10-01-2024, 07:56 PM | #1 |
![]() ![]() 2526
Rep 7,053
The Journey getting my 2001 E38 740i Shorty up to my standards
![]() Featured on BIMMERPOST.com After acquiring the car from a fellow enthusiast, I started to source parts from dismantlers, BMW dealers, fellow owners, as well as aftermarket sources. My thoughts about maintenance is if there is an better than option go with it. Trying to go as OEM plus and period correct as I could go... Problems to sort out - blown speakers - worn suspension - worn front leather seats - droopy headliner - M Parallels rashed and tired - brakes worn out / need more braking power - cosmetic issues, dulled out trim, roundel emblems worn, dents - paint imperfections - front bumper scratched up and paint damage - rear bumper scratched up and paint damaged - mirrors fade and don't match the car's paint - valve covers typical wear - cluster needs to be fixed (pixalation) - needs front windshield and rear window replaced (waiting for potential full body repaint) Upgrades Stereo - 5 inch rear deck woofers removed and replaced with Bavauto - Focal Flax Evo PS165ES (front and rear) - Focal FDP 6.900 V2 - 6 Channel Amp - AVIN Avant 4 - Design Rendition Cup Holders with 2 Charger Ports Suspension KW Variant 3 Syncro Design Works Thrust Arms Brakes Brembo GT Front Brake Kit Goodridge SS Lines Front and Rear Brembo Cross Drilled Rear Brake Rotors Brembo Rear Brake Pads Interior Restored Headliner, A, B, C Pillars, Mirrors in Alcantara Restored Rear Deck in Alcantara Front Seats reupholstered Restored Steering Wheel New OEM Leather Shift knob Replaced phone carrier in arm rest with coin holder (OEM) Center dash grill replaced with new OEM Exterior Roundel Front and Rear replaced Front Bumper Black Trim replaced Front Bumper repainted Rear Bumper repainted Mirror repainted Dents removed Wetsanded and Corrected OEM Pre LCI Center Grills UPDATE: 10/16/24 Ordered BavTek Inc BMW Instrument Cluster LCD Display Silver Ribbon Cable DIY Unfortunately I'm not sure where my original photos of the car prior to the mods and maintenance. When I find them I'll post them. ![]() Dent removal ![]() Bumpers, Mirrors and Trim removed for repaint ![]() ![]() ![]() ![]() ![]() ![]() ![]() Years of build up dirt and debris ![]() Painted pieces back from Final Touch Collision ![]() OEM pieces about to go back on the car ![]() Rear cleaned up for bumper install ![]() Old Orange bulbs out for newer clear bulbs ![]() Before ![]() After ![]() M Parallels were pretty beat up, had Will from Proformance in New Rochelle completely refinish them. ![]() ![]() ![]() ![]() ![]() ![]() Back on the car with restored wheels ![]() ![]() Last edited by Detailers Domain; 10-16-2024 at 01:52 PM.. |
31
SW111601.50 MichaelLH0.00 Wolf 3352570.50 MarcoF90185.00 spielnicht554.50 M5Rick74075.00 Dégoûté565.00 Mani5917323.00 tracer bullet4389.00 LH443421.00 JMD1037.00 pizza2401220.50 doudzi4.50 Berry52844.00 Needsdecaf8893.00 BrikM64.00 agentrnge404.00 S58_M17711.00 cfm56d7b6846.00 orkinos317.00 mrdudley641.50 2srsman97.50 TourStageFan22.50 TechKid340.50 volodp204.00 Niko ZV121.50 jpf34016.50 hypersonic1.50 A340600driver72.50 Ldlicon0.00 HP Guy7834.50 |
10-02-2024, 03:53 AM | #2 |
![]() ![]() 602
Rep 49
Drives: 2016 M235
Looks great! I’ve always loved the shorty E38.
Detailers Domain2525.50 |
10-02-2024, 04:11 AM | #3 |
![]() 193
Rep 88
Drives: 2010 Z4; 2008 118D
Can't wait to see more content. Great job so far!!
10-02-2024, 04:55 AM | #4 |
![]() 4770
Rep 3,461
Nice shorty sporty, looks great. Good luck with the car.
10-02-2024, 10:43 AM | #5 |
![]() ![]() ![]() ![]() 615
Rep 970
I came here to see oil leaks
Did you fix it all mechanically already? Nice car btw, enjoy the black paint |
Detailers Domain2525.50 W///8059.50 |
10-02-2024, 02:19 PM | #6 |
![]() ![]() 695
Rep 274
I have two NEW valve covers. $350 plus shipping from 85712.
Thanks, Ted |
Detailers Domain2525.50 MarcoF90185.00 |
10-06-2024, 05:26 PM | #7 |
![]() ![]() 2526
Rep 7,053
eventually this car will be fully repainted, in the mean time I decided to wet sand the car to improve the look of the paint.
Tools and products used RUPES Skorpio III Sander SAND PAPER - 1000-3000 RUPES HLR75 RUPES HLR15 RUPES HLR21 RUPES YELLOW WOOL PAD RUPES YELLOW FOAM PAD RUPES WHITE FINISHING PAD RUPES DA COARSE COMPOUND RUPES DA FINE POLISH THE RAG COMPANY MINER MICROFIBER TOWEL BEFORE THE PAINT WAS DULL WITH DEEP SCRATCHES AND SWIRLS ![]() PHOTOS OF THE PROGRESS ![]() ![]() ![]() IMPROVEMENTS ON THE PAINT AFTER THE SANDING AND CORRECTION ![]() ![]() ![]() ![]() BROUGHT THE CAR OUTSIDE AFTER SANDING AND POLISHING AND I WAS PRETTY HAPPY WITH THE RESULTS, IT'S FAR FROM PERFECT BUT MUCH MORE PRESENTABLE NOW. ![]() ![]() ![]() ![]() |
10-06-2024, 05:42 PM | #8 |
![]() ![]() 2526
Rep 7,053
Debadging and Installing new emblems. (heat gun / fishing wire / solvent to remove the left over adhesive)
While sanding the car I decided it would be a good idea to remove all the badges and emblems. ![]() ![]() 20+ years of old emblems with dirt and debris ![]() ![]() Hood and Trunk Emblems ![]() Old Vs New ![]() Rear Trunk Roundel Installed ![]() Front Hood Roundel Installed ![]() Last edited by Detailers Domain; 10-06-2024 at 05:57 PM.. |
10-06-2024, 06:16 PM | #9 |
![]() ![]() 2526
Rep 7,053
A ton of maintenance items
Fix Rear Shades - found a new one at the dealer the other side I believe was NLA ![]() 3 out of 4 Window Regulators were replaced ![]() ![]() ![]() Updating the broken grills with new pre LCI grills ![]() ![]() ![]() Transmisson Control Module - Replaced the old one (got some transmission failure code, so glad it was this module and not a transmission) ![]() Trunk Shock Mounts replaced ![]() ![]() Old vs New ![]() These were removed to prevent the water/condensation in the cockpit (one on each side / driver and passenger) ![]() ![]() Unhappy with the current condition of the valve covers I ordered a refinished set on ebay .... not really happy with what I got from the ebay vendor, I decided to go ahead with the covers and service. While the original ones were out I sent them to Proformance to refinish and wrinkle coat it. Ordered a valve cover seal kit / plugs / filters / oil the works. ![]() ![]() ![]() They all seem to do this ![]() ![]() ![]() New Starter ![]() ![]() Ebay bought valve covers ![]() ![]() ![]() ![]() ![]() Much better than the worn out stock ones ![]() ![]() New window/engine cowl to replace the old beat up one ![]() Wiper blades replaced ![]() When I bought the car the previous owner mentioned that the roof may have a leak, we ended up doing a full maintenance service on the sunroof, cleaned the track and changed all the seals. ![]() Center Arm Rest Coin Holder replaced ![]() |
Wolf 3352570.50 MarcoF90185.00 spielnicht554.50 Mani5917323.00 tracer bullet4389.00 Needsdecaf8893.00 agentrnge404.00 2srsman97.50 |
10-06-2024, 06:26 PM | #10 |
![]() ![]() 2526
Rep 7,053
Cleaned up the Engine Bay
Products Used to Clean the Engine Bay Nanolex Professional All Purpose Cleaner EZ Detail Brush Wheel Woolie Brush 20 inch Detailer's Domain's Standard Detail Brushes Sonax Plastic Detailer (used to dress the motor) ![]() ![]() ![]() ![]() ![]() Engine Cleaned and Dress (prior to the valve cover change) ![]() ![]() ![]() ![]() |
10-06-2024, 06:32 PM | #11 |
![]() ![]() 2526
Rep 7,053
Original Valve Covers get restored by Proformance in New Rochelle
Beat up valve covers ![]() Blasted and prepped ![]() ![]() ![]() Final outcome is great ... now time to find the time to pull it all out again and redo it. ![]() |
10-06-2024, 06:34 PM | #12 |
![]() ![]() 2526
Rep 7,053
believe it or not the car didn't have any oil leaks...but there were a ton of routine items that needed to be replaced, I'll post them as I have time to build this thread.
10-06-2024, 06:35 PM | #13 |
![]() ![]() 2526
Rep 7,053
thank you!
thanks! ![]() Ted I wish I knew... I would have bought them LOL. |
10-06-2024, 07:02 PM | #14 |
![]() ![]() 695
Rep 274
Well, it was either you, or the art installation in the den ;~). Looks great!!!!
10-07-2024, 09:42 AM | #15 |
![]() 2121
Rep 4,178
Beautiful e38! Really puts it in perspective just how much work it is to get a car back up to a good standard once it's been neglected for a while. Great work!
10-09-2024, 02:37 AM | #16 |
![]() 2483
Rep 3,023
How much do you think you’ve spent on replacing all these parts?
2025 X7 40i, 2024 I7 60i, 2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
MarcoF90185.00 |
10-09-2024, 09:33 AM | #18 |
![]() 185
Rep 201
Awesome restoration so far! You got me inspired now, as I have recently picked up a 1998 E38 740i and have currently been trying to get it together mechanically.
I do have some questions, how easy was it for you to install the new shift knob? As mines is kind of loose. |
10-10-2024, 04:18 PM | #19 | |
![]() ![]() 2571
Rep 3,663
MarcoF90185.00 |
10-11-2024, 08:57 PM | #20 | |
![]() 185
Rep 201
So far i got it going in a great direction mechanically. Next issue is shaking close to idle and up to 2k rpm. anything past 2k RPM and the shaking disappears. So will be tackling that issue this weekend Last edited by MarcoF90; 10-12-2024 at 11:03 AM.. |
Wolf 3352570.50 |
10-14-2024, 10:35 AM | #22 | |
![]() ![]() 2526
Rep 7,053
MarcoF90185.00 |
