02-11-2021, 06:47 AM | #111 |
Rep 309
Yeah, it's a terrible feature, it always tries to steer me into potholes and cyclist, but when I actually need it to steer me into lane on the highway it does nothing.
06-21-2021, 09:44 AM | #112 | |
Rep 2,234
Thank god. It was ruining my experience. |
06-21-2021, 04:30 PM | #113 | ||
Rep 1,780
06-21-2021, 04:40 PM | #114 | |
Rep 5,089
06-22-2021, 01:20 AM | #115 |
Rep 2,234
That's exactly why it's downright dangerous. Numerous near-misses where it's yanked the steering wheel has left me infuriated. Thankfully that's no longer an issue with the latest software update allowing you to permanently disable the steering intervention.
06-22-2021, 08:24 AM | #116 |
Rep 336
A quick tap on the indicator eliminates most of those frustrations imo, I suppose that's one way for BMW to try shake their drivers' reputations though
06-23-2021, 02:44 AM | #117 | |
Rep 2,234
My work premises is on an industrial estate, which at certain times of the day is deserted, and yet I'm having to indicate to absolutely nobody when traversing a certain part of the road. On this same road there is a well-sighted bend which you can cut the corner of perfectly safely, yet if you try the car doesn't like it and tries to yank you back onto your side of the road. It's awful. Thankfully no longer an issue now. |
06-23-2021, 04:09 AM | #118 | |
Rep 336
Of course, I don't know your circumstances but I'd personally save the spirited driving 'til I'm off the industrial estate. That said, I definitely agree with BMW to add the flexibility to allow drivers to turn it off, more options and customization is no bad thing imo. |
06-23-2021, 05:08 AM | #119 |
Rep 255
Drives: BMW 320d g20
I hate it too. it's way too aggressive. I tried to overtake a cyclist, did not indicate, and the lane keep steering kicked in very strongly and almost gave me a heart attack. I turned it off. it now only vibrates the steering wheel bit does not intervene
06-23-2021, 05:10 AM | #121 | |
Rep 255
06-23-2021, 06:42 AM | #122 | |
General
13275
Rep 19,803
Make sure you have your setting on Early and I'm sure you will eventually get used to it trying to correct so it doesn't scare you.
francton126.50 |
06-23-2021, 12:33 PM | #123 |
Rep 310
Exactly the issues I had. It intervenes unexpectedly and in situations where it can cause fatal outcomes. I don't need line keeping. I'm not texting, eating, looking at the clouds while driving. And no one should do that, with or without lane keep assistant.
06-23-2021, 12:40 PM | #124 |
Rep 27
From my experience it is very abrupt so I just turned it off so now it only vibrates if I go over the line. I actually work for Mercedes and their lane keeping assistant is horrible, it actually feels like it brakes the inside rear wheel on whichever side the lane your going over and it gives you a mini heart attack and with their cars once you turn it off it's off, it won't let you have the option to have the steering wheel vibrate.
francton126.50 |
06-23-2021, 12:53 PM | #125 |
Rep 20
Am I the only person who likes this feature?
I have sleep apnea and while CPAP has been a game changer for me sometimes I still get sleepy when driving. I pull off and sleep for 5-15 min and all is well. The day after I took delivery of my '19 330i I was driving on a road near my house when I felt the need to sleep. The problem was the road had no shoulders and was surrounded by trees. I figured I was about 5 min from home, so I'd try to stay awake. Obviously, I failed. The car drifted to the right and the wheel shake woke me up. Before I could correct, the car steered back into the center of the lane. At that point I was FULLY awake and the rest of my drive was uneventful. So, do all the things listed in this thread sometimes bother me? Yes. DO I leave the system turned on always? Absolutely. |
francton126.50 |
06-23-2021, 01:01 PM | #126 | |
Rep 5,089
In addition my car has no blind spot(with steering intervention) + rear cross traffic alert as I figure that can be intrusive, but my experience with standard LDW now tells me $500 extra for BSD + RCTA can be quite useful too. |
06-24-2021, 02:13 AM | #127 |
Rep 336
Honestly like others have said that just sounds like bad habits feeding in, indicate appropriately and it won't engage lane keeping.
06-24-2021, 02:16 AM | #128 |
Rep 336
For me it's the front collision warning, I have it set to most sensitive which means rarely it'll panic if I take a bend that has cars parked on it as it thinks I'm going to keep going straight, but I'd rather 1000 mini scares than 1 hit.
francton126.50 |
06-24-2021, 04:37 AM | #129 | |
Rep 255
Talisman77151.00 |
06-24-2021, 08:40 AM | #130 | |
Rep 2,234
Without knowing the roads I'm talking about, you can't comment. When I say nobody is around, it's because I know nobody is around. You can see in this link here one bend which is a pain in the arse. It's a fast bend with good sighting, and if you stray slightly towards the central white line, the steering yanks you back right, just as you're turning the steering left. It's downright dangerous. This is on my route to work. https://www.google.co.uk/maps/@50.91...7i16384!8i8192 A bit further down the same road, the road slowly splits into two lanes, both of which go straight ahead at the next lights. I work shifts and sometimes it's utterly deserted and I KNOW nobody is around to see me indicate (and I would argue indicating is largely pointless anyway here) but if you try to keep right and take the right hand lane, the steering doesn't let you. It's a joke. I'm indicating to avoid the steering deciding it knows better. Technology shouldn't do that. https://www.google.co.uk/maps/@50.92...7i16384!8i8192 And if you think technology is flawless, you only have to look at the speed limit assist. I'd say 10% of the time it's showing an incorrect speed limit. |
06-24-2021, 11:43 AM | #131 | |
Rep 5,089
In both cases the steering interventions look legit. |
06-24-2021, 04:29 PM | #132 |
Rep 2,234
So even when there's nobody present to observe it, you think it's worthwhile using your indicators? Who am I supposed to be indicating to at 2am on a deserted industrial estate? When I'm using the indicators as a method to override the steering intervention, then there's something wrong with the technology. Thankfully BMW agree, which is why they've changed the ability to permanently override the steering intervention.
urbo7358.00 |
