03-26-2021, 07:56 AM | #1 |
Rep 50
Drone at 65mph
Like most of you I hate run flat tires. I finally pulled the trigger on replacing my 9k mile old tires when I found a good deal. I am regretting that decision so far. I found a deal on Pirelli Pzero all seasons in 245/40/19. They fit and look great, handling is good and ride is also good. Only issue is when I get to around 60mph I start to hear some road noise that increases to an annoying drone at 65-70mph. Its not crazy loud but it is noticeable even with the radio at normal levels and I feel a very slight vibration sometimes as well. I know they are balanced correctly as that has been double checked. I also have 12mm wheel spacers (which were also on with the original tires). Has anyone else experienced this with spacers and wider tires then stock? I also played with tire pressures. Initially I ran the factory spec 38ft and 42rear but then figured they would not need to be this high with non run flats. I did a little research and adjusted them to 36 front and 38 rear. This did not change the noise at all. Any advice or info would be helpful. I should have just ordered the Michelins but these were about half as much (hind sight is always 20/20).
2020 M340i Xdrive Portimao
AA catless downpipe (offroad only of course) BMS intake and Inlet tube H&R Springs MHD Stage 2 E40 |
03-31-2021, 06:17 PM | #2 |
Rep 777
Sell them and buy the PS4s........there is nothing better than driving on good tires....
2022 M440i Convertible - San Remo Green / Cognac
2021 Mazda 6 Signature - Machine Grey / Parchment 2020 M340i - Mineral White / Black - SOLD 2017 M2 - Alpine White / Black - SOLD 2001 e39 M5 - Titanium / Caramel - A "Keeper" |
03-31-2021, 08:39 PM | #3 |
Rep 50
I rotated them and they are much quieter for now. Since I can't return them, I'm gonna get some use out of them. The next set I will be wiser and just go with the Michelin's.
05-15-2021, 11:42 PM | #4 | |
Old Fella
18
Rep 37
I'm suspicious that this may be a design problem, or perhaps an issue with a resonance damper. Otherwise I may eventually have to change to non RFTs to try to address the issue, although there is no guarantee that this will work. To be continued ....
Current : 2019 M340i xDrive, Mineral White |
