02-11-2025, 08:56 AM | #23 | ||
![]() 1386
Rep 2,669
Prepping for cermaic coating (aka liquid polymer, aka thin layer of transparent plastic) application is no different than prepping for waxing the car. You want to clean the surfaces first. Otherwise, you will just scratch the paint as you apply wax/ceramic coat on top of dirt. If you can clean the paint without Iron remover, than you don't need it. I do find Iron removers very helpful for cleaning the wheels and the lower sections of the doors and fenders. But those can also be cleaned with other chemicals. I also ceramic coated my wheels for subsequent ease of washing and maintenance. Quote:
a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
starlights377.50 |
02-11-2025, 09:26 AM | #24 | |
![]() ![]() ![]() ![]() ![]() 1394
Rep 924
Drives: 24 Pure Blue M4 Vert
I went diy on the coating - it was trivially easy. Couldn't recommend it more highly - it is an absolute no brainer. Almost impossible to screw up. Looks terrific. I did an initial application of Cure right after the coating - I've been maintaining with d3fy. |
starlights377.50 |
02-11-2025, 01:56 PM | #25 |
ホンダ
1284
Rep 378
The big thing with ceramic coating (that hasn't been mentioned) is that you don't want to get it wet within 2 weeks (3 weeks in the Winter) of application because the water will break the bonds, causing it to not cure properly and as a result, wear off much more quickly.
02-11-2025, 03:49 PM | #26 | |
![]() ![]() ![]() ![]() 378
Rep 763
NSXR1283.50 |
02-12-2025, 11:09 AM | #27 |
Rep 763
Considering that the car currently has wax on it, what's the recommended order in decon/correction process?
Wash > Iron R > Wash > Clay > Paint Correction > Wash > Surface Cleanser/Prep Spray > Ceramic coat. Is this correct or does it have too many washes? For washes, I plan to do rinse less using ONR - is that an issue? |
02-13-2025, 07:18 AM | #28 | |
![]() 1376
Rep 1,637
I wouldn't use ONR and definitely not for the final wash. Not sure if it has been confirmed but I've read enough speculation about it leaving a polymer film behind. I'd stick with a regular wash; obviously something that is not a wash/wax, wash/SiO2, etc... combo. re: wax, there are washes that help strip a wax coat as part of a wash. A combo of that plus the paint correction would do the deed. Some might say paint correction alone (assuming some degree of polish) should he fine. If it were me, I'd leave nothing to chance.
- Jeff
bosstones' flickr |
02-13-2025, 07:24 AM | #29 | |
![]() 1376
Rep 1,637
Off topic but I'd love to see some of your work. The photography sub-forum isn't very active anymore but that'd be the place to post'em. Then again, this is your thread so you could hijack it any which way you wanted. ![]()
- Jeff
bosstones' flickr |
starlights377.50 |
02-13-2025, 09:48 AM | #30 | ||
![]() 1386
Rep 2,669
Many coatings warn against washing the car with strong detergents for first 1-2 weeks, but rain exposure after 24 hours is usually perfectly fine. Of the onese I used, the following trend emerges:
If anything was missed, Claying will get the wax remnants for sure. Typical Directions: 1. Chemically and mechanically decontaminate the paint. By whatever means necessary, ending with a rinse/wash. 2. Before applying the coating, wipe the vehicle down with Coating Prep Spray (each coating brand has their own). Usually, this is just diluted alcohol. 3. Once the surface has been properly prepped, apply the coating one panel at a time. Apply side-to-side, and then up-and-down in cross-hatch pattern. 4. Once you finish coating, level excess product using a microfiber towel. Use short, firm strokes when buffing off excess. Flip your towel often. 5. Avoid exposing the vehicle to moisture for 6-24 hours (read specific coating instructions). a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 02-13-2025 at 05:12 PM.. |
starlights377.50 |
02-13-2025, 10:44 AM | #31 |
ホンダ
1284
Rep 378
Ceramic coating takes 2 to 3 weeks to fully cure (depending on several factors), and depending on which website you read you'll find different answers as to how long you should wait to expose it to any type of moister. Every installer should explain that water exposure within this period will absolutely shorten the life of the coating to varying degrees. This is literally the main reason why people have different outcomes with ceramic coating life.
starlights377.50 |
02-13-2025, 12:48 PM | #32 | |
![]() 123
Rep 112
Drives: '15 535i xDrive M-Sport, E30
Check out his recent video for the best coatings. CarPro CQuartz UK 3.0 is still one of his favorites and is on par (maybe slightly better?) than Gyeon MOHS. A little more $ but check out Armour Detail Supply. Their Quartz coating is one of Mike's favorites and I look forward to applying the bottle I just purchased later this Spring. I've heard it may not be the best for your first time applying a coating though. FWIW |
starlights377.50 |
02-14-2025, 03:42 PM | #33 | |
Rep 763
![]() Apart from above, I have 2 additional questions for anyone who can help. 1. What's the real world difference between Graphene and Ceramic coatings? 2. Can these coatings be applied to glass and plastic (such as exposed plastic bumper or other black plastic parts). If yes, will it wear off faster from glass due to wiper use? Thanks again all - please keep sharing your knowledge!! |
02-15-2025, 01:43 PM | #34 | ||||
![]() 1386
Rep 2,669
That insistance is highly impractical and bordering on absurd. Here is the video by DIY Detail team addressing the subject matter: Quote:
Possibly - increased longivity, but all longevity claims are unproven, highly suspect, and impractical. For example, any product that claims 5-10 year protection is fibbing, as none have been on the market that long. More importantly, your car's paint will pickup swirls and scratches in the course of a year, never mind 5-10 years. You will want to go back in and polish those out, and then re-coat the area. So what good is a 5-10 year longevity claim if every panel on your car will have been re-coated by then many times over? Same goes for any coating (consumer or pro) 5-10 year "warranties" - all of those are worthless if you read the fine print! Quote:
Cross material application and longevity are two biggest advantages of ceramic/graphene coatings vs. wax. You no longer have to mask rubber parts off before waxing, or work to remove wax overflow - I just ceramic/graphene coat over all surfaces with no white hazing or discloration on rubber and plastic. Some plastic and chrome trims fade over time, so you may want to first polish those out with appropriet restoring products, or apply black dies to black plastic first. Then allow those to dry before ceramic-coating over everything! Glass it the MOST troubleshome area because it gets constant scrubbing from the wiper blades. I've tried more glass ceramic/graphene/nano/whatever coatings than those for any other surface (Adams (multiple versions), Gyeon, Griots (multiple versions), Stoner, RainX, and others I'm forgetting right now). None lasted more than 6 months. Some decay gracefully, some induce massive wiper skip/chatter and require some form of intervention after 1-3 months, but all wear off WAY before the promised longevity benchmark. I've even tried ceramic coating the wiper blades together with glass - same outcome. Coatings applied on other areas of the glass (rear, roof, sides) do last much longer than RainX (old benchmark). But the wipers destroy ALL windshield coatings in <6 months. At this point, I'm not sure anything lasts longer than RainX + RainX topper in the winshield washer fluid! HTH, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 02-17-2025 at 11:20 AM.. |
starlights377.50 |
02-15-2025, 08:45 PM | #35 | |
ホンダ
1284
Rep 378
This link explains the curing process in basic detail, and how it depends on several factors: https://www.feynlab.com/how-long-doe...4sZrIlNTkUDWzx |
02-17-2025, 11:29 AM | #36 | |
![]() 1386
Rep 2,669
1). Initial cure when exterior surface hardens and car becomes safe to drive. DIY and other vendors say that takes 1-4 hours. Your vendor (Feynlab) claims their product takes 24-48 hours. 2). Full cure with chemical cross linking between coating and paint. Feynlab claims this take "several days to a few weeks". Other coatings disclose 6-24 cure times. Finally, the punchline message from Feynlab site is very apropos: "Follow the manufacturer’s recommended curing times and application instructions." I totally agree with the above, and nothing on Feynlab's web site would make me want to go against the earlier cited cure times from DIY, Adams, Gyeon and McKeys (6-24 hours before road ready). HTH, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 02-17-2025 at 05:41 PM.. |
s_ribs122.50 |
02-19-2025, 02:01 PM | #38 | |
Rep 763
![]() I think I am settled on Mohs Evo and will apply a top layer of Gliss on that at some point. Now the wait begins for the weather to warm up to 60s - we are in the 20s at the moment, so I decided to add some more garage lighting in the meanwhile in preparation for the time for coating! |
02-20-2025, 11:14 AM | #39 |
Rep 763
Alright, I am back with some more questions :P. (I must stop going down these research rabbit holes - LOL).
02-20-2025, 04:35 PM | #40 |
![]() ![]() 2166
Rep 2,909
Drives: F33 430 and F39 M35i
I think you need to prep spray again after Essence before applying Mohs?
Carpro has essence plus out now. In other news, the Mohs Evo I ordered on Feb. 7th finally showed up today. Post office lost it after it left Chicago on the 12th. |
02-21-2025, 08:10 AM | #41 | |
![]() ![]() 150
Rep 153
starlights377.50 chowser512166.00 |
02-21-2025, 10:40 AM | #42 |
![]() ![]() 100
Rep 98
pro detailer here, get yourself a bottle of gyeon cancoat or optimum glosscoat (known as one of the easiest DIY coatings and the coating I install most frequently for my clients)
If you're not going to polish the car I wouldn't even go for a "true" ceramic coating anyways. You're wasting your time and money. It won't bond properly. I personally wouldn't recommend mohs to someone doing a first time coating. Nor Carpro. Just my $0.02 after tinkering with these products for years. Edit / Couple other things Don't waste your time with a chalky, shitty polish like Meguiars 205. Get a bottle of this instead as it's safe on trim, won't require masking and is super easy to use. You mentioned your car doesn't have a whole lot of heavy defects so this in tandem with a few RUPES Yellow pads is all you need. We're talking a few passes per panel on medium high speed and wiping the polish off. With the condition you described your vehicle to be in there's no reason you should need to spend any more than 60 - 90 minutes polishing. Secondly, you need a panel wipe before coating. Every coating brand makes one, I usually buy GYEON Prep and call it a day. Panel wipe as you go (after removing the polish) and consider doing one last panel wipe of the entire car at the end. Third, invest in quality towels if you're going to do this. You need the proper towels to level the coating efficiently. I guarantee you doing this job without the proper towels you are going to introduce a fuck ton of marring and swirlmarks. I've seen it time and time again and it's probably the most overlooked item for people new to detailing. You can spend hours and hours cleaning, correcting etc and the moment you go to apply that ceramic coating with those cheap yellow microfibers you got from costco or that pack from autozone you're ruining all that hard work. Last edited by EvasiveF87; 02-21-2025 at 10:50 AM.. |
02-21-2025, 11:38 AM | #43 | |
ホンダ
1284
Rep 378
02-23-2025, 12:29 AM | #44 | |
Rep 763
https://www.amazon.com/gp/product/B08NQ593K2/ Thanks again! |
