01-10-2024, 03:38 PM | #1 |
Rep 19
Hey all
I'm looking to upgrade my OEM head unit with a potential Android based head unit. Just to clarify, I'm specifically looking at a head unit with Android installed directly on it ... so not a MMI unit. Few crucial questions I wanted to ask: 1) Sound - After doing some research online, it seems like the most common way to connect the head unit to the car speakers is via AUX or if the car doesn't have this then it's USB located in the armrest compartment. Is there any other way to connect the audio that comes out from the head unit to the car speakers? I'd prefer not to have the armrest USB port to be used for this. So in other words, can the head unit (connection from the rear or where the connection ports are located) be used to plug in the audio somehow to the car speakers? 2) What's peoples thoughts about using the GPS splitter to leverage the cars GPS as opposed to the GPS antenna provided along with the head unit. Does it work just as well or is the dedicated antenna better? 3) Does anyone know if the 4G antenna that usually comes along with the head unit also contain the wifi too? TIA! Nik |
01-10-2024, 06:01 PM | #2 |
![]() 4330
Rep 4,500
1. As far as I know, audio is only via Aux in the arm rest. You can't send audio via the USB. Get the higher end models with DSP, sound is pretty decent (but my hearing may be a bit damaged from years of V8 straight pipe abuse lol)
2. Absolutely use a GPS splitter so you can use the stock GPS antenna. I do this. GPS lock is much much faster than using the provided GPS antenna cable. 3. No idea here. |
01-10-2024, 06:31 PM | #3 | |
![]() 1154
Rep 1,502
01-10-2024, 06:45 PM | #5 |
![]() 1154
Rep 1,502
01-11-2024, 10:08 AM | #6 |
Rep 19
Ugh, this is highly annoying! Is there really no other way to hook into the car speakers? I just don't want to route any wire whatsoever to the armrest from the head unit.
01-11-2024, 11:08 AM | #7 |
![]() 51
Rep 45
The wire routing is clean and easy to the armrest. Go under the center console by your shifter, through the e-brake housing and in through the little vent (dremel out 1-2 bars in vent "grille"). No wires are visible.
01-11-2024, 05:59 PM | #8 |
![]() 4330
Rep 4,500
Yeah. Route it inside the center console itself. There's actually a rubber storage tray inside the center arm rest, and below that tray are some holes. The aux cable comes out the edge of the rubber tray, right beside the aux hole. You only have about 1-2 inches of exposed aux cable inside the arm rest. Nothing is exposed outside. Let me get some pics later.
Edit - Pic added. . Last edited by Redd; 01-12-2024 at 07:38 AM.. |
12-27-2024, 10:13 AM | #9 |
![]() ![]() 3
Rep 31
Does anyone understand why this is necessary? Doesn't that aux jack just go right back to the quad lock connector on the back of the head unit?
12-29-2024, 08:52 AM | #11 |
Rep 12
I didn’t do anything you guys are talking about … my xtrons headunit is 4g 64gb RAM and it was plug and play with the exception I had to buy a fiber optic decoder … and she’s been running perfect for about a year and some change now …with gaming emulators and all
12-29-2024, 08:59 AM | #12 |
Rep 12
12-29-2024, 06:25 PM | #13 | |
![]() 4330
Rep 4,500
12-30-2024, 10:35 AM | #14 |
![]() 3714
Rep 2,148
Ive tried both MMI and full android, and yeah the full is way better, less limited, more app, more settings, etc.
The biggest pros imo is the battery phone. MMI wireless KILL the phone battery, while xtrons wont that much, EVEN if I hotspot the cellphone. So with my Samsung, I did a routine : if xtrons bluetooth connecterd > Hotspot on. So every time I jump in the car, the unit has internet automatically, no 4G cable with a SIM necessary. GPS antenna that came with it, work fine for me. For audio you can use AUX or bluettoth A2SP if you have the proper combox. I didnt see a major sound quality decrease, some review stating the sound is worst are pretty old, so I guess they fixed that. And I'm on the highest sound system, the individual audio one. Other small cons, the screen is too glossy, might want to get a anti-glare film. also keep in mind if you use FM radio with the CIC, you'll loose the android sound, like Waze warning, phone , etc. You need to switch the input to take a call, and check waze for warnings. |
AttaboyK4.00 |
03-07-2025, 04:02 PM | #15 |
Rep 8
oVeRdOsE. Redd Whitewidow90 jiggersplat
Hi, all. Similar questions here and hoping to get some guidance from yall. 2011 F10 CIC. Recently Installed Android head unit (XTRONS 14.9'' Android 14 8 Core 8+128GB). Significant loss in audio quality when streaming wireless CarPlay music from head unit to OEM speakers via aux cable under armrest. Perhaps I just need to tune/recalibrate audio to alleviate this? I found this video whereby they claim to have used BimmerCode to code out (eliminate) the need to run the aux cable. I coded exactly as described but did not work for me. ANY sort of guidance you might be able to provide is greatly appreciated. Thanks in advance. |
Tags |
android, audio, headunit |
