Technical Topics Cosmetic and Lighting Modifications (exterior & interior) Ambient Lighting Retrofit?
      12-17-2020, 10:47 PM   #23
razanmajid
Drives: BMW 330i
anyone tried it?
I was reading this thread, and I was wondering if anyone has tried this retrofit yet? I wish I got mine with ambient lighting from the factory, but found with with a great price without it. the link to aliexpress above looks promising but im wondering if anyone tried it yet...
      05-08-2021, 07:23 PM   #24
DKarts
Ukraine
Drives: BMW 330i G20
I have some progress with custom made ambient light with using own wifi rgb led controller.
https://ibb.co/THpMfYb
https://ibb.co/Pz3tWvC
https://ibb.co/ZB0TWWs
But at this moment I have some trouble with front passenger door connector, that located in car. If somebody know how to access it for adding new pin wires to it? Should I remove fuse box or it must be some easily way to remove it? I have no problem with the rear doors and front panels as you can see on my photos. Hope for your helping and many thanks!
      06-11-2021, 03:07 PM   #25
Neo67
Drives:
I’m actually work on it.
The bad news is that the wire are not in place. We have to add the complete wire.
Nothing in the doors, and nothing in the dash.
To have the dash trim ambient light, you have to buy a new trim. The lighting système is integrated on it. Same in the left Air vent.
I’m looking to see where this wire is connected to. Will see.
      07-09-2021, 04:09 PM   #26
Ahmaddoski
Drives: 2020 bmw 330i Us spec
Can i know the details of the process please ? Parts used
      07-22-2021, 05:41 PM   #27
DKarts
Ukraine
My result of custom made Ambient Light for BMW G20 330i 2019:
You can read and translate some process in my blog here:
https://www.drive2.ru/r/bmw/3_series...40726/logbook/
I also can answer all you questions about my custom made Ambient Light in Telegram @dkarts or on e-mail: dkarts2009@gmail.com
Hope my information and experience will help you
      07-23-2021, 09:32 AM   #28
Ahmaddoski
I want to know how did you do the door panels did you change the panels? I assume you used fiber optic ambient light from aliexpress correct? If you can post some photos from close up i will be thankful
      07-24-2021, 11:00 AM   #29
DKarts
Ukraine
I bought original Aluminum trims with embient light. Than I just removed original Led module, connector, diffuser, and puted there my own RGB led stripe:
This is trims that I bought:
      08-08-2021, 04:43 PM   #30
Care01less
@That.M2
Care01less's Avatar
Drives: F87 M2 Comp
Would love to see the final product and get a $ number. I have a 2020 M340i which unfortunately didn't have ambient lighting as well. For the trim pieces I'll probably just order the G80 M3 carbon ones and do that retrofit while I'm at it.
F87 M2 Comp
997 Carrera S
G20 M340i (Sold)
      12-01-2021, 08:09 PM   #31
Care01less
@That.M2
Care01less's Avatar
Drives: F87 M2 Comp
Neo67 Any update?
F87 M2 Comp
997 Carrera S
G20 M340i (Sold)
