BIMMERPOST Universal Forums Classic BMW (Pre-2005 Models) 2004 Z4 3.0i (Turn Signal & Window)
      02-02-2025, 01:36 PM   #1
NocturnalDev
Drives: 2004 Z4 3.0i
Hello,
I recently purchased a 2004 Z4 3.0i.
Currently, I am experiencing a weird issue with the turn signal. The light turns on and works, but the ticking sound is not always present. Sometimes, it works normally during the drive, but most of the time, it remains silent. What’s also strange is that I’ve had instances where the blinker turns on, the sound starts, then suddenly stops, while the light continues flashing both on the dash and outside. However, I have never had an issue with the blinker malfunctioning on the outside—the problem is only with the sound inside.
The other issue I’m having is that the passenger-side window has two notches when being pulled up. The first notch operates normally, stopping the window when you release it. The second notch, when pulled past the first, is supposed to raise the window automatically. Unfortunately, this second notch doesn’t work for the passenger window, regardless of whether you try it from the passenger door or the driver’s door.
Any help with either of these issues would be greatly appreciated.
Thank you!
