BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Wheel barrel brush
      07-14-2024, 09:59 AM   #1
Clarkie52
Drives: BMW M4 Comp
Wheel barrel brush
Can anyone recommend a wheel barrel brush that fits between the barrel and the calliper on a M4 Comp on 20’ rims.I have a full set of Wheel Woolies and use the medium 1 but this won’t fit between the calliper.
Looking for something a bit flatter.
      07-14-2024, 10:36 AM   #2
mjj
Drives: 2025 M4 Comp Verde BR
Have you ceramic coated your wheels? I use that and simple green wheel cleaner on cars I have had in the past. Then just rinse it off.
      07-14-2024, 10:41 AM   #3
Clarkie52
Drives: BMW M4 Comp
No wheels have no coating on them.I might start applying a spray wax on them to make cleaning them easier.
      07-14-2024, 11:47 AM   #4
B58-M340iX
Drives: 2021 M340i xDrive
P&S Brake Buster is great on wheel dust, and you can dilute it around 5:1 to make it last longer (not required, you can use it straight from the bottle or container). Use a thin microfiber-sleeved brush, like this one: https://www.amazon.com/dp/B0BHXCF44B/
rmedina144.50
      07-15-2024, 05:17 AM   #5
disintegrator66
disintegrator66's Avatar
Drives: '18 340i M-Sport 6MT THP MPPSK
I was looking for the same thing. Unfortunately in the automotive world it doesnt exist. I own several wheel cleaning microfiber brushes (wollywormit & barrel blade) and they are too thick to fit inbetween the barrel and caliper. I found the duster brush below works, but it gets a bit flimsy when soaked with water. However, it does work! Good luck!
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
      07-16-2024, 01:32 PM   #6
BobsM3Coupe
BobsM3Coupe's Avatar
Drives: X5MC
I have been using this one since my 2010 M3. Works great. Fits between the wheel and the 6 piston calipers on my X5M.
https://www.amazon.com/Speed-Master-..._source=1&th=1
shimmy232433.50
Huck5022.00
      07-16-2024, 01:35 PM   #7
Clarkie52
Drives: BMW M4 Comp
Already have this brush,stopped using it as I get splattered when taking it out the wheel.
      07-16-2024, 04:04 PM   #8
tracer bullet
tracer bullet's Avatar
Drives: '25 Z4, '15 X3 35i (135i sold)
I've been using a similar one: https://www.amazon.com/dp/B0C49X1C1W...roduct_details
For my Z4, but it is indeed thin and might be a candidate here. Comes with a few extra "sleeves" as well.
      07-16-2024, 06:07 PM   #9
biz77
Drives: 2021 X3 M40i
Hey, you want clean wheels or you want to be clean here?
Seriously, that style wheel brush is the best I've encountered for a tight clearance between wheel and caliper.
Raimo5356.50
      07-17-2024, 02:29 PM   #10
John in VA
Drives: 2015 228i M Sport
I wear a black T-shirt when I'm using my large or small SpeedMaster brushes! The Wheel Woolies-type do a good job as well. Sometimes it's worth it to just remove the wheel & tire from the car for cleaning.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      07-28-2024, 09:18 AM   #11
chassis
chassis's Avatar
7782
Drives: 9Y0 Cayenne S
What size brush is needed if the wheel is taken off the car to clean the barrel?
      07-28-2024, 10:56 AM   #12
DrVenture
DrVenture's Avatar
1148
Drives: M550i 2022
I'm with you on that! All kinds of nastiness sprays back at you, including the chemicals that you are using.
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Executive|Luxury Seating|M668 w/ DSW06+
      07-28-2024, 12:04 PM   #13
John in VA
Just about any size works to clean the barrel with the wheel off the car. You still need a brush small/flexible enough to hit the edges of the holes & spokes.
      07-29-2024, 02:20 PM   #14
Dan B
Drives: 2024 M440i xDrive Gran Coupe
I use these for my car. I have the M Sport brakes, so 374mm front rotors and 4 piston calipers. They fit.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      08-31-2024, 04:06 PM   #15
USMC G2
USMC G2's Avatar
Drives: 2025 M4 Competition
Greetings,
Or...you can make your own...
Semper Fi
rmedina144.50
Raimo5356.50
      09-01-2024, 07:07 AM   #16
cb804
cb804's Avatar
2394
Drives: 340 xDrive, M2C
I use this small brush from Adams to get between the caliper and the barrel. Unfortunately, it's sold out now.
https://adamspolishes.com/products/a...ni-turbo-stick
For the rest of the barrel, I use a Woolly Wormit. It works really well but doesn't fit between the caliper and barrel on my 20" wheels.
https://www.amazon.com/Detailing-Int...e%2C105&sr=1-2
