04-09-2024, 04:05 AM | #1 | ||
Rep 123
Question re: drive modes
Unlike my previous car (Audi A4) where if I engaged Dynamic mode it would switch everything to dynamic (suspension firmer, steering heavier, gearbox into S, throttle response sharper) when I put my 340i into Sport or Sport+ the gearbox stays in D. The manual is pretty vague about what exactly is happening when you change modes but in the section on "Driving Experience Control" (p145) it implies that there is some effect on the drivetrain, at least in Sport+:
I can't find a good description anywhere online of what settings change in the different drive modes and what exactly the interaction is between them and selecting D or S on the gear selector. Does anyone have a link to one? Or know enough about it to explain? |
04-09-2024, 06:00 AM | #2 |
Rep 163
There's a small and slightly blurry image I have bookmarked at https://f30.bimmerpost.com/forums/at...1&d=1427641065 that explains the modes and gearing for the previous gen, I would assume that the G20 would be broadly similar
Edit: found a better image after some reverse image searching: https://f30.bimmerpost.com/forums/sh...postcount=68): |
alFR49.00 The_Tok'Ra124.00 |
04-09-2024, 08:20 AM | #3 |
Rep 123
Thanks, that's exactly what I was looking for - even if it's not exactly the same should be close enough to get a handle on it. Bit odd there seems to be nothing similar but official from BMW out there.
