Technical Topics DIYs and Coding Discussions (G20 DIY 6) Alarm System (VO 302)
      02-14-2022, 04:05 AM   #1
soi3847
soi3847's Avatar
Drives: BMW G20 320i M Performance
https://youtube.com/shorts/K7rvMN7CfLE?feature=share
https://youtube.com/shorts/kHg705pWODg?feature=share
https://youtube.com/shorts/pjtBT3FK99Q?feature=share
Many South Korean Car's has not Alarm System.
But Can Retrofit.
If You Have Gesture Control FZD Module,
Need Buzzer & Security Inside Mirror. (with Esys Coding)
-Parts Number-
FZD Module with Gesture Control
61319483615
61319460012
61319893141
61316986144
61319875363
61317910960
61315A0F616
61315A25179 - One of These
Buzzer
65759493759 - Buzzer
61132359998 - 3P Connector
07129904870 - Hex Nut
or
65122245615 - Buzzer Retrofit Set
Inside Mirror
51162472237 - Frameless Inside Mirror
or
51166830616 - Security Inside Mirror
Pin
61139230107 - NanoMQS 0.22-0.35mm
61131383776 - MQS 0.2-0.35mm
-Need Tools-
Trim Remover
IWISS Press Tool
Star Wrench Sets
Hex Socket 10mm
*Torque Tools (preferbly to have)
-Main DIY-
1. Removal FZD Module
2. Removal Inside Trim
3. Removal Rear Bumper
4. Assembly Buzzer
5. Change Inside Mirror
6. Make Wire to FZD
7. VO Coding
-Wiring-
Check Image
Go DIY (watch my video or repair guide)
(I'm so sorry... video is not Eng sub. only Korean)
Check PDF File or Video
1. Remove A Pillar Trim & FZD Module
2. Remove Passenger Trim & BDC Cover
3. Make Wire Buzzer to FZD
4. Assemble Buzzer
6. Make Wire Inside Mirror to FZD
7. Add VO 302
8. BDC, MGU, FZD Code or Flashing
Freelancer without work
JSaid287.50
panki_86137.50
baturbo47.50
akataka23.00
