BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Whats The Fastest U Have Been Driving In Your Life?
      05-25-2007, 04:50 PM   #45
NSM
Modeldater
23
Drives: BSM M6 Vert & BSM 1M
187 in a dodge viper gts acr edition (modified)
191 2005 yamaha r1
      05-25-2007, 05:10 PM   #46
Fartpimpson
Fartpimpson's Avatar
Drives: E92 335i
2007 E92 335i  [0.00]
180mph in Ferrari F430 Spider with straight pipe, also my other record is from Alhambra, CA to Las Vegas in 2 hours and 45 minutes in a Buick.
      05-25-2007, 05:11 PM   #47
Fartpimpson
Drives: E92 335i
Originally Posted by Dammmittt View Post
Stable huh...I guess you were going in straight line.
      05-25-2007, 05:41 PM   #48
Carnage
Carnage's Avatar
Drives: people insane
I raced the Flash once and he was going almost the speed of light but I smoked him with my Procede 335. 335 rules everything!!!!
Sorry I couldn't resist....
      05-25-2007, 07:38 PM   #49
Dammmittt
My favorite sign.
Dammmittt's Avatar
Germany
186
Drives: 2007 M Coupe
Originally Posted by n1smo View Post
What exactly does the video show? Other than you saying "holy f#$k" over and over again like a broken record? The video does not show 155mph, it shows you saying the limiter is at 155. The other day, I was cruising at ~150mph for 20 miles or whatever the distance from the A6/A7 interchange to the Bad Windsheim exit. I was chasing a VW Tourag which has a higher governor because he was pulling away from me on the straights, I made up distance by carrying my speed into the turns and I never saw the needle go past 150mph, downhill, uphill, level, doesn't matter. Now, you caused me to dig up my old 330 catalog and guess what? It states the car is governed at 149mph for the 330i and 150mph for the 330xi. Your adrenaline was running high which caused you to become delusional, by all the evidence I have seen, the car is governed at 150mph. But I will do one more experiment just for you, I will set my speed warning function in Idrive to 155mph and replicate your run. I'll post the results after the next time I have to hit the Autobahn, which may be tomorrow if I feel the itch to drive up to Wurzburg.
n1smo I'm with you in theory...but M Coupe is supposed to be governed at 155 as well. Some times it just doesn't kick on when it's supposed to. (Pic is courtesy of me breaking in the car on A63 between Mainz and Kaiserslautern )
      05-25-2007, 08:08 PM   #50
Dammmittt
My favorite sign.
Dammmittt's Avatar
Germany
186
Everytime I had enough space. I'm thinking it wasn't set properly at the factory. The worst is when it kicks in and the engine just loses power. A7 is also a great drive. Enjoy it while you can. I miss it.
      05-25-2007, 08:21 PM   #51
Hunter399
Hunter399's Avatar
342
Drives: F90M5
165 in an e60 m5
      05-26-2007, 12:10 PM   #52
Str8EJ
Master of Ceremonies
Drives: '07 328xi Jet Blk/Blk/6Spd
couple of years out of college - pegged the speedo (120+) in my '93 civic, less than one week after completing my first motor changeover.
going south on i-75, south out of atlanta, past midnight.
only other car on the road (apparently) was a state trooper.
felt like 200 mph.
stupid, stupid, stupid.
result was a rather hefty fine & lecture, but no visit to the pokey.
      05-26-2007, 05:24 PM   #53
AW335TT
Armenia
627
Drives: a car
160ish in my Evo 9 on the PCH
      05-27-2007, 10:20 AM   #54
hotsand5
hotsand5
hotsand5's Avatar
Drives: 2006 BMW 330i 6spd
2006 330i  [0.00]
Results are in: The E92 335i Feb07' build is limited to 150mph, period. I set the speed warning to 155 (it allows you to set it up to 159mph) and let loose on the A7 enroute to Wurzburg. The needle would not go past 150mph (tried for ~5 miles). So, unless you think you have a special e90 330i that is able to go above the top speed listed by BMW, you were seeing things.
n1smo, I also verified BMW manual and it states top speed at 150mph, but I do know that the speedo needle went past 150. There were posts on here how the BMW speedo over exaggerates by a few MPH. Do you think its possible that the needle showed 155, but in reality it was going 149-150? Obviously you spent a lot more time on the autobahn and at high speeds than I ever would. Could there be slight differences between the 335 and 330, Euro vs US spec?
-2006 BMW 330i-Sapphire Black- Tera Leather-Aluminum trim- 6spd manual- Sport- Premium- Cold- Navigation- Euro. delivery
-2005 Yamaha Warrior 1700 102cu"
      05-27-2007, 11:17 AM   #55
Richwm
Richwm's Avatar
Drives: 06 E90 330i 6MT, 01 E46 330i
Originally Posted by 742 View Post
Is that the rule? A bit over 200 before getting airborne. .90 Mach after that.
Now the military/CIA guys can chime in. Curious to see if any old A-12 drivers are out there.
Not a driver but I worked on the SR for a couple years until the final shut down in 1998. I think there top was 2200 Mph.
Mar 05 Build date,2006 E90 330i, Sport Package, Premium Package, TR MT-1's . V-1 Hard-wired power with custom V-1 Concealment Display . Rear fogs, Rear power outlet's, M short shifter knob, BlackLines, BMW Strut tower bar, CDV Delete, Front M3 wishbones + tension struts, BMW Performance shocks and springs, BMW Performance Brake kit F&R, OEM short shift kit. Rear M3 Guide rods and Wishbones.
2006 E-90 330i with 302,000 miles.
      05-27-2007, 02:28 PM   #56
Dammmittt
My favorite sign.
Dammmittt's Avatar
Germany
186
lol 2200 huh? That's about mach 3.5-4 depending on the altitude.
      05-28-2007, 12:50 PM   #57
MJO9040
Drives: Alpine White 328i Coupe
2007 328i Coupe  [0.00]
so far 115 in my not broken in 328i e92
      05-28-2007, 01:05 PM   #58
hotrod2448
grand poobah
hotrod2448's Avatar
Drives: F80 M3, F10 535i
2011 335d  [0.00]
I've had my Evo up to 145mph once or twice. The fastest I've ever driven was around Fontana with the driving school I used to work for testing some new wing setups. I averaged something like 218mph.
      05-28-2007, 11:07 PM   #59
Heli Animal
Heli Animal's Avatar
Drives: 3 Cobra's (sold) - 335i Order
191 2005 yamaha r1
I've been 175 mph in a 00' GTS Viper and 175 in a 00' Yamaha R1 (both indicated speed.. I'm sure it was lower by a big error margin)
      05-29-2007, 10:03 AM   #60
achien
AC
Drives: E90 Post Members Crazy
120mph driving in a rental Pontiac Sunfire on Pennsylvania Turnpike from Philadelphia to New York.
On my second round trip I got caught and got stuck with a $495 ticket. (Ouch!!!)
Your Supreme Leader
      05-30-2007, 12:27 AM   #61
Richwm
Richwm's Avatar
" Developed for the USAF as reconnaissance aircraft more than 30 years ago, SR-71s are still the world's fastest and highest-flying production aircraft. The aircraft can fly more than 2200 mph (Mach 3+ or more than three times the speed of sound) and at altitudes of over 85,000 feet. " From fas.org http://www.fas.org/irp/program/collect/sr-71.htm
      05-30-2007, 12:51 AM   #62
BiggieJ
Drives: e92 335 ZSPZPPOPP
      05-30-2007, 10:16 AM   #63
Dammmittt
My favorite sign.
Dammmittt's Avatar
Germany
186
Oh A12...my bad. I thought you were talking about the A10. HAHAHAH
      05-30-2007, 12:12 PM   #64
hotrod2448
grand poobah
hotrod2448's Avatar
2011 335d  [0.00]
" Developed for the USAF as reconnaissance aircraft more than 30 years ago, SR-71s are still the world's fastest and highest-flying production aircraft that we know about. The aircraft can fly more than 2200 mph (Mach 3+ or more than three times the speed of sound) and at altitudes of over 85,000 feet. " From fas.org http://www.fas.org/irp/program/collect/sr-71.htm
Fixed.
      05-30-2007, 04:22 PM   #65
shipill
Drives: F10 528
ok ok let me tell u my something
210 KM or 130 MPH with peugeot 206 1.4 liter 75 horse power !! can you do that ? it was 4 year ago when i was back home
220 KM with VW Jetta 1.8 Turbo
      05-30-2007, 05:24 PM   #66
Dammmittt
My favorite sign.
Dammmittt's Avatar
Germany
186
Ummm...can you say wind resistance?
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
