Technical Topics Cosmetic and Lighting Modifications (exterior & interior) BMW roundel
      08-14-2024, 04:02 AM   #1
Youngjnr
119
Drives: BMW E90 + BMW F30
BMW roundel
Anyone know the process of changing the roundels to black ones on a g20 trying to figure out how to remove the stock ones
      08-14-2024, 07:12 AM   #2
JJKiii
Drives: 2024 BMW M340i
2024 BMW M340i  [9.00]
There's two ways that I know of. Easiest is if you can find a strip of plastic box wrap (about 1/4 inch wide) and slide it under the roundel and slowly lift. Alternatively, and this is what I did on my car, put a bunch of blue painters tape around the roundel and using a plastic trim tool, slowly work your way around and it will come up.
      08-15-2024, 12:57 AM   #3
Youngjnr
119
Thanks I’ll give it a go, did u use double sided tape to stick new ones down?
      08-15-2024, 07:20 AM   #4
JJKiii
The hood roundels have two small "posts" and are held in by rubber grommets. Since my car was new, I just re-used the grommets. You can purchase replacement grommets if yours are older. The trunk roundel came with double sided tape in addition to the grommets. Here's two YT videos that explain the process.
      08-16-2024, 08:10 AM   #5
Youngjnr
119
Thanks you appreciate this just what i was looking for
