiber cold air intake for BMW G20 M340i (2019–present) - Engine: B58 - Direct bolt-on design, no modification needed - No remapping of ECU/DME is needed - Gloss Finish More info: https://www.armaspeed.com/product/bm...ld-air-intake/ Video:
Tags |
armaspeed, carbon fiber, cold air intake, g20, paddle shifters, strut bar |
