Technical Topics DIYs and Coding Discussions Retrofit M Sport Differential 330i
      11-14-2023, 04:14 PM   #1
dan1111
Drives: BMW G20 330i
Hello.
I’ve bought a m sport differential and I am planning to change the stock open one.
From what I researched this would be possible but I need any advice if you have any.
If anyone did this before pleae share your insights.
From what I can see the GHAS control module is the same on both equipment levels, the wiring from the trunk seems do be the same but the sport diff has a plug. Is the wire hidden somewhere between the trunk and the underbody?
Would codding the VA be enough to enable the diff?
Thank you! I’ll update the post when I am done, diff arrives in couple of days.
      11-17-2023, 09:15 AM   #2
TheNine90
Drives: bmw
I think you will need to modify the fa to match a vehicle equipped with m sport differential
      11-18-2023, 03:54 AM   #3
dan1111
Yeah, that’s right. I found out I didn’t have the GHAS computer. I bought one and I need to install it. There is one plug going directly to the diff and one to the “car”. The plug for the car has 1 positive from fuse box, 1 negative, and 3 wires to the BDC. Still trying to figure out it I need to route them to the BDC in front or there is something in the trunk where I fan plug them in.
      11-18-2023, 11:50 AM   #4
TheNine90
Drives: bmw
The GHAS needs to go to the bdc to be connected to the flexray. Not sure if there is spare flexray port allocations at the rear
      11-19-2023, 11:56 AM   #5
dan1111
Based on the diagram the flexray goes from connector A416*1B (ghas module) to connector A258*8B (bdc module). Would a "spare port" show in the diagram?
      11-19-2023, 12:15 PM   #6
TheNine90
Drives: bmw
You will have to open the ports using tool32 and then reset and relearn the flexray configuration.
      11-20-2023, 07:02 AM   #7
dan1111
So pretty much even if I run the wires from the GHAS connector to the front BDC connector and plug them in the coresponding PINs I still need to enable the ports using tool32?
Thank you, this is very helpful!
      11-20-2023, 07:30 AM   #8
TheNine90
Drives: bmw
Yes. The GHAS needs to be added to the flexray configuration.
      11-20-2023, 11:33 AM   #9
dan1111
Thank's! I think I have everything I need now. I'll update this thread when everything is set up.
      11-30-2023, 03:29 PM   #10
hanselfransel
Germany
Drives: BMW
Enabling ports with tool32.
Can you explain a little more precise please
      12-01-2023, 01:34 AM   #11
TheNine90
Drives: bmw
open ZGW using tool32
steuern_flexray_pfad ==>F5(select required ports)
steuern_reset_learn_flexray==>F5
      12-04-2023, 03:40 PM   #12
hanselfransel
Germany
Drives: BMW
Thank you for the answer,
is it possible to delete GHAS in the other direction.
If i like to retrofit a G80 with real diff its not possible to delete GHAS as i know.Is it possible to delete the ports,so that GHAS isnt shown anymore.If you remove GHAS its always shown in ista, don t know why
Do you know a way for this too?
      12-05-2023, 01:27 AM   #13
TheNine90
Drives: bmw
Try deleting it from SVT and see if that fixes the issue.
      12-08-2023, 03:23 PM   #14
hanselfransel
Germany
Drives: BMW
No, the standard things i did several times
      12-08-2023, 08:58 PM   #15
TheNine90
Drives: bmw
I can have a look at it if interested.
      12-09-2023, 11:19 AM   #16
hanselfransel
Germany
Drives: BMW
I am searching for this for long time, i never had a full solution for error free retrofit for G80.
Ghas module is always shown with icom next although its not inside anymore.If you use normal enet its not shown , but with icom next its shown in ista.
So if you have good idea would be very nice
      12-10-2023, 10:46 AM   #17
TheNine90
Drives: bmw
So issue is only ICOM? Check using tool32 the configuration of flexray
      12-16-2023, 08:17 AM   #18
hanselfransel
Germany
Drives: BMW
OK, will do
differential, g20, lsd
