12-03-2023, 09:18 AM | #1 |
Rep 50
How do I turn off sailing?
How do I turn off sailing in comfort mode?
I found 4 lines of code on the forum: DKOMBI4, Anzeige_Configuration> 10Seglen_In_Comfort_Modus, Change to active HG_MGU, Global_Conf_Sailing, Change to active. Eff_Dyn_Sailing, Change to active. Sailing_Counter, Change to active Unfortunately, I have all (!) not active and sailing works in comfort and eco pro mode. I would also like to have a checkbox in the ecopro settings to disable sailing. 320d xDrive '19 car |
12-03-2023, 09:59 AM | #2 |
Rep 117
Put all on Active. Global_Conf_Sailing active will let you disable coasting.
Go to Vehicle Settings and searh for a menu with an item named 'coasting' In my id6 this menu is om vehicle settings->engine->coasting Remember that you must disable checkbox con every ride (i could not found a way to persiste between rides) |
12-12-2023, 04:12 PM | #4 |
Rep 117
