Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications m340 not pulling
      12-21-2023, 01:25 PM   #1
kingm340
Drives: bmw m340
m340 not pulling
So i have had a weird experience where i was in first gear and when I floored It, it felt as if i was flooring it in 3rd gear from 0mph and when i hit 3-4k rpm is when it finally started going at speed. usually with m340s the cars are quick and move very fast at low rpms but it felt very laggy. then the next day the issue disappeared like nothing happened. never got any codes or any lights in the car. i am scared if something is wrong with the trans or if i have a boost leak. anyone got any thoughts?
      12-21-2023, 09:22 PM   #2
Its.Wiser
Drives: BMW M340i xDrive
Are you tuned?
      12-22-2023, 06:14 PM   #3
Manjot14
Happened to me Multiple times, In my case it was a torque limiter. I am Tuned on MHD
      12-30-2023, 10:05 AM   #4
kingm340
Drives: bmw m340
Originally Posted by Its.Wiser View Post
Are you tuned?
i am stock but I will be tuning very soon
      01-19-2024, 12:51 AM   #5
imported_nick
Drives:
i wouldn't void your warranty until you figure out what happened
k4sh_90580.50
lebaaron411.50
siegester378.50
      01-22-2024, 12:39 PM   #6
Dan B
Drives: 2024 M440i xDrive Gran Coupe
DSC on or off? Mine falls on its face hard when there is wheel spin. I turn off DSC and no issues.
      03-29-2024, 02:12 PM   #7
Dan Villa
Dan Villa's Avatar
Drives: 2020 M340i X-Drive
2020 BMW M340   [9.75]
Happens to me sometimes also. I'm not tuned yet. From a launch get full power its only from a roll in manual mode in 1st gear. I can do 2nd gear pulls with no
power cut. I took mine to the dealer and they found nothing.
Has anyone found the solution to this issue?
      04-02-2024, 09:41 AM   #8
rahimhussainar@gmail.com
Same symptoms here. Lmk if you find anything!
      09-10-2024, 08:45 PM   #9
Lasha_Saakashvili
Lasha_Saakashvili's Avatar
Drives: BMW X4M comp, BMW X3M40i, BMW M4.
Hey actually I’ve been having this problem too I’m tuned on MHD stage 2, I alwase get a DME interface times out code never any check engine lights or anything it just happens out of nowhere I think I know a few things that might cause this, #1 the car is running too hot, also could be the gas, oddly when I went E40 this problem stopped, also I notice that this happens mainly when I’m in comfort and as soon as I floor it it just doesn’t go until like 4-5k RPM’s. Other than that I really don’t know what the problem might be.
      09-10-2024, 08:55 PM   #10
cyam
Do a throttle reset. Almost guarantee this issue will disappear.
I have had this several times, every time I do a throttle reset it disappears.
      09-15-2024, 10:01 AM   #11
Narek_M4
Drives: 2020 BMW M340I
How does one do that? Can I do it from my house on my 2020 340 or do I got to take it to dealer?
      09-15-2024, 04:39 PM   #12
cyam
I have MHD and can do it through that. Otherwise, I think bimmerlink might be able to do it.
Not sure if there is a button sequence to a hidden menu that allows you to do a throttle reset.
