01-19-2010, 03:23 PM | #1 |
Rep 14,394
Cooking with coconut oil.
I bought a big jar of virgin coconut oil after hearing it is good for you. I have been using it instead of olive oil for certain foods and it tastes pretty good too.
My question is could it be more harmful being that it has a lot of saturated fat. I watched one vid of an M.D. saying it is actually a good saturated fat and much better for you than any other oil. Especially Canola which I used to use when frying. Very rare but I do like fried shrimp. The problem, I read, is that coconut oil will not stand up to high heat as needed to fry. With the very cold weather we had here a week or so ago I had a dry scalp. My body is used to humidity I guess. The vid said to melt some and rub into your scalp/hair and leave on for an hour or so. Worked like a charm. |
01-19-2010, 11:18 PM | #2 |
Rep 304
I have cooked with it a few times. Kindof strange stuff as usually at room temperature it is sortof solid in the jar. Some brands seem to be better than others but it does have a very low temperature at which it burns.
01-23-2010, 08:25 AM | #3 |
Rep 36
there is no such thing as "good saturated fat". I would not use the coconut oil. The oil is almost pure saturated. Olive oil is 90% monounsatured. You could drink it and it would be healthy. Canola is closer to a 50% mix of polyunsaturated and monounsatured. That's still a good oil, but olive oil is better. Both are far better than coconut.
2006 325xi 6MT
01-23-2010, 05:20 PM | #4 |
Rep 14,394
A large number of articles I have read since I created this thread go against what you say about it. ^
This is pretty informative. Coconut Oil as Saturated Fat Another reason people believe coconut oil must be bad for you is misguided association: it is a saturated fat and "saturated fats are bad for you." Dietary guidelines inevitably fail to distinguish between different kinds of saturated fats and insist that saturated fats (meaning all saturated fats) are harmful. This is not just misleading. It is bad science. Leading scientists now recognize that just as there is good cholesterol, there are also good saturated fats. Fats are classified as short-, medium- or long-chain based on the number of carbon molecules they contain. Nearly two-thirds of the saturated fat in coconut oil consists of medium-chain fatty acids. When we eat long-chain fatty acids, they must be emulsified by bile salts in the small intestine before they can be absorbed into our body. Short- and medium-chain fatty acids, such as those in coconut milk, are absorbed directly through the portal vein to the liver, where they are immediately available to the body. In other words, most of the saturated fat in coconut oil is easily digestible and converted into quick energy. And these types of fatty acids are less likely to cause obesity because they are immediately used by the body and have no opportunity to be stored. Benefits of Coconut Oil Nearly 50% of the fatty acid in natural coconut oil is lauric acid, which converts to the fatty acid monolaurin in the body. Lauric acid has adverse effects on a variety of microorganisms including bacteria, yeast, fungi, and enveloped viruses. It destroys the lipid membrane of such enveloped viruses as HIV, measles, Herpes simplex virus (HSV-1), influenza and cytomegalovirus (CMV). Its usefulness in treating AIDS is currently under investigation. It is a main component of human breast milk and helps protect children from illness during infancy. Capric acid, which comprises another 7% of coconut oil fat content, also stimulates anti-microbial activity. In other words: not only does coconut oil not cause heart problems, it is good for you. To quote Dr. Mary Enig: "The research over four decades concerning coconut oil in the diet and heart disease is quite clear: coconut oil has been shown to be beneficial."(See endnote 4.) Coconut oil is a "functional food," defined as a food that "provides a health benefit over and beyond the basic nutrients."(See endnote 5.) It is an immune-system enhancer. For further reading: Mary G. Enig, Coconut: In Support of Good Health in the 21st Century (offsite). Also the Center for Research on Lauric Oils, Inc (offsite). TFAs – The Real Cause for Concern In fact, the real problem fats in our diets are the trans fatty acids, mentioned above as a by-product of hydrogenating fats. Here are just a few of their adverse effects: lower the "good" HDL cholesterol and raise the "bad" LDL cholesterol while raising total serum cholesterol levels; increase blood insulin levels in humans in response to glucose load, increasing risk for diabetes; affect immune response by lowering efficiency of B cell response and increasing proliferation of T cells; interfere with utilization of essential omega-3 fatty acids; and escalate adverse effects of essential fatty acid deficiency. You get these effects, and more, every time you consume hydrogenated or partially hydrogenated oil, which is present in most processed food, including margarine, potato chips, baked goods, etc. |
01-24-2010, 01:03 PM | #5 | |
Rep 1,352
Kudos to the OP for using coconut oil for cooking. It is one of the best fats for that purpose.
Coconut oil also has anti-fungal/microbial properties (lauric acid), reduces triglycerides, improves thyroid function and lipid profiles, aides in weight loss, is exceptional for the skin and hair, and is great as a non-toxic sunscreen. Olive oil is good to cook with when using low temperatures as it will oxidize under high heat. Saturated fats DO NOT cause heart disease. The lipid hypothesis is based on junk science. |
01-24-2010, 05:34 PM | #6 |
Rep 14,394
^ Your posts usually seem based on fact.
Hide behind the couch symbol here: Yes, I put it on my face. I did not know it was a sunscreen though. Great to know. This one jar has seems like it is going to last a long time too. I have not made a grilled cheese with it yet. One of my favorite quick guilty pleasures. With a dill pickle on the side. |
01-24-2010, 05:55 PM | #7 | |
Rep 1,352
The use as a sunscreen is based on first person experience. I have fair skin, and I do not even get red after long-duration sun exposure in Cali sun. |
01-24-2010, 08:23 PM | #8 |
Rep 195
I'm not fully informed on the cooking part, but I've heard it's good. What I do know is that coconut oil is VERY good for you skin and hair. Look it up if you don't believe me. Try it out sometime!
EDIT: I decided to pull up a site for you myself http://www.organicfacts.net/organic-...conut-oil.html |
01-25-2010, 06:45 AM | #9 |
Rep 14,394
Hides behind couch again..
I have put it in melted/warm form on my hair and scalp 3 times now. Leave it for an hour then wash out. No more itch and smooth hair. |
01-25-2010, 06:31 PM | #10 |
Rep 36
And yet I find articles that counter yours. You can find articles on the internet that support all kinds of things. Your article does not prove anything the same as this article probably does not convince you:
http://www.healthcastle.com/coconut-...ed-heart.shtml And straight from the American Heart Association: Saturated fat Saturated fat is the main dietary cause of high blood cholesterol. Saturated fat is found mostly in foods from animals and some plants. Foods from animals include beef, beef fat, veal, lamb, pork, lard, poultry fat, butter, cream, milk, cheeses and other dairy products made from whole and 2 percent milk. All of these foods also contain dietary cholesterol. Foods from plants that contain saturated fat include coconut, coconut oil, palm oil and palm kernel oil (often called tropical oils), and cocoa butter. So the jury is still out and it's better to err on the side of caution until a consensus is reached. I don't consider the AHA as "junk science". You are free to bathe in oil if you'd like.
2006 325xi 6MT
01-25-2010, 07:15 PM | #11 | |
Rep 1,352
The study you posted proves absolutely nothing. There was no correlation made between heart disease and saturated fat intake. The meta-analysis I posted below included nearly 350,000 people! They found no correlation between saturated fat intake and heart disease, stroke, or cardiovascular disease This was published January 13th, 2010 in the American Journal of Clinical Nutrition. http://www.ajcn.org/cgi/content/abst...n.2009.27725v1 Poor lifestyle, an abundance of refined carbohydrates, transfats, synthetic ingredients, and vegetable oils lead to the inflammation that leads to heart disease NOT saturated fats. Dietary intake of cholesterol DOES NOT raise cholesterol levels. http://www.ncbi.nlm.nih.gov/pubmed/1...?dopt=Citation |
01-26-2010, 03:25 PM | #13 | |
Rep 1,209
As those Starbuck's foo foo drinks, mocha this, frappa crappa that, is all coconut oil and corn syrup and bad for you.
2011 535i
2008 VW GTI |
01-26-2010, 08:07 PM | #14 | |
Rep 36
We can spew crap like this back and forth all day long.... One thing is for sure - I agree with gonzo!
2006 325xi 6MT
01-26-2010, 08:56 PM | #15 | |
Rep 1,352
What exactly does the average life expectancy have to do with saturated fats causing heart disease, stroke, and cardiovascular disease? If a diet high in saturated fat leads to heart disease, a large group of individuals who ate as such would be dying of symptoms related to the disease. Does an active lifestyle simply inhibit the action of these "bad fats" that cause heart disease? Gonzo it seems to be on my side so I'm not sure if you have your story straight. |
01-27-2010, 06:44 AM | #16 |
Rep 14,394
I am using it and I believe the independent studies.
Starbucks and cooking shows?????????? Last edited by gonzo; 01-27-2010 at 12:02 PM.. |
01-27-2010, 11:34 AM | #17 |
www.facebook.com/Synergy69
24
Rep 505
I try to get at least 3 tablespoons daily. I have one with my morning V8 then the other two mixed in with my protein shakes.
01-27-2010, 11:39 AM | #18 |
Rep 75
Drives: Jet Black 2008 M3 Sedan
Use it for sex!
01-27-2010, 12:06 PM | #19 | |
Rep 14,394
I am getting off powdered protein. You melt the c oil then blend it in? Back to old reliable. 2% milk Egg whites Low fat vanilla yogurt Handful fresh blueberries Going to look for some organic peanut butter today. |
01-27-2010, 01:09 PM | #21 | |
24
Rep 505
no, I just use room temp water and mix and then shake up the coco oil in it. It's harder in the winter though. lol |
01-27-2010, 01:26 PM | #22 |
Rep 14,394
From another member re: powdered protein.
I don't recommend these commercially available products as the pasteurization and harsh processing leads to a supplement that is poorly absorbed. These processed "foods" take a toll on the body and can lead to digestive and endocrine disruption. Also. Many brands are made from sick cattle. Nuff said for me. I figure I can get more protein from a natural blend of milk, low fat yogurt, organic peanut butter and egg whites. Even if it is a bit less I am not drinking a sick cow. Phobia or whatever, I am not using it again. Some highly rated brand was mentioned that passes muster. Last edited by gonzo; 01-28-2010 at 09:46 AM.. |
