08-13-2023, 06:30 AM | #45 |
Rep 146
turbobeagle403.50 |
08-13-2023, 06:33 AM | #46 |
Rep 146
Start car in ECO individual mode
Light / rain sensor insensitive lights insensitive Turn off passenger mirror tilt in reverse No horn when locking car with engine running Enable option to turn off lights with engine running Exterior lighting switch off allowed - change to active Window lifter interuption when opening door - removed Auto start stop memory function active Auto start stop not active Air circulation setting memory Active Remove seat belt chimes driver and passenger |
08-13-2023, 08:52 PM | #47 |
Rep 1,792
I might be careful with this one - I’ve heard it could prevent your airbags from deploying in the event of a crash. Not sure if anyone has figured out how to reduce the volume or mute it. My gripe with the chime is that it starts to sound as soon as the engine starts regardless of whether the gear is engaged. Super annoying. I much prefer if it only went off after driving a short distance without seat belt - as is the case with other manufacturers.
I also had mine coded off - just like you but I’m going to revert back out of an abundance of caution until someone has figured out how to really reduce the volume of the chime. |
08-13-2023, 10:44 PM | #48 |
Rep 430
Do you mind sharing where you heard this? I’d be really surprised if this is the case.
dhock_holiday213.50 |
08-14-2023, 12:22 AM | #49 |
Rep 1,792
08-14-2023, 01:52 AM | #50 |
Rep 430
My understanding is that these basic configurations are mostly about regional preferences (e.g. show the iDrive legal disclaimer at startup in the USA because it’s so litigious there, but hide it in other countries). So to actually expose a configuration flag that lets you disable the airbags strikes me as odd, and even more odd for it to be bundled in with a seatbelt warning chime. I also think that if the airbag were disabled, the airbag light would be flipped on. If there really is a way for the airbags to be disabled by software, it would be for the technicians’ safety. But then BMW would want to make really sure that they don’t forget to flip it back on.
08-14-2023, 02:50 AM | #51 | |
Rep 1,792
Also - what exactly do you mean by exposed configuration? I don’t believe the manufacturer expects owners to code their vehicles at all. Those of us who code our cars are a small minority; so your argument about exposed configration is a moot point. Moreover if you tempered with a code that potentially affects how the seatbelt might react the manufacturer bears no legal responsibility. So again the question of litigation is not applicable as you’ll be liable. I personally would prefer to reduce the number of seconds for the initial gong — a parameter that’s codeable in earlier models like my E90 while leaving the system intact. |
08-14-2023, 09:33 AM | #52 | ||
Rep 430
08-21-2023, 01:25 AM | #54 |
Rep 348
08-21-2023, 05:15 AM | #55 |
Rep 5,115
Re seatbelt chiming, this sounds a like a market specific regulation. In the U.K. we only ( at least on my g30) get a chime after you have moved off and driven a small distance. The icon will appear in the smash’s but no chime unless you drive a bit or perhaps reach a certain speed. So you can manoeuvre the car around with getting chimed at.
08-21-2023, 09:28 AM | #56 |
Rep 430
08-21-2023, 10:24 AM | #57 |
Rep 1,792
08-21-2023, 04:16 PM | #58 |
Rep 430
I can't speak from direct experience unfortunately as I didn't update, but I emailed the bimmercode dev today and the response was that it won't work on 03/2023. I have an X3 M40i (and that's the model I specifically asked him about) so that may not apply to the G20. But I'm also following a few threads on various models, and they all seem to suggest it's still blocked. Take it for what it's worth.
08-21-2023, 04:21 PM | #59 | |
Rep 1,792
https://www.bimmerpost.com/forums/sh...php?p=30364318 |
08-21-2023, 04:28 PM | #60 | ||
Rep 430
08-21-2023, 04:32 PM | #61 | |
Rep 1,792
08-22-2023, 12:28 AM | #62 | |
Rep 146
08-22-2023, 05:43 AM | #63 |
Rep 853
Drives: 2020 BMW M340i xDrive
Still haven’t been able to code it off mine. Bimmercode says it was coded, but neither coding memory nor coding it “Not Active” seems to actually apply.
jfcbmw19.00 |
08-22-2023, 07:05 AM | #64 |
Rep 395
Simply coding it as ASS “not active” does not work on my 2021 mild hybrid M340i. You can code it, and it writes the change, but nothing happens to turn off ASS.
Finally went back and coded it to start up in Sport Individual, where ASS is always off. |
08-22-2023, 12:09 PM | #66 |
Rep 22
