02-18-2023, 07:06 AM | #1 |
Rep 534
MHT charging success.
Because I use my car relatively infrequently I was keen to periodically charge the battery. After discovering that my existing CTEK 3.8A charger wasn't charging my battery (even though the status LEDs indicated a full charge), I tried to find out why. Cutting a very, very long story short I found out that BMW have stated a charger with an output >20A is required. The only reports of successful MHT charging I could find were from 2 American guys on the General Discussions section of this forum, and they had both used CTEK 25A chargers. As there seems to be no alternative, I went ahead and bought a CTEK Pro25s.
It does seem to do the job. Before I hooked it up my battery had an estimated SoC of 55%. It then took roughly 11 eleven hours charging to raise the estimated Soc to 100%. Last edited by sjb993; 02-18-2023 at 07:22 AM.. |
02-18-2023, 08:15 AM | #2 |
Rep 1,230
The number don’t make sense to me. 11 hrs at 25A is 275Ah. And if that tops up the battery from 55% it means the total battery capacity is over 600Ah.
But I think the actual OEM battery is around 80Ah. Most strange. |
02-24-2023, 02:19 AM | #7 | |
Rep 534
Thanks again for bringing to light the Service Information Bulletin. |
02-24-2023, 06:24 AM | #8 | |
Rep 15,858
Something still doesn't add up, where some can charge with a 5amp charger, some only with a 25amp, why no consistency? |
02-24-2023, 06:45 AM | #9 |
Rep 534
It is strange that some can't charge their batteries with >20A chargers.
In the case of reported success with 5A chargers, I wonder if those people are actually checking their state of charge. Or, are they relying on their charger's status indication LEDs? My 3.8A CTEK indicated that it had fully charged my battery, but it didn't increase the SoC at all. |
HighlandPete6658.50 |
02-24-2023, 09:59 AM | #10 |
Rep 1,230
But what is SoC as reported by the car actually measuring? Does anyone know? It can’t be voltage because that’s what the charger has measured and seen rise to the fully-topped-up value.
02-24-2023, 01:59 PM | #11 | ||
Rep 15,858
02-24-2023, 02:09 PM | #12 |
Rep 1,230
I suspect that SoC as reported by the car is just being too clever. If it knows the car was at 70% (say) and hasn’t been charged by the car itself, then it probably thinks it’s still 70%, even though you’ve charged externally.
But then that doesn’t explain why (sometimes) using a meatier charger will update the SoC value. Someone needs to put a hall-effect DC (current clamp) monitor on one of the charging leads and again on one of the battery leads and see what’s really happening. |
02-24-2023, 02:49 PM | #13 |
Rep 328
Interesting to just check the battery voltage directly across the terminals in the boot before and after charging.
Whilst it won't give an accurate SoC, it'll give a rough estimate of the battery's state before and after. |
03-31-2023, 07:34 AM | #14 |
Rep 535
Interesting and timely thread. Having never had battery issues in any other car over 33 years of driving, today my M340i decided to throw a low battery warning.
Admittedly it hasn't been used much the last month or so and today was the first time it moved in 10 days! So I'd better buy a charger - I guess the CTEK mentioned up thread is the best one to get?? Cheers |
03-31-2023, 09:16 AM | #15 |
Rep 353
Drives: 2023 M340i
Dumb question but why does one need to be worried about the battery for the MHT system?
Even if it is depleted, doesn't the running engine or coasting charge it back up? The 12v batteyis what is important to get the car started is it not? |
03-31-2023, 09:28 AM | #16 |
Rep 534
Bianchi Dave and NLJ,
You may find this attachment interesting. It's a BMW Service Information Bulletin with instructions for dealerships on how to maintain MHT car batteries either in storage or on the showroom floor. (FWIW - CTEK 25A chargers are used by BMW dealerships.) Last edited by sjb993; 03-31-2023 at 10:11 AM.. |
03-31-2023, 10:37 AM | #17 | |
Rep 353
Drives: 2023 M340i
If I leave for a 3 week vacation, should I worry about the 48v battery? I've never needed to worry about my 12v for this period of time. |
03-31-2023, 10:45 AM | #18 | |
Rep 534
But, just to be on the safe side, I'm going to get mine fully charged before I go away. |
NLJ217.00 |
03-31-2023, 11:11 AM | #19 | ||
Rep 15,858
48V system makes it more complex. BMW state the 48 Volt battery will keep the 12 Volt battery above a certain SoC, until both depleted. As to how long even a 12 Volt system stays reasonably charged, BMW posted the following, during Covid for UK users. (Bold text added by me). Quote:
03-31-2023, 11:41 AM | #20 | |
Rep 353
Drives: 2023 M340i
20km a day round trip. How do I check the state of charge for the 48v battery? I have the LCI, does it show a percentage somewhere? |
03-31-2023, 02:32 PM | #21 |
Rep 535
Just another thought, and I can't seem to find a definitive answer -
I know batteries are not covered under the insured used warranty, but does the manufacturer 3 year warranty not cover it? |
03-31-2023, 04:20 PM | #22 | |
Rep 15,858
There is documentation on how BMW dealers need to look after batteries on stock/showroom cars, to prevent too low a state of charge. Keeping charging calendars, etc. |
Bianchi Dave338.50 |
