03-10-2021, 09:13 PM | #23 |
Rep 80
helmet91 Asterix RSnic rcz22 SG_E90
Hi all, sorry for late reply, here's some info you guys would like to know: 1. To get these M-style widgets, you have to do a flash(not simple cafd ncd coding) with your MGU(Headunit) with M vehicle FA using E-SYS(no need to get a Launcher). 2. For now, if your car is G20 3-series, there's no G80 M3 data yet in the latest PSdZData, so you cannot flash your MGU using G80's FA(if you somehow got one). The only option is to go for a SP2018 M-car like M8, X5M, X6M etc. 3. M menu for configuring M cars in Headunit will be all available, very cool to show to your friends but unfortunately they're not selectable, which is understandable. 4. Your vehicle model both in cluster and headunit will also be changed to which M-car FA you use. 5. You'll have no driving mode display in M style instrument cluster. Cheers and try at your own risk(flashing is dangerous than coding), good luck! |
03-11-2021, 02:37 AM | #24 |
Rep 567
Thanks for the info... Sounds like quite the undertaking. I'm comfortable with Bimmercode, but E-SYS scares me a bit.
Good luck, guys. |
03-19-2021, 04:32 PM | #26 | |
Rep 1
Hi jimmmyzhou,Can you provide a detailed tutorial for getting M-style widgets.I can use ESYS,Hope to reply. Thank you very much |
03-20-2021, 09:13 AM | #27 | |
Rep 224
It's set 20sec but I wish 30 sec or 1 min. Now is 0x14 means 20 sec HW_OPTION_BODY_LC_WELCOME |
03-20-2021, 09:21 AM | #28 | ||
Rep 224
0x40 means 62 sec. Got it. But is the correct coding for welcome light duration? Something else to do? |
03-25-2021, 08:34 AM | #30 |
DaZuc
72
Rep 161
Enable within HU_MGU & DKOMBI xview parameters
03-26-2021, 06:48 AM | #31 |
Rep 1,480
Drives: 2020 M340Xi (G20)
jimmmyzhou ,
Thanks! While I'm not concerned about VO/FA coding (did so on my F30 when I added PDC & camera), I pretty sure it will also affect such things like Tach redline since G80 M3 has different engine than my M340 (S58 vs B58) Perhaps, there's a way through FDL coding?
Al
04-19-2021, 10:08 AM | #32 |
Rep 142
Drives: 2021 BMW M440i XD
Garage List 1984 Mazda RX7 GSL [0.00]
1999 Subaru Sambar [0.00] 1970 VW Beetle [0.00] 2024 BMW Z4 [5.00] 2021 BMW M440i Coupe [0.00] |
Its under DKOMBI4, 3000 Anzeuge_Konfiguration, HUD_XVIEW_ENABLE
I just set it to active but don't see the x_view on the ID7.. oh well.. Last edited by cowymo; 04-19-2021 at 10:25 AM.. |
04-26-2021, 03:42 AM | #33 | |
Rep 22
01-02-2022, 12:51 PM | #34 |
Rep 4
03-19-2022, 04:50 AM | #35 | |
Rep 85
07-19-2022, 09:03 AM | #36 |
Rep 352
Drives: G20 330ix M Sport
I coded xview but some how I coded engine temp and turbo psi widget in the HUD but it doesn't function. Does anyone know what I coded for this so can uncode it?
07-19-2022, 08:43 PM | #37 |
Rep 243
That usually gets added when you code in the M tire psi/temp widget in the cluster but ive never seen it working.
07-20-2022, 05:28 AM | #38 | |
Rep 352
